Can not acess router setup page or router, updated the firmware and lost router. power light flashes and it knows when something is connected to it. port lights come on when rj45 is connected, but it is useless. Linksys Router BEFSR41 ver 4.2 wired Junk or can it be saved??
  • 432 Answers
Should be a pin type button on it somewhere that you can use a paper clip on to hold it down for 5 to 10 seconds and let go whilst it is powered on.
If that does not reset it then you might have to use telnet or an ftp client to upload the correct firmware in binary mode.
Posted on Apr 13, 2009
Belkin N300 f7d2401 v1 firmware update failed
expert can help you resolve that issue over the phone in a minute or two
Apr 02, 2014 | Computers & Internet
Link failed and flashing light
      it sounds like you have locked the Router into Firmware Flash mode by incorrectly performing the reset steps which are :
      To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a
      paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
      Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
      If however, one presses and holds the Reset button while it's off, then turns it ON, then it will start the flash process and flash the power light orange.
      To recover, you will need to re-flash the Router.
      Here is the D-link support page to find your firmware, you will need to find the correct "version" of the 615 you have and download that file, (you will need to un-zip it,) then follow these steps :
        1. Disconnect the power cable from the router.
        2. Open a web browser and type in the URL http://192.168.0.1/ but DO NOT PRESS [enter] or the [GO] button yet.
        3. Press and HOLD the [reset] button on the router and connect the power cable. Continue to hold the [reset] button for about 10 seconds, then release.
        4. Now click inside the address bar of the browser and press [enter] or the [GO]. The "Emergency Room" Updating Firmware screen should display.
        5. Browse to and upload the DIR615_v4.11_B02.bin image file.
        6. When you see the message "IMAGE UPLOAD SUCCESS", the flash will begin to be erased and re-written.
        7. Use your browser to again connect to the router at http://192.168.0.1/ or press [F5] and refresh the page.
        The Dlink setup screen should load. If not, you did something wrong. Go back and try again.
Aug 31, 2012 | D-Link DIR-615 Wireless Router
My WRT54GS router is not connecting to the net
I think you don't need to upgrade the firmware.
The router might have lost the connection to the modem.
You can try to reset and reconfigure it. Or you can also try to upload or re-flash the same firmware on your router.
Connect the computer to the modem and make sure that you have active internet through the modem.
Connect the modem to the router and computer to the router.
Open the setup page of the router and reconfigure it manually.
See Setup Linksys router
Jan 05, 2012 | Linksys Computers & Internet
My WBR-1310 keeps losing connection every 10 mins or so. Is there a fix I can download to my router? (like an update or something)
I got your issue, since your facing the frequent disconnection in the internet connection,
ftp://ftp.dlink.com/Gateway/wbr1310/Firmware/wbr1310_firmware_104.bin.
Please download the firmware using this link and log into the router setup page of DLink with 192.168.0.1 and update the firmware
I'm sure this will help you to fix the issue.
Thanks & Regards,
Prema
Oct 09, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
I have a Netgear wgt624 for 2 years now then all of a sudden it doesn't work anymore. I tried resetting and then reloading setup. The lights just flash on and off and will not connect to internet. Is there...
You can perform a firmware update on your router. Please go to netgear website http://netgear.com and make sure to select the exact model number and version of your product. Download the latest firmware for your product and proceed with the firmware update.
If you need assistance on doing this, you can call their support hotline at 1888netgear.
Cheers,
KJ
Jun 18, 2010 | NetGear WGT624 Wireless Router
Can't keep steady connection while surfing
check and update the firmware version .
->open the router page and check the firmware version and do a firmware upgrade.click wan set up under advanced menu to upgarde firmware.
or
->go to my.netgear.com and at the left select your product and find the latest firmware and update it.
Hope this solution resolves if not reply me ll help you
Mar 23, 2009 | NetGear RP614 Router
Green Power light flashing
Hi, Have you tried a hard reset? Your model has a small reset button at the rear between the Internet/WAN connection and one of the antennas (Press for 10 seconds +). Also flashing power led is an indicator of firmware problem which might have been caused by a failed firmware upgrade/update. Instruction on how to correct this problem is also included in the firmware upgrade/update. A more detailed instruction is in the User Manual. With regards to firmware update/upgrade , pls be reminded that firmware is very version specific. To locate the version number, you have to look underneath the unit and download the appropriate firmware from LinkSys website. (http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859878881&packedargs=sku%3D1115416826220&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7888126220B03&displaypage=download) The download is a zip file which you have to extract to a folder. The .bin file plus instructions as well as specific instructions on how to make the power led stop flashing. Hope this works out for you. Pls post again how things turn up. Good luck and kind regards.
Jul 28, 2007 | Linksys BEFW11S4 802.11b Wireless...
Computers & Internet Logo
369 people viewed this question
David Payne
David Payne
