Question about Dishwashers
Whirlpool dishwasher, rotary selection switch PROBLEM tablets are not dissolving. with any of the normal selection pgb
  • 1 more comment
  • brannigans Apr 13, 2009
    if i pull out the dishwasher is it easy to access and clear out the valve ??
    pgb
    will be accepting access through kick plate at front looks problematic. likely i will need a visit from repairman . your help very detailed am accepting now but there maybe a backup question?
    very good
  • 1,170 Answers
I think the problem is with your water valve of the dishwasher. It could be blocked with sediments/damaged and as a result it will only let water in once and there won't be nothing for the rest of the cycle. This might have happened with your dishwasher, and hence the water intake may not be sufficient enough to dissolve the tablets completely.
As the dishwasher is programmed, insufficient water intake may trouble the rest of the program functions as the solenoid switch on the value will sense that there is no water and hence stop all the further programs. In that case, It may not be with the rotary program selection switch. So before going for any replacement of the rotary program selector, confirm that the water valve is working properly.
Here is a picture of water valve with solenoid switch (orange colour):
whirlpool dishwasher, rotary selection switch
Hope I helped with the repair of your problem.
An Accept is how I get paid
And a positive feed back tells me how I did with the repair
Arjun.
Posted on Apr 13, 2009
  • Arjun Komath Apr 13, 2009
    Testing a water inlet valve
    Note:
    Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
    Locate your dishwasher's water inlet valve. It should be located behind the lower kickplate panel in either the right or left corner. There will likely be two screws either on the top of the panel, or on its bottom. Remove these two screws, and then remove the kickplate. On some dishwasher models, the door has to be opened in order to gain access to, and remove the kickplate's screws. Close the door before you remove the kickplate panel.
    You will be able to identify the water inlet valve by the hoses that connect to it. There will be one hose feeding water from the house to the water valve, and another hose leading from the water valve that carries water away. Now is a good time to inspect your dishwasher's hoses, to make sure they aren't responsible for any water flow problems. Make sure the hoses are securely connected to the valve. Also check to make sure there are not kinks in the hoses. Kinks can impede the flow of water.
    There will be two wires connected to the water inlet valve. If your dishwasher's water inlet valve has two solenoids, then there will be four wires. Label the wires so that you will be able to correctly reconnect them later. The wires are connected using slip-on connectors. Grasp the connectors and pull on them firmly in order to disconnect the wires from the valve's terminals. Do not pull on the wires themselves. You may want to use a pair of needle nosed pliers to help you.
    Use your multitester to test the valve for continuity. Set the device to the ohms setting x 1. Touch each of the meter's probes to a terminal. If you receive a reading of infinity, it means the valve's solenoid is faulty and the valve needs to be replaced. If your valve has two solenoids (four terminals), test the second pair of terminals in the same manner. If either pair of terminals receives a result of infinity, replace the water inlet valve.
    You do not have to remove the water inlet valve from the dishwasher in order to test it. Just make sure power is not getting to your dishwasher before you conduct the test.
    Interestingly enough, it is entirely possible for your water inlet valve to pass the continuity test and still need replacing. This is because sometimes the valve itself is faulty, but its solenoids are not. For instance, a leaky valve may pass the continuity test, but because it is leaking, it should be replaced anyway. The same applies to valves that are filled with debris. The debris may be what is causing the valve to not function properly. If you are unable to clean out a debris-filled water inlet valve, you will have to replace it.
    An Accept from you is how I get paid.
    And a positive feed back tells me how I did with the repair.
    Arjun.
    Replacing a water inlet valve
    Note:
    Disconnect the power source to your dishwasher before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
    You will be able to identify the water inlet valve by the hoses that connect to it. There will be one hose feeding water from the house to the water valve, and another hose leading from the water valve that carries water away. Now is a good time to inspect your dishwasher's hoses, to make sure they aren't responsible for any water flow problems. Make sure the hoses are securely connected to the valve. Also check to make sure there are not kinks in the hoses.Turn off your dishwasher's water supply so that you can remove the hose attached to the water valve. The water supply turn-off is located beneath your sink. There will be a knob to turn or a lever to press down on. Alternatively, you can turn off the main water supply to your house at the main valve.
    Place a container below the hose to catch the water that falls out when you disconnect it. The hose that brings water to the valve will most likely screw in place like a garden hose. The hose that carries water away from the valve is probably held in place with a clamp.
    The valve itself will be secured to the dishwasher using at least two screws, but maybe more. Remove all the screws you find that hold the valve in place. Now you can remove the valve as well.
    Install your new water inlet valve in the same location where you just removed the old one. Secure it in place using the screws removed from the old valve. Reconnect the wires and hoses. Replace the lower kickplate panel and restore power to your dishwasher.
    Arjun.
Dishwasher tablet does not dissolve so crockery not clean
Are you using a rapid wash program, ie 30 minutes total?
if you are, put the tablet in the cutlery basket, not the soap dispenser. The wash time is very short on the 30 min program, so putting it in the cutlery basket gives it more time to dissolve.
Other problems might be problem with water level, (should be just above the filter but below the lip of the wash tank), pump not working or the spray arms not turning - (check the angled jet at the very end of the spray arm for blockage by food particles).
Feb 04, 2018 | Dishwashers
Seriel PAA41010 dishwasher does not dissolve tablets
Tablets dissolve in the water, normally by the drawer opening and the tablet falling out into the wash. Is the door sticking (tablet door not loading door) or is the wash arm not spinning freely or blocked? These can interfere with the cycle
Nov 02, 2017 | Dishwashers
Dirty dishes
Some brands of powder do not dissolve properly, also it is not recommended to use the tablet type powder blocks as they don't work well and cost more than normal powder.
Mar 10, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
Tablet is not dissolving from my dishwasher drawer
If it drops to the bottom when you open the dishwasher door - your soap dispenser is blocked by the rack or an utencil protruding from the rack. Make sure both racks slide in all the way to the back. (hint: check the middle spray arm inlet, make sure it aligns with the tube on back.
Good luck)
Oct 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Dishwasher detergent won't dissolve
Recommend you stop using the gel and switch to a brand name powder - like Electrosol or Cascade. Never use gel, gel packs or tablets in any dishwasher. Avoid untra-cheap, generic powders.
If problems continue, a service call, with them checking that the heating element is working is the follow up step.
Good Luck!
Apr 02, 2009 | Whirlpool DU930PWSS Stainless Steel...
Dishwasher opens tablet door but tablet is not used
are these self desolving tablets with covered in plastic film?  If they are use another brand of tablet, or turn the heat up on your water heater as it is set too low.
Had the same problem
Mar 15, 2009 | Dishwashers
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
