Question about Lexmark C500n Laser Printer
Vertical streaks My Lexmark C500N prints black and white without a problem. When I print colour, the page has vertical streaks, almost like strands, all the way down the entire page... HELP!
  • 1 more comment
  • gadow Nov 10, 2008
    I own a C500 and the same thing happens. Black and white OK. Any printing done in colour has vertical streaks all the way down the page. Printed out a page with a blue, yellow and magenta blocks. Yellow was fine the other 2 streaked. Maybe there is some sort of build-up of gunk somewhere?
  • Goede Dec 08, 2008
    same thing happened to me
    Did you solve the problem in the mean time ?
  • richmohr18 May 08, 2009
    Same problem here.......it's frustrating that my cheaper printer gives me better results :(
    Problem Solver:
  • 9 Answers
The toner forms small lumps and get stuck on the doctor blade of the cartridge. Where there are the lumps it blocks the toner from getting on the roller. Removing the doctor blade and cleaning it with a soft cloth and alcohol can solve your problem.
Send me a mail at [email protected] if you need further help in doing it.
Posted on Mar 01, 2008
  • 64 Answers
This sounds like a damaged/faulty cartrigde. run three pages off with blocks of colour one page in yellow, one in blue and one in as close to magenta as you can get. depending which page you get streaks on this should tell you which cartridge is faulty.
Hope this helps
Pete
Cops
[email protected]
Posted on Oct 10, 2007
6ya staff
SOURCE:
Vertical white skreaks when printing
Check the remaining service life of the drums, also check the condition of your transfer belt. It is most likely your problem is one of those two elements.
Oct 07, 2014 | Lexmark C543DN Laser Printer
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
I have a Lexmark 1200 printer. Colour promlems
It could be that the cartridge has become dry.
you have to try several head cleans using the printer software and if that doesnt help then the cartridge needs to be replaced.
Nov 03, 2009 | Lexmark Optra Color 1200 Led Printer
C500n color problem
Try using another magenta/yellow cartridge.
Draw 4 rectangles colouring them 100% C, M, Y, and K and print.
Check the print and see which colour print is not appropriate
Oct 14, 2007 | Lexmark C500n Laser Printer
Print quality Epson C1100
It sounds as though a cartridge is faulty. To determine which one, the easiest way is to run a page of text/block of colour through in yellow then cyan then magenta. which ever page comes out with the streaks on it will tell you which cartyridge to ditch and replace. Hope this helps Cops [email protected]
Oct 10, 2007 | Epson Aculaser C1100 Printer
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Steve
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Minolta 2300DL Printer - black streaks
Hey Chuck, Any chance you can post a scan of one of the faulty pages ? This will make it easier to assess the fault. Print off about 10 pages of a page that is affected by the lines. Look at each page and see if you can detect a recurring pattern over any of the pages. If there is a pattern, chances are it is probably the PCU that is marked.
May 20, 2007 | Minolta magicolor 2300W Laser Printer
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
Without actually seeing a print sample or the machine, my bet would be on the black print cartridge. Even though it reads a an acceptable level of toner, the cartridge itself sounds like it has developed a proble. 1. It's the most obvious 2. It't the cheapest place to start. If it does not correct the problem, you can still use it later. 3. It's the problem in about 80% of these types of cases. 4. I know it should be fine, but if things didn't go wrong, I wouldn't have a job! Let me know. If not we'll investigate further. Ed
Lexmark C500n Laser Printer Logo
593 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
