Question about Kenmore 57029 Side by Side Refrigerator
Kenmore side byside refrigerator
My kenmore refrigerator is making a loud humming noise, so loud that we have to turn it off. 2 weeks ago it stopped allowing water to flow. Do you have any idea what could create these problems??
  • deb2007 Sep 11, 2007
    Thanks for the quick response, i will start there :)
  • 42 Answers
Maybe you have some sort of a blockage in the pipes or the water cooler has an electronic fault and mabye needs replacing. Ask an expert such as a plumber. I'm glad i could help. Good luck!
Posted on Sep 11, 2007
SOURCE:
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
My Kenmore side-by-side refridgerator is making a loud humming noise.
Has anything changed in the cooling? Can you locate the model number on your refrigerator.The noise is coming from under or inside the refrigerator or freezer? Let me know those few things and we will find out whats going on, Thank, Sea Breeze
http://servicepartstec.blogspot.com/
May 17, 2009 | Kenmore 57029 Side by Side Refrigerator
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
PROBLEM WITH HUMMING NOISE
Sounds like your compressor is having a hard time to start
Replace Relay/Overload combination that should do it let me know if you need additional assistance email me at [email protected]
Apr 18, 2008 | Maytag MSD2454G Side by Side Refrigerator
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
212 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
