Question about Apple iPod touch
I reset IPOd and it says connect to iTunes I do and it does nothing so what do I do
  • 143 Answers
Try entering DFU mode.
Here is a great step by step guide to do that. http://iphonefreakz.com/beginners-guide/howto-dfu-mode/
I hope this helps,
Nathan.
Posted on Apr 14, 2009
My ipod says DISABLED CONNECT TO ITUNES
Sometimes when you connect your iPod to the computer it will do nothing.
If that's the case...keep the device plugged in and do a hard reset.
Hard Reset: Hold down the power button and home button at the same time, the device would completely shut down (Do Not Let Go) next you will see a apple symbol (Do Not Let Go) it will shut down once more and a few more seconds it will have the symbol to connect to iTunes (Now you can let go)
Restore the device as prompted on the screen.
There are times when a Hard Reset would be needed more than once.
Jun 28, 2014 | Apple iPod touch
How do i reset ipod nano 2G, I am getting nothing
To restore your I-pod, do this:
1) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software
may need to be downloaded to your computer.
2) Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that
came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes.
3) Select your iPod in the Source panel and you will see information about your iPod appear in the
Summary tab of the main iTunes windows.
4) Click the Restore button. You will be prompted with one or more restore options that may prompt
iTunes to automatically download the latest iPod Software. Use restore option 4.
Apr 14, 2010 | Apple iPod nano
Ipod won't appear in itunes. when connected to the computer, nothing happens.
1. Try another USB cord or USB cable.
2. Restrart your computer for a try.
3. Reset or restore your iPod for a try, this way can fix many general iPod problems.
4. Download and install the latest version fo iTunes for a try.
5. You may try this Daniusoft iPod transfer, it's a nice iTunes alternative that can help you upload music and video to iPod, I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well
Jan 06, 2010 | Apple Audio Players & Recorders
Ipod clasic not connecting to Itunes
trying to going in and doublue jump it or you may need to take all of them off the itunes and start over i keep 4 diiferent itouches and this has happened before so try that and see
Dec 30, 2009 | Apple iPod classic MP3 Player
When I went to turn it on it has only a white screen-nothing else there, won't sync, I've tried the 5 ways to restore and there is nothing there.
Have you attempted to reset the ipod? It sounds more like a hardware issue, but a reset may still help. Just in case you are unfamiliar with how to perform a reset i have included step by step instructions below.
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
if you can get it powered on at all with the reset, I would suggest restoring it using itunes. As before i've included the instructions below just incase you are insure on how to do this step.
How to restore iPod (ARTICLE NUMBER HT1339) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer. Download and install the latest version of iTunes if you do not already have it installed. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
If none of these steps resolve your issue, you will probably want to contact a repair service dealer of your choice. Or replace the unit all together. I hope this does resolve your issue though. Good luck :)
Apr 24, 2009 | Apple iPod classic 7th Generation
Reset because couldnt connect to iTunes now says connect to iTune
my daughter just had the same problem..........instead of taking it to apple ($$)....(connect to pc) i took the software off and store it on the pc) shut itunes off.and formatted (this will erase every thing on ipod) the ipod then reinstalled the software...............open itunes (where all her files (audio/video) reinstall files also...now its like brand new....save $$$
Apr 13, 2009 | Apple iPod MA446LL/A MP3 Player
My ipod suddenly wont mount!
The first thing you can try is unplug the Ipod from the computer. Hold down the center button while pressing down on the menu button. You should see an Apple logo appear on the screen. Your Ipod has been reset. Plug it back into ITunes.
If that doesn't work after plugging it in. You may have to restore the software in your IPod from Itunes. Make sure your songs in your IPod are on your hard drive because this will restore all of the settings back to default and empty out the memory of the IPod as well.
This system restore can be done through ITunes or by selecting the system software option from the IPod menu in the computer if you have it installed.
Option 1 should work.
Jun 09, 2008 | Apple iPod nano
I connected it to my computer however nothing shows my ipod is connected it just charges i cant restore it..
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
Apr 20, 2008 | Apple iPod nano
Itunes
have you tried to check for problems on your computer. it could be your computer may be the one at fault for not allowing you to connect to itunes.
Aug 12, 2007 | Apple iPod nano 2nd Generation MP3 Player
Apple iPod touch Logo
74 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
