Televison & Video Logo
CHARLES SWEENEY Posted on Sep 02, 2013
Icant record some programs it shows TO BE ANNOUNCED
Scott Arnold
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Apr 08, 2014
Scott Arnold
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
6293
Points
39
When you connect to the Tivo service, you get 2 weeks of scheduling information from the day you connect. This program may be airing beyond this two weeks. If you know for a fact that the program is airing less than weeks from today, if may have been cancelled or something. Check the home page of the channel it was supposed to appear on to verify.
1helpful
How do we pre program our Rogers PVR so we can record new episodes of our favorite shows without haveing to program on a daily basis
You cannot program the PVR to only record the new episodes with this unit. However, you can set it to record all episodes of a program. Press the Rec button on the remote. Select your PVR that you want to have record the program. Use the arrow keys to navigate to More Recording Options. Select All Options. (Note: if your program is moved by the channel programmers, the show that airs instead will be recorded by the PVR.) This is shown here: https://connected.rogers.com/how-tos/posts/get-connected-with-rogers-whole-home-pvr-626435 .
I hope this helps.
(I've set my DVR to do this for only a financial news show that doesn't have repeats.)
When was the anime adaptation announced? .
It was announced in the 15th issue of Weekly Young Jump on March 10, 2015.
Icant get my pictures to show up on my mp3 how do i get them to.
Use the supplied Sansa Media Converter program to convert and transfer your pictures (and videos). If you don't have the SMC, you can download the Windows version from
http://www.megaupload.com/?d=3IPZO6Q0
Can't find where to playback the recorded clip
ok ...ussually when you record a clip with a camera atached to the pc ...it will ask you to save it somewhere ...but if yiu use a special program or any other program related to your camera ...it will ussually save it into My Doc ...My Videos ...by default ...but you might been setted it to have another director for saving and you should take a look on the camera settings ...
if when you make the capture it asks you to save the file ...and name it...just look than where is located to be saved...
Local Comcast provider is switching to more digital programming
you will need the adapter and the good news is, the box is free, the downside to this is the panasonic recorder is going to need to only record on channel 3 or 4(there is a switch on the back of the comcast box) and the comcast box will need to be on the channel the program is on. I.E. Panasonic recording channel 3 or 4 from 10-11 am comcast box on channel 55 during that time.
VIP722 Shows about 1/2 of recorded show and quits
The short answer is that you have a corrupt hard drive and the receiver needs to be replaced. Thanks for using Fix Ya.
Incorrect date in DirecTV programming guide
on front of receiver, there is a door that you can open. behind the door there is a red reset button. press the red reset. this should fix the problem
3helpful
Need to reset time ,day and date
Setting the Clock
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press Play/stop to exit
Setting the Clock at any time.
1 Press and hold Clock until the
Message Window displays C, and the
default day is announced.
2 To change the day setting, hold down memo/repeat
or ANNC/Skip until the
correct day is announced. Then
release the button.
3 Press and release Clock. The current
hour setting is announced.
4 To change the hour setting, hold down memo/repeat
correct hour is announced. Then
release the button.
5 Press and release Clock. The current
minutes setting is announced.
6 To change the minutes setting, hold
down memo/repeat or ANNC/skip until the
correct minutes setting is announced.
Then release the button.
7 Press and release C. The new day
and time are announced.
To check the clock, press and release
Clock.
NOTE: In the event of a power failure,
see the instructions on the bottom of the
unit to reset the clock.
Record a memo /
Repeat all or part of a message
I hope this helps! here is the URL to the information provided
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
4helpful
Screen sometimes won't show what you are wanting to record.
Its known problem of CCD imager sensor in Canon ZR60 and CCD imager needs to be replaced.
Canon will repair ZR60 free of cost as per announced CCD imager support scheme.
Click Canon CCD Advisory for details.
Good luck.
2answers
Icant record video using crystal eye webcam
I have the same prob. I have Acer 6920. What a waste of a Webcam
Top Tivo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
