Question about Sony VAIO VGN-C140G/B Notebook
Laptop screen flickers and goes off .
Hope you can point me in the right direction.
I have a Sony Vaio (not sure of model as its at home) which developed a problem a few days ago.
The screen started to flicker and then went off.
After a lot of trying different things the summary is detailed below.
1) Running on battery all is ok except dimmer screen for power saving.
2) Plug in power adaptor and within 10 seconds the screen will flicker for a bit then go off.
3) The rest of the laptop seems to function ok as it will display on external monitor.
4) When power is removed screen will reactivate when changed back from monitor mode to laptop screen.
Many thanks in advance
Jim (Scotland)
  • Sony Master
  • 32,281 Answers
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 13, 2009
My screen is white
Sony Vaio is one of the most prominent brands of laptops on the market, and also one of the most expensive. The laptops, created by Sony, are known for their efficient processor functionality and sleek designs. While the Sony Vaio line of laptops are considered high-end, they are also prone to display problems.
Symptoms
Among the problems facing Sony Vaio laptop screens are blackouts. When these blackouts occur, the monitor turns solid black, and upon rebooting the laptop, light will briefly flash on only to blackout again. Additionally, there have been reports of an issue which causes the screen to flicker intermittently until it goes out all together. b> Troubleshooting b> Blackout displays and the continuous flickering of Sony Vaio screens can be caused by various issues taking place inside the laptop. It is not necessarily true that the problem lies within the LCD screen itself, with display issues often occurring as a result of problems with other parts of the laptop. You can test whether or not the screen is defective by connecting the laptop to an external monitor. If the display comes up normally, then the problem lies within the laptop's LCD screen. b> Parts b> If your Sony Vaio is connected to an external monitor and suddenly goes black, then the problem may have to do with the laptop's sleep button. The sleep button latch located inside the device may be jammed or broken, thus putting the screen in a permanent sleep mode until the latch is fixed. Encountering hissing sounds when the laptop is running indicates a faulty circuit board, usually damaged due to overheating. Display issues can also occur when certain parts of the laptop, such as the hard drive, have been replaced. b> Design b> Some owners have made complaints about Sony Vaio design flaws, specifically mentioning defects in the laptop's boards. Among the problems discovered after opening the laptop include burnt LCD fuses, as well as worn out circuits and internal latches. Some of these events may occur even in newly purchased units. Sony has not yet responded to various consumer complaints and has not yet issued any recalls in response to reported problems. b> Repair b> When repairing a defective Sony Vaio laptop screen, it is important that owners remain aware of the nine screws which hold the laptop cover and the board together. Not doing so can easily lead to further damage to the Vaio due to static electricity, and may even lead to a short circuit. For owners who are experienced in the area of laptop repair, parts are readily available for purchase, allowing for cost efficient repair. b> Extended desktop You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. or Click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop
Jan 28, 2013 | Sony VAIO VGN-CS204J/W 14.1" Notebook...
Power managment
Hi, A Sony VAIO PCWA-A200 is an 802.11b Wireless Access Point Router. Your post "...AC PLUGGED IN AND RUNNING ON BATTERIES...." indicates a laptop issue. To be of better assistance, post the brand/model of your laptop.
Aug 27, 2007 | Sony VAIO (PCWA-A200)
Sony vaio laptop half screen black on the right
Symptoms
Among the problems facing Sony Vaio laptop screens are blackouts. When these blackouts occur, the monitor turns solid black, and upon rebooting the laptop, light will briefly flash on only to blackout again. Additionally, there have been reports of an issue which causes the screen to flicker intermittently until it goes out all together. b> Troubleshooting b> Blackout displays and the continuous flickering of Sony Vaio screens can be caused by various issues taking place inside the laptop. It is not necessarily true that the problem lies within the LCD screen itself, with display issues often occurring as a result of problems with other parts of the laptop. You can test whether or not the screen is defective by connecting the laptop to an external monitor. If the display comes up normally, then the problem lies within the laptop's LCD screen. b> Parts b> If your Sony Vaio is connected to an external monitor and suddenly goes black, then the problem may have to do with the laptop's sleep button. The sleep button latch located inside the device may be jammed or broken, thus putting the screen in a permanent sleep mode until the latch is fixed. Encountering hissing sounds when the laptop is running indicates a faulty circuit board, usually damaged due to overheating. Display issues can also occur when certain parts of the laptop, such as the hard drive, have been replaced. b> Design b> Some owners have made complaints about Sony Vaio design flaws, specifically mentioning defects in the laptop's boards. Among the problems discovered after opening the laptop include burnt LCD fuses, as well as worn out circuits and internal latches. Some of these events may occur even in newly purchased units. Sony has not yet responded to various consumer complaints and has not yet issued any recalls in response to reported problems. b> Repair b> When repairing a defective Sony Vaio laptop screen, it is important that owners remain aware of the nine screws which hold the laptop cover and the board together. Not doing so can easily lead to further damage to the Vaio due to static electricity, and may even lead to a short circuit. For owners who are experienced in the area of laptop repair, parts are readily available for purchase, allowing for cost efficient repair. b> Extended desktop You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. or Click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Dec 13, 2012 | Sony for Sony VAIO VGN-C2S/G VGN-C2S/H...
I have soney vaio VGN-CS215J model laptop. i loose driver for touch sensor A/V controls. How can i get driver for this problem? can you give me suggestion please.
Just go to Sony home page and customer support, type the model of your laptop in the drivers download.
Hope that helps!
Nov 19, 2011 | Sony VAIO VGN-CS220J/W Notebook
I have a sony vaio vgn cs36gj and on the start bar there is a line right across the bottom that flickers every five seconds. I have my screen adjusted to the correct resolution. I have also plugged in an...
90% chances are that this is the problem with your Graphic settings.(go to your Graphic Properties and make sure that Refresh Rate should not be more then 60Hz). Change it to 60hz and restart your machine, This should resolve.
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Sep 28, 2010 | Sony VAIO VGN-CS260J/P Laptop
Display flickers on boot. then goes black
Before making any decision on whether it's a hardware failure, please try and boot from a CD or DVD (recovery disc). If it does successfully boot from an external disc - and there is no flickering problem, then the hardware parts are okay. In that case, please go to this link: http://lifehacker.com/5413223/how-to-fix-your-relatives-terrible-computer?skyline=true&s=x for more information on what to do when you can't enter into your operating system and how to fix malwares that might be causing the flickering. If you find my ideas satisfactory, please do rate me. Thanks
Jan 23, 2010 | Sony VAIO VGN-A270P Notebook
Screen won't turn on
when u power up press F8 key then enter in enable vga mode then change screen resolution to 1024*768 then apply and ok thats it.
Jun 09, 2009 | Computers & Internet
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Sony VAIO VGN-C140G/B Notebook Logo
825 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
