Hi I got installed bosch 16plus panel 10 months ago but I didn?t have the electric garage door back then and I do have one now but I just want to know how to connect my garage door to the panel so I can use the alarm key fob to open the door. Which output of the panel is supporting 2 pear cables coming from garage motor out put? Please help Thank you
  • 19,396 Answers
Bosh does not make available for online use any documentation for security system 16pluscc100.
You can contact the Bosch Technical Support Team based in Sydney EST 8am to 7pm on 13000 BOSCH (that's 1300 026 724). They will follow wiring setup step by step.
Posted on Apr 13, 2009
Craftsman model 139.53918d. Why doesn't it turn on lights when garage door is opened or closed?
Free Craftsman Garage Door Opener User Manuals ...
homeappliance.manualsonline.com > ... > Household Appliance Craftsman
Products 1 - 50 of 60 - Craftsman Garage Door Opener 139.53515SR - I/2HP.Craftsman Garage Door Opener User Manual. Pages: 0 Saves: 0. See Prices
Aug 24, 2015 | Building Materials
Garage Door: How to fix single car garage door that is in raised position, on tracks but will not move using the power opener or manually?
Gary released the lift could be the rails that the rollers ride on are bent or damaged what you can try is disconnect the 4 panels and try moving top panel inside the rails slots movement to the back and force and see how it works if ok then hook up the next and try it and next try it and next try it this way you can see if one of the panels or the rail is not correct lined up until you have all 4 panels connected again or check with your house insurance and see if they will cover you installing a new garage door system.
Feb 21, 2015 | Building Materials
I have a PowerStar tankless electric water heater, model #44-557710 and it was replaced about 3 months ago. This morning I had hot water and this afternoon I do not. When I call for hot water a red light...
Call Bosch. And exercise your 10 year parts warranty rights.
Copy following link for Bosch power star manuals:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#Ariston
Check circuit breakers, fully off and then fully back on. Test if voltage is at least 80% rating plate on unit. Check that temperature dial is set correctly. Call for service again.
Don't install tankless computer that heats water. You cannot fix this computer yourself, and they are problematic for owners.
Go to Lowes right now, spend $285 and buy tank-type electric water heater, roll it into your house, and save money, since the electric tankless computer heater costs average $100 more per year to operate than tank-type heater for average family of 4.
Tank type heater can be repaired by homeowner same day for $25 using off-the-shelf parts from hardware store. And that empowers the regular guy, and gets you off the junk tankless treadmill.
Gene
Aug 03, 2013 | Powerstar Water Heaters
Does a garage door opener needs it own circuit
I think it depends on the horse power of the GDO, in most cases "no" BUT... is it sharing a circut with a washer or dryer? if so you may have a problem.
Nov 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
HAVE A GE PROFILE SIDE-BY-SIDE REFRIGERATOR ABOUT 10 YEARS OLD THAT NEEDS A GARAGE REFRIGERATOR KIT INSTALLED. IN MY UNHEATED GARAGE AND NOT WORKING IN FREEZING TEMPERATURES. TRIED A 100w LIGHTBULB...
You need to put a heat source in the fridge compartment near the fridge thermostat. Try putting a lower wattage bulb (40w) into the fridge compartment. Or even try this, take the door switch out of the fridge and short the two leads together. Tape the exposed ends with electrical tape and that should provide enough heat to keep your compressor on long enough to keep the freezer cold. Just remember to put the switch back in in the spring and summer months or you will have a real high electrical bill. Hope this helps you.
Dec 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Bosch electric oven is 5 years old. We
Either you have not refitted the door back correctly, or the door hinge springs are weak, a common problem.
This being the case, then the only solution is to replace door hinges.
Feb 11, 2010 | Bosch Ovens
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Door glass stained between the two panels
The door will have to be taken apart to get to the inside of the glass for cleaning.  Unfortunately, warranty will not cover this.
Oct 16, 2007 | Bosch HGS 245 Electric Kitchen Range
No transmitting with Raymarine Ray45VHF
Re your queries:
1. how to memorize channels?
The channels are pre-programmed that a channel number corresponds to a frequency setting. Ex. Ch16 is 156.800 . If for some reasons some channels are missing, perhaps your best course of action is to reset the unit to factory default, that way everything would be back to  normal. Master reset is performed by pressing the 16PLUS button while powering the radio. The LCD will display "CL" indicating that the memory has been cleared.
If you  want to memorize a certain channel/frequency, you can only store it as a replacement for 16PLUS assignment. Ex. Instead of Ch16 as your priority/emergency channel you want say Ch14 (156.700), you can do this by pressing the up/down key till your desired channel; press & hold the 16PLUS key for 3 seconds or until you hear the confirmation beep that your desired channel has been memorized in the memory as the new 16PLUS.
2. Why I cannot transmit?
There could be 2 possible reasons:
2.1 You are transmitting on a channel that has been assigned as receive only. Examples are the weather channels, Channels 1,2,3,  also 70,75,76, and possibly others.
2.2 Your TX module/circuitry has a problem. More often it is the finals that gets burned.
3. When i use the PTT Channel 16 is automatically set ?
The mic has an identical 16PLUS button (similar to the radio's front panel). If you pressed the PTT switch on the side and the radio switches to Ch16 (as if you pressed the 16PLUS button on the front) then you have a wiring problem from the mic to the radio. Possibly a shorted or open connection.  It is also possible that you have a break in the small PCB (in some versions) inside the microphone.
The user's manual can provide a more detailed instruction.  It is available at the RayMarine website and the link is >
http://www.raymarine.com/SubmittedFiles/Handbooks/Legacy_Handbooks/communications/RAY45MANUAL.pdf
Hope this be of some help/idea. Post back how things turns up or should you need further information.
Good luck and kind regards.
Oct 13, 2007 | Raymarine Ray45VHF (53 Channels) 2-Way...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
