Question about Intel Computers & Internet
How to press key in keyboard going BIOS setup in model intel cerlon dot.station 2300
  • dadneil May 11, 2010
    Are you trying to get into BIOS
    Sergeant:
  • 199 Answers
Dear to entering in motherboard setting,,you can press one of the following keys,,,,
1-delete button press
2-F2 key
3-F8 key
4-F10 key
these keys are helpful for you.please rate it
Posted on Apr 13, 2009
I have inteldotstatin it is creating a problem that is system is not opening please give me the solution thanks&regards ranjith kumar
Ok,
The problem might be the boot device configuration
in first press F2 while your BIOS is loading
When your BIOS software start to load it will ask you for a
password, press enter and wait for the BIOS to load.
When your bios finish to load go to the option called Boot
you can get there using the arrow keys.
When you find the Bios option called boot you will see a boot sequence
at the first boot device option select Ide-Hdd.
If you want to load your OS using a PXE Boot(network boot)
select Intel PXE 2.0 as your first boot device.
If you want to Load the default config of your Dot Station(wich will make you boot from the hard-drive) go to the bios setup opition called exit and select the option Load Setup Defaults.
press F10 to exit saveing the configurations you did.
Hope that it helps you.
Dec 08, 2010 | Intel Dot Station (INTC300AIO) PC Desktop
Cmos setting wrong on start up
are you able to enter the cmos to make changes?
depending on the brand, you may hit one of several keys to access the cmos. del, f2, f10, f11, f12.
then try resteseing the cmos to defaults.
Jan 06, 2010 | Intel Computers & Internet
Which key is used to enter cmos setup in intel dot station
hi kamal
if u want to open bios so when u start ur computer so press on delete button which is on the keyboard then bios will open
regards
kamal
Oct 08, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
I want circuit diagram of intel dot station 2300
It's very relly hard to get the circuit diagram of intel dot station 2300..
you should try another way to solve your problem
you can tell what problem you are having with it.,
Jul 06, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
Keyboard keys
sir,
I have problem in my Keyboard keys, i have just buying dot station computer, i geting the problem in setup keys, i want to go in BIOS for setup what can i do for that please give me solution. Can i change keyboard or i change with other USB keyboard.
Dec 18, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Intel dot station english manual
You can download Intel Dot Station keyboard driver and keyboard layout at
www.nsexim.com
Apr 07, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
How to operate function keys and right click in intel dot station keyboard
F1 = HELP F2 = RENAME SELECTED ITEM, F3 = SEARCH FOR FILE OR FOLDER, F4 =Display the Address bar list in My Computer or Windows Explorer, F5 =Refresh the active window. F6 = Cycle through screen elements in a window or on the desktop. F7 =Displays all commands for this program stored in memory in a pop-up box. Use the UP ARROW key and the DOWN ARROW key to select the command you want, and press ENTER to run the command. You can also note the sequential number in front of the command and use this number in conjunction with the F9 key. , F8 =Displays all commands in the history buffer that start with the characters in the current COMMAND , F9 =Prompts you for a history buffer command number, then displays the command associated with the number you specify. Press ENTER to run the command. To display all the numbers and their associated commands, press F7., F10 =Activate the menu bar in the active program, ALT+F10= Deletes all macro definitions.
UZOWUANYA
e-mail: uzowuanya@yahoo.ca
Feb 11, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Function Keys
setup your keyboard driver then active your hot key & function key.
Feb 10, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Usage of keyboard
right click in keyboard. you can find in the space bar line "
from left;
CTRl, logo windows, Alt,space bar,Alt,Logo windows,right clickkey,Ctrl.
You can identify right click key cause there's an arrow pointer on it.
Jan 14, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Install
simply use xp cd and follow the given instruction..........
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 25, 2007 | Intel Dot Station (INTC300AIO) PC Desktop
Computers & Internet Logo
243 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
