Question about Cameras
My Minolta X-700 has no LED's lighting up and film advance lever is stuck. New batteries fitted and get beeps but problem stays the same. Any advice greatly appreciated. Derek.
  • Derek J Pollard Apr 14, 2009
    Excellent advice. I am quite sure that this is the problem but I cannot source the 220uF 4volt caps here in South Africa. So I will see if I can pirate parts off an old low voltage power supply.
  • 1,170 Answers
There is a capacitor that goes bad in the X series. You can find themon eBay. A simple soldering job. One is in the bottom of the camera and the other is at the top.
Here is the picture regarding disassembling the top :
Here is the picture regarding disassembling the bottom :
Picture of electrical parts :
The frequent electronic failure of the X700 seems to be a simple failure of two 220uF/4V capacitors.
Simply replace them and it works again !
Picture of location of capacitor 1 (BMy Minolta X-700 has no - 744ab93.jpgbr />744ab93.jpg
Picture of location of capacitor 2 (Top)
Schematic of location (cap 2)
Here is a picture of another camera with same problem :
Here is a very detailed guide of the parts and its dissembling.
http://twid.de/x700/disas.html
Hope I helped with the repair of your problem.
An Accept from you is how I get paid.
And a positive feed back tells me how I did with the repair.
Arjun
Posted on Apr 13, 2009
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
atdlee@netzero.com
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
The the lever on my minolta to advance the film is jammed, how do i get it unstuck?
If the advanced is locked and the mirror is down, you may only need new batteries. If the mirror is up, let me know
Dec 09, 2009 | Minolta X-700 35mm SLR Camera
The film advance lever is stuck on my minolta
Here are the most likely:
A. Lever will not move on some models if the shutter is already cocked. If the shutter is cocked, and will not release with new batteries INSERTED CORRECTLY, then the most likely is this...
Two capacitors in these Minoltas die over time. If you are handy at such things, you can buy the caps, remove top and bottom covers, remove the dead caps and solder in the new ones. Don't Panic.
You can find instructions on the web for this well known issue, and you can also opt to send it to a camera repair place. Garrys camera repair in Niles, ILL does it for about $58 incl return shipping. He will also clean, lube and adjust it for ya. Something they all need eventually.
Oct 04, 2009 | Minolta X-370S 35mm SLR Camera
Film Advance levar wont work. Milnolta x-700
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Aug 05, 2009 | Minolta X-370S 35mm SLR Camera
Film Advance won't work on Minolta X-700
changing the batteries have no effect on film transport, just a coincidence. take the bottom cover off and check the white plastic gear on the film take up side of the camera. if it is broken your X700 may not be repairable as no new parts are available.
push the re-wind button in and try to charge the shutter again. remove film first. if it still just goes part way then a gear is stripped. try to find a camera repair shop that may have good used parts available.
Jul 18, 2009 | Minolta Photography
Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
Jun 15, 2009 | Minolta X-370S 35mm SLR Camera
Minolta X-9
Mar 22, 2009 | Minolta X-700 35mm SLR Camera
Advance lever jam
Yes, If you get metering lights in the viewfinder display that go out when you press the release fully to take a picture, it is the cap.
Aug 05, 2008 | Minolta X-700 35mm SLR Camera
Cameras Logo
455 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
