Question about Indesit W 123 Front Load Washer
Indesit wm12x currently have used setting number 3 after finishing does not drain and spin, just clicks round the settings, i have switched off and tried other settings but still wont drain it will do the rinse cyclebut wont advance on that and will go back to clicking round the washing options
  • 3 more comments
  • loopylou333 Nov 18, 2007
    on my indeset w 123 front loader i cannot release my filter compartment to clen my filter.
  • loo tat Dec 07, 2007
    i cant find the filter and my machine smells as it drains
  • chezza31 Jun 24, 2008
    it wont drain or spin at all and tried to get filter out and having problems.
  • rajul_lal Jun 27, 2008
    I have tried to clean the filter and adjust the water drain pipe as per the instructions in the manual. doesnot help.
    I live in a city where indesit doesnot offer support ... kinldy help
  • Anonymous Nov 13, 2008
    same problem. Can someone link to manual?
What other information can I add ? The haier stopped mid rinse and now wont respond to any programme attempts. There is a buzz showing that it is live - but plays dead ! :) So thanks for your offer to fix it Fixya , but I guess I will join the que with the others as you can't fix it from a distance .
Posted on Jan 01, 2012
Look into the filter of the pomp ..clean it and restart the machine
Posted on Sep 12, 2007
Washer won't finish spin No error codes
check the pressure is not sticking in the high position if the pressure system is blocked the air might be slow getting out stopping the pressure switch from dropping to low level by the time you get to the machine it has had time to drop to low and will allow the machine to spin
Mar 11, 2014 | Indesit Washing Machines
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Machine button is just clicking round and now nothing happening. Think something is maybe jammed in drain. How do I sort this. Indesit wm12x
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 20, 2011 | Indesit W 123 Front Load Washer
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
Mar 13, 2011 | Indesit W 123 Front Load Washer
My dial keeps clicking round on my indesit wm12x, have ordered a new part, do you think this is the problem.
I doubt it will solve the problem, as the part you are referring to is a selector switch and not the timer, the problem is more likely to be a faulty control unit.
Nov 19, 2010 | Indesit W 83
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Jan 13, 2010 | Indesit W 123 Front Load Washer
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
Indesit wm12x wont finish cycle just clix through dial,can u help me ?
i suspect that you may not be draining water,if you watch the light flash it will flash at 1 sec interviles it will then stop for approx 3 secs and then start flashing again at 1 sec int,if you wait for it to stop for aprox 3 secs.when it start flashing again count how many flashes til it stops again for the 3 sec,thats is your fault code,if it is 10 or 5,then its will be your pump blocked or inop.
Apr 05, 2009 | Indesit W 123 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
Jan 24, 2009 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
486 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
