Question about Panasonic Toughbook CF-P1
How do i make stylus work - Panasonic Toughbook CF-P1
Stylus pen using on adobe photoshop
If it is a resistive touch screen you can use anything as a stylus. To test if it is resistive touch it with a non conductive material like something made of wood or wear a glove. If it doesn't work then it is a capacitive touch screen and then you just need to buy any capacitive stylus and yes it will work. Photoshop should work fine too.
Jul 04, 2013 | HP Pavilion TX2110US PC Notebook
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Tip
Reset Epson Color Printer Counter
Many Epson Printers that reach an End of Life counter number will lock your printer down and force you to contact a Service Center.
However, this is really not necessary in all cases. If your printer is still working fine for you but the counter has locked your printer:
To download this free utility program read the agreement and then download.
Follow all instructions for download, install and usage.
End user agreement
1) This software is provided "as is" without any express or implied warranty of any kind including, without
limitation, warranties of merchantability, non-infringement or fitness for any particular purpose.
2) You are liable for all risks in relation to the quality or performance of this software. In no event shall SSC Localization Group or personally, author of this software, be liable for any damages whatsoever caused to you or the third party arising out of the use or inability to use this software. Damages include general damages, special damages, accidental damages or consequential damages (including, without limitation, loss of data or accuracy or unfitting interface for other programs, or problems with peripheral equipment).
2) You understand the risk of whole head or individual nozzles clogging in case of tardy replacing of empty cartridges, as well as risk of using hot swapping function (this include frequently cartridges replacement, or wrong deblocking of parking head on some models). You understand, that resetting the ink level counters or using ink freezer function implies responsibility to carefully watch ink levels in all cartridges and timely (as soon as You see any raw white bands, even in one color) replace cartridge.
I agree with all above statements and want to download software (v4.30)
Supported Models:
Model
Epson Stylus C50
Epson Stylus C60
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson PictureMate
Epson Stylus Photo
on Aug 31, 2008 | Laser 3115cn All-In-One Printer
I try set up phone but stylus does not work on screen what can i do?
Use button and go to tap - settings from menu, then tap your screen. Stylus will work.
Regards
Marshal
Dhaka, Bangladesh
bdman2010@hotmail.com
May 20, 2010 | Palm Treo 600 Handheld
Have an Epsom stylus color 440. will not print
I'm trying to do a print nozzle check on my Epson Stylus Color 440 printer that I have but a pop-up box say "Error, can't print". Why is this?
Oct 06, 2009 | Epson Stylus Color 440 InkJet Printer
Print server PD-301U can not work in Printer
I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to Epson's Web site, here are the Epson printers it supports (note the TX101 is NOT in the list):
  • Stylus 5700
  • Stylus 5700L
  • Stylus 5800
  • Stylus C60
  • Stylus EPL-5500
  • Stylus EPL-N2000
  • Stylus EPL-N2010
  • Stylus LQ-100
  • Stylus LQ-300
  • Stylus LQ-550
  • Stylus LQ-570+
  • Stylus LQ-1070C+
  • Stylus LQ-2070
  • Stylus LQ-2170C
  • Stylus Color 400
  • Stylus Color 440
  • Stylus Color 460
  • Stylus Color 480
  • Stylus Color 600
  • Stylus Color 640
  • Stylus Color 660
  • Stylus Color 740
  • Stylus Color 800
  • Stylus Color 850
  • Stylus Color 860
  • Stylus Color 900
  • Stylus Color 1160
  • Stylus Color 1500
  • Stylus Color 1520
  • Stylus Color 3000
  • Stylus Photo 700
  • Stylus Photo 710
  • Stylus Photo 750
  • Stylus Photo 870
  • Stylus Photo 1200
  • Stylus Photo 1270
  • Stylus Photo EX
  • Stylus Pro XL
Here is the link to page I am refering to:
http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
May 14, 2009 | D-Link DP 301U (DP-301U) Print Server
Intuos 3 Pen/Stylus suddenly stopped working (as in dead).
Will the tablet work with the mouse? If it does not, is not working is the blue LED light on. If the LED is not working try another usb port. If the mouse works go into the Wacom tablet properties from the start menu. Select the grip pen from the tools. Click on the default button to restore the stylus to factory settings. When you press the pen you should see the pressure scale rise. You can also test the eraser pressure. You could also replace the stylus tip to see if that works. From the Wacom site you can order a new stylus or tips if it is found defective.
Apr 14, 2009 | Computers & Internet
How to get Epson R300 stylus monitor to work in Vista
I have the same problem with my stylus C88. Epson never did provide Vista drivers so I have never found a way to get the Epson software to work with Vista. The print driver does work so you will be able to print but you'll have to clean the nozzle manually by pushing the button on the printer rather than using the Epson Monitor. Sorry.
Jan 25, 2009 | Epson Stylus Photo R300 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Stylus not responding
Have you tried a reset of the phone by pushing the stylus into the small hole in the bottom of the device?
Try this, and see if it picks up the stylus touches again.
Nov 13, 2007 | HTC TyTN Smartphone
Panasonic Toughbook CF-P1 Logo
55 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
