Question about Sharp AR 201 Copier
Error Code F1 on Copier Sharp AR201
I Mr A. Raheem from Mauritius & I have a Sharp copier model AR-201. It was working properly, as it was on power saving mode, i press enter, suddenly i heard a noise, then F1 code appears. I can't do any photocopy now. I switch off then On problem persist.
  • 95 Answers
F1 means "shifter Motor Trouble". The motor that driver the shifting mechanism at the paper exit side is not functioning. The motor could be bad or there may be something binding the motor up. Take a real close look at the exit unit (where the paper comes out of the machine) and see if there is anything in the way of the shifter. It could also be a bad board issue - sending the wrong signal to the motor... or possibly a bad home position sensor for the shifter.
You could try taking the shifter unit out for a closer inspection - make sure its properly installed.
Hope this helps.
Posted on Apr 14, 2009
SHARP AR 201 - ERROR CODE H4
# * C * den start batan the copier will re-start
Oct 07, 2010 | Sharp AR 201 Copier
Error Code
A error code F1-09 deals with the finisher of the copier. Have the bins gotten stuck or got something in it's way when moving up & down. I would turn the copier off and unplug the finisher from the copier, 1 screw holds connector in. Then I would turn it back ON and see if the code is gone, if so reconnect the finisher and you should be good to go...
Jun 11, 2009 | Sharp AR 201 Copier
Error code U2 on a AR201 copier
Hello sir; This error code it can be reset folloe the instruction;
1, press "clear", "interupt", " 0 ", "interupt"
2, enter 16 then press start.
Jun 01, 2009 | Sharp AR 201 Copier
Sharp copier model SF2530 F1 flasing and copier
Hello sir; F-1 is sorter problem, did you connect sorter with machine, turn power off and check th connecter .
May 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR201 COPIER
Hey Robert,
Sounds like it could be in need of a maintenece kit. The ghostinf is usually caused from the fuser or transfer roller. And that would also apply to the band down the page.
Feb 13, 2009 | Sharp AR 201 Copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
Error Code F1 -57, and clues, solutions? Thanks, Don
F1 errors have to do with the finishing section. My code list doesn't go as high as 57.
Check to see if the finisher is connected properly to your copier. You should turn your copier off while inspecting it.
Jul 22, 2008 | Sharp AR-C160 Color Copier
AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Apr 28, 2008 | Sharp AR 201 Copier
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Photocopier Sharp ar201 not working
L6 - Polygon Motor Lock: The lock signal (the specified rotation speed signal) is not supplies within the specified time (about 6 seconds) after starting the polygon motor rotation. LSU connector disconnection of harness disconnection in the LSU. Replace LSU.
Aug 01, 2007 | Sharp AR 201 Copier
Sharp AR 201 Copier Logo
200 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
