High frequency sound out of monitor
When screen resolution is lower than 1152X864 32B or every 16B then monitor starts to make very high frequency sound waves. i do not know what to do, please help
    Problem Solver:
  • 13 Answers
Tell OS and monitor model...?
set this configration in win xp os...
1024by768 pix
32bit
and go to display properties=>advanced=>monitor=>change the frequncy....
some CRT monitors not support..
Posted on Aug 29, 2009
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
ViewSonic VE155b
this means that your computer is set to either a too high frequency or too high resolution. Try to lower the resolution setting of your desktop step by step, until the message disappears.
Jul 23, 2010 | ViewSonic VE175b 17" LCD Monitor
Screen Shakes on High Resolutions
your rate of refresh is too high, it's refreshing too fast, you need to lower the screen resolution. keep in mind, the tv resolution is much much smaller than a computer monitor. a computer monitor has much higher resolution. so Tv can only handle so much in resolution. if you need a better picture, it always the best to buy a monitor, not a tv for computer to get a good picture. if you have any more questions, let me know.
Oct 17, 2009 | Televison & Video
Out of frequency set resolution or see monitor
If you are getting a splash screen (COMPAQ) then video goes black, you can try this. Boot system in Enable VGA mode from the F8 menu and see if you get to the desktop. If you do, you can then go to display properties and adjust the resolution to the Optimal for the monitor.
If you do not get a splash screen, check you cable connections and ensure the Video cable is properly seated and no bent pins. If issue is occurring after the system was moved, also ensure that the correct video adapter connection is being used on the tower, as there may be 2
Oct 04, 2009 | Compaq 7500 17" CRT Monitor
"Input Not Supported" message on monitor at boot
Sounds to me like the input has gone out of the boundaries the monitor supports. IE the refresh rate is too high frequency (normally 60 to 72 Hertz for LCD's) or the screen resolution has been set too high.
Go into safe mode and set it back to 1024 X 768 at a frequency of 60 Hz, once back into windows proper you can try higher resolutions and change your refresh, if the screen goes black or displays a message "Out of Bounds" or similar it should revert after 15 seconds if left alone.
Have fun
Apr 27, 2009 | Envision EN-9250 19" Flat Panel LCD...
Can't view connected Dell Inspiron 9400 computer on Toshiba 37 AV52U TV
You need to change your computer display settings following your TV user manual.
Here follow the compatible display settings as on page 57-chapter 9 on manual.
Put resolution 640x480 and frequency 59,940Htz.
Here the user manual where you can find the same information on chapter 9.
See How to change display settings: screen resolution, screen
refresh
Do not forget to evaluate the solution.
Many thanks.
Mar 08, 2009 | Computers & Internet
Resolution
You need to enter a lower resolution. The monitor you are on is incapable of using a resolution that high. If you cannot get back on you need to start in safemode. Then change the resolution to a lower one that your monitor can handle.
Feb 25, 2008 | Gateway FPD2275W LCD Monitor
Screen Whine
Hi, constant high pitched whine from most monitors have something to do with the horizontal frequency which is partly affected by the screen resolution as set in your computer display properties. Try lowering down your resolution or go into safe mode. if the whine disappears, it may be that the monitor is not fully capable of displaying too high a resolution. If the whine continues even at safe mode or lower screen res, then you would need to consult a qualified technician to check for defective components in the horizontal circuitry of your monitor. I wouldn't recommend that you take look due to the presence of extremely high voltage in that area. Hope this be of some help. pls post again how things turn up. kind regards.
May 20, 2007 | Hansol Multitech 920p 19" CRT Monitor
Tiny Monitor
Out of frequency means your video card is trying to display a resolution beyond the capability of you monitor. Typically it is really a combination of too high a resolution and too many colors. Typically a 19? CRT will be set to display at a screen resolution of 1024 x 1024 with the color quality at 32 bit or *true* color. Personal preferences differ and you can set it lower or higher, depending on the capabilities of the monitor. Let us know if you have any other questions and please don?t forget to rate this post.
Mar 02, 2007 | Tiny Computers B1996 19" CRT Monitor
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
