It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
do you know of any sub-zero repairmen in my area,I live in Round Top NY I had a repairman from saugherties NY here twice,first time he put in some gas,second time he raised the freezer temp,that didn't help,vacuum condenser lite is still blinking & my fridge is still constantlyrunning,the door inside is often warm to touch
I also vacuumed the condenser very well....it didn't help...
I do not personally know any repair in your area, but befor you call, check the fan speed on your condenser.
Sometimes the fans get slow, but do not stop as they wear out. If it isn't spinning at least as fast as a window fan there is a problem. the vacuum condenser light is caused by high temperature in the condenser. High temperature is caused by poor airflow because the condenser is dirty, or the fan not functioning properly. The refrigerant level is very rarely a problem.
