Question about Nisca PR5310 ID Card Printer
I am using a Nisca 5310 Printing Machine with Heat Roller Unit 5302 which we bought it in 2008. Now the printer does not laminate the Card and gives massage below: Ribbon Type incorrect H1B-12" "The machine is printing the card properly till reaches to the Heat Roller Unit 5302. When the card reaches their the heat roller reject the card and gives error massage and the card comes out from backside of the machine.. The ribbon is the same one which we used it before. Below is the details for the ribbon: H00097 NSCHOLOUN500 H8D-372 2.598"x 180' And laminate ribbon is ymcko2 Could you find a solution as soon as receive the mail or send me a manual book please Ahmad Farid Hakimi
3 Suggested Answers
SOURCE: H 52 Nisca pr5200
SERVICE MAN CALL ERROR CODE = H53 I HAVE APROBLEM IN MY PRINTER
Posted on Jun 16, 2009
nilutpalsono
  • 238 Answers
SOURCE: Hi I changed the ribbon on
take it to a service centre
Posted on Aug 12, 2010
Laminate did not come out it just went back inside on roller
warm the machine back up, get the glue sticky again, then work it off, either by going in forward or reverse, whichever works best for the given situation. Don't use anything sharp as the rollers damage easily....very expensive
Sep 09, 2014 | Gbc Heat Seal Ultima 65 Laminator 1710740
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Lamination Problem
You have to go to printer driver, see the general settings and put more darkness(normally it ranges from 0-20, it should be set at 10. Try puting the darkness at 11,12,13, etc until it laminates properly. Don't forget to put back the setting when printing ymcko, or you will burn ribbon.
If the head that prints color is the same that laminates, then you should be cleaning the head after use.
Jan 17, 2014 | Datacard SP75 Plus Card Printer
Laminator wont feed
If the motor is running, then the cog that drives the roller system may have failed. Laminators built today are made with plastic (nylon) roller drive cogwheels that crack. Especially if the fed media is too thick. Put the machine into run mode and feed a single piece of card (a playing card will do) into the feed slot. Lightly hold the card and see if you can feel the card moving. To check if the motor is in reverse, feed the card into the output slot.
If you are handy with a screwdriver, then with it disconnected, remove the lid (about six screws underneath) and check the rollers for old lamination sheets that could be stuck to one of them. This would limit the feed gap between the rollers, preventing you from putting your media in.
Nov 23, 2013 | Fellowes Saturn 2 A3 Laminator Laminators
What is the difference between cold and hot laminators?
Hot laminators are the most common types of laminators. They use heat (220 to 300 degrees F) to apply the lamination. Hot laminators provide a better quality lamination that is more resistant to wear and tear. This is the preferred method of lamination for materials that are not effected by heat.
Cold laminators use pressure sensitive adhesives to bind the lamination film when the material being laminated is sensitive to heat. Certain inks in standard ink jet printers are known to have the ink melt in the machine. There are other types of printers that use heat sensitive paper. For these types of applications the cold laminator is the best choice.
Jan 28, 2013 | Office Equipment & Supplies
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
PVC HID 1000 cards were getting stuck/bent in the Lamination module of our DTC550 printer. Talked to the tech department where we bought the printer/lamination module. They suggest because we are using...
Turning down the lam temp and dwell on the lam unit should have no effect on image color - they affect the processes only AFTER the printing of the card is complete. Make sure you were making adjustments to the LAMINATION settings, not the printing settings.
As to the noise, squeeks and groans emanating from the lam unit usually means mis-loaded lam film. Check the loading of the lam film in the printer and make sure it is not binding on the spools, and that the spools turn smoothly. Other than that, it could just be your printer showing signs of age. They have been out of production for more than 5 years, and do break down with age and usage.
Apr 28, 2017 | Fargo DTC550 Thermal Card Printer
I want to change the toner Nisca PR5310
While I myself don't know anything about NiSCA printers, I do know they're basically government printers and I have a website you can visit that will help you with whatever you need. Here's the site: http://www.teamnisca.com/
Jun 18, 2010 | Nisca PR5310 Smart Card Printer
When printing text on every tenth or so Thank You Card, a card gets jammed and I can't seem to release the printer's grip on it. Is there a release other than the green lever above the rollers on the left...
It really sounds like the teflon coating on the heat roller is worn and contaminated. On an M20 you will have to replace the fuser itself. Google a business called " the parts drop" Give Britt a call and he should have what you need. The M20 uses a unique hearing element. So the fuser itself will have to be replaced. The pages you are printing are tacking to the surface of the heat roller. Not uncommon .
Jun 08, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Lam Error/Out
I contacted fargosupport.com and a technician walked through the solution, free of charge.
Jul 16, 2008 | Fargo Pro L ID Thermal Printer
251 people viewed this question
Top Nisca Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Nisca Office Equipment and Supply Expert? Answer questions, earn points and help others
