Question about Microsoft Windows XP Professional
How i find cpu usage of client pc using java. i got aone code but which is written in c++. i want to write a java code that find cpu usage of client pc.
    Guru:
  • 846 Answers
Im trying to write a code in matlab that accepts a character corresponding to the one above buttons(keypad-0-#) and genrates the appropriate dual-tone frequency
Provides an example Server / Client written in MATLAB that utilises the ability to call Java inline to perform message communication using TCP/IP.
Importantly it does not require any pre-compiled DLLs or force you to compile some MEX c-files. Nor does it require any additional toolboxes Its all contained within the .m files.
To use the example:
- Start 2 instances of MATLAB
- in the first execute the following:
message = char(mod(1:1000, 255)+1);
server(message, 3000, 10)
- in the second execute the following:
data = client('localhost', 3000)
Aug 20, 2013 | Computers & Internet
Tip
How to Protect PC from Overheating?
Laptop over heating which is also known as Thermal Overload.This is mainly due to excess usage of CPU(More than 60%) for a long time.
To check CPU usage Right click on Task Bar>Select Start Task Manager>Performance.
or
Shortcut Ctrl+Shift+Esc
If your CPU usage is more than 50% you need to close some applications which are using 20++% CPU.
To check application which are using 20++% CPU
Right click on Task Bar>Select Start Task Manager> Processes
Search in this dialog box for programs which are using 30++% CPU
You need to close this application to prevent PC from over heating.Actually %age usage indicates load to CPU by the application.If load is to much CPU is to processes at faster speed which in turn increases temperature of CPU.
To close the program select the program,and select End Process.
If didn't found any program using 30++% CPU in this dialog box.
Select Show process from all users. and search in this dialog box and close the program.
Caution:some times your system also uses 30++% CPU inn some processes like anti virus scanning,at this if you closed the program your PC may shutdown.At this time you need to restart the PC.
This usually happens for out dated anti virus or incompatible programs.
There are some other factors like Graphics Properties and Graphic Memory,Display size, Processor type,etc.At this time its better top use a cooling pad.
Some program like camera drivers,Simulation softwares,games uses 50+% CPU.This is common these programs need to process large amount of data at short interval time which increases CPU usage but this is normal.
The processors properties are tested at 140*c so no need to worry.If the CPU exceeds the limited temperature PC will shuts down automatically,and after cooling you need to start the PC.
Thank you...:)
ANY SUGGESTIONS...?
on Feb 16, 2011 | Computers & Internet
Is high CPU usage will make battery life reduction?
Anything that requires more activity from your CPU will shorten the battery charge. It is eating power. I am not sure about "Magician".
Jan 13, 2012 | HP Computers & Internet
Does android fully related with java??????????
Hello and Welcome to FixYa!
If you are asking that the Java JRE is compatible with the android environment then this is an open question, Android is far more powerful than Java. Although Android will ship with a set of core applications including an email client, SMS program, calendar, maps, browser, contacts, and others. All applications are written using the Java programming language.
Android apps are also programmed in Java, there is also a news about Mobile software company Myriad Group announced J2Android, which will make it possible for Java-based mobile applications to run on Android-based phones.
The J2Android tool converts existing Java applications, including games, to run on Dalvik, which is the virtual machine used on all Android devices.
If this was what you were asking about, Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Jan 03, 2011 | Google Computers & Internet
My mouse pointer occasional freezes, it's not about drivers I uninstalled them, logitech mx 500. This happens when I start java program. It only then. Many people had this problem but non of them knows...
mouse cursor is one of the first things to start having problems when the system is taxed. if you are getting high cpu usage and high memory usage, that would cause crazy stuff with not just the mouse cursor to happen. next time you get a chance, pull open task manager. (right-click on taskbar) then start the Java app that you are using. look at task manager and see what is using a lot of RAM or CPU.
I've seen something similar before, where i have had to remove all previous versions of java. and re-install it..
Aug 07, 2017 | Logitech MX500 Optical Wheel Mouse USB...
What is the purpose of java
high-level programming language developed by Sun Microsystems. Java was originally called OAK, and was designed for handheld devices and set-top boxes. Oak was unsuccessful so in 1995 Sun changed the name to Java and modified the language to take advantage of the burgeoning World Wide Web. Java is an object-oriented language similar to C++, but simplified to eliminate language features that cause common programming errors. Java source code files (files with a .java extension) are compiled into a format called bytecode (files with a .class extension), which can then be executed by a Java interpreter. Compiled Java code can run on most computers because Java interpreters and runtime environments, known as Java Virtual Machines (VMs), exist for most operating systems, including UNIX, the Macintosh OS, and Windows. Bytecode can also be converted directly into machine language instructions by a just-in-time compiler (JIT). Java is a general purpose programming language with a number of features that make the language well suited for use on the World Wide Web. Small Java applications are called Java applets and can be downloaded from a Web server and run on your computer by a Java-compatible Web browser, such as Netscape Navigator or Microsoft Internet Explorer.
Apr 01, 2010 | Computers & Internet
What is the difference between Java editor and Java software?
java editor is a text editor which probably understands java language synthax and can automatically call java to compile your code.
Java software is a program written in Java programming language which is interpreted/executed by JVM(JAva virtual machine) on a target computer.
Your question is a rough equivalent to : What is a difference between typewriter and a recipe book written in English language
Jan 21, 2009 | Microsoft Windows Vista Ultimate Edition
Unable to View Java Applet
"load: class JFI.class not found."
Based on the console output, it means that it cannot find the java applet class. In other words, the applet is missing on the server side. There is nothing that you can do about it, unless you know the person who created the applet. Good luck :)
Dec 23, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Task Manager/CPU Usage
first thing scan ur pc..it may be infected by viruses
and check usage
Sep 30, 2008 | Microsoft Windows Xp Home Edition Sp2...
Going between PCs and MACs.
What drive are you speaking about.
PCs and Macs (assuming you are speaking about a PPC architecture machine-- older-- not the newer dual core Intel processor machines capable of running Windows) run on different code due to the different fundamental architecture of their respective central processing units (CPU's). PC software will not run on Macs and vice versa. Exceptions to this rule would be software written using a platform independent language such as Java (open office is an example of such software).
That said, you can transfer any data that you have on your PC to the drive on your Mac. Unless you have an Intel dual core chip, however, or the software is written in Java or the like, it will not run on your Mac. It will just sit there, nicely stored, waiting for you to transfer it to a machine that can understand it.
Feb 20, 2008 | Seagate (ST660712URK) 6.0 GB USB 2.0 Hard...
Microsoft Windows XP Professional Logo
323 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
