Question about Apple iPod MA446LL/A MP3 Player
Says improper software when I try iTunes that's what it says
What can I do to get my iPod working I resett it and now all it will do is say connect to Itunes and I did and it does nothing help please and also the reason I reset is because when I tried to get on iTunes or youtube it said cannot connect so if someone has the answers please tell me how to fix these issues
    President:
  • Apple Master
  • 688 Answers
I am assuming your ipod is a touch?
when you restored it you took the jailbreak off.
Try restoring it in itunes by using the following method:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
then restore it and you will be able to get in itunes.
Posted on May 17, 2009
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch Second Gen (8 GB,...
My ipod wont show up on the bar when i plug it in the itunes
My windows vista does not recognise my usb ipod shuffle.......?! it was fine before.tried the 5steps...the pc still does not reconginise it.
In 1 line:uninstalled the iPod firmware updater program and iTunes. Get a fresh download of the firmware app and iTunes .Try installing iTunes 4.7.1
Steps:
remove the iTunes software and iPod drivers, make sure the iPod isn't connected. Restart the computer and reinstall the software again.
When you log in, load up iTunes (wait till it's fully opened and not in a busy state)
Then connect your iPod.
May 13, 2009 | Apple iTunes
Reset because couldnt connect to iTunes now says connect to iTune
my daughter just had the same problem..........instead of taking it to apple ($$)....(connect to pc) i took the software off and store it on the pc) shut itunes off.and formatted (this will erase every thing on ipod) the ipod then reinstalled the software...............open itunes (where all her files (audio/video) reinstall files also...now its like brand new....save $$$
Apr 13, 2009 | Apple iPod MA446LL/A MP3 Player
New iPod Nano 4G won't connect to iTunes.
Hi Paige,
  • First reset the device by pressing and holding Menu & Select till the apple symbol appears
  • Next check the USB port on both the PC and ipod are clear of dust etc.
  • Download and install the latest iTunes from the Apple site.
  • Connect the ipod to a USB port directly on the back of your PC (ie, not a USB hub or keyboard etc.)
  • If iTunes recognises it (properly or improperly) and suggests an ipod software update, do this.
  • On the main ipod page of iTunes press the restore button and choose the bottom option (if it gives you any) to restore the ipod to manufacturers settings.
  • After a couple of restarts once its done it should be fine.
All the best
Sean
PiDigital
Dec 25, 2008 | Apple iPod nano
Ipod wont restore.
have you tried resetteing it, by holding down the home and on/off button for abour 8 seconds? try that
Jul 25, 2008 | Apple iPod touch
30 gig iPod after plugged up to computer completely stopped working
you said its not responding to the reset trick nor turn on or charge, plug ipod to pc via usb plug. go to my computer find the ipod it shoudl show up as a hard drive. if it is there click on it and copy the ipod software to the pc (non music). now format the ipod (you was going to erase it any way) once formatted copy the ipod software from pc, back to ipod. this should make feel and act as new again. download and updated version of itunes and put your music onto ipod. feel free to rate this suggestion
May 11, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod feezing when connected
Have you tried any of these, if not do.
I hope you tried to reset the ipod.
You can try restore :
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Good Luck.
Live, Love, Laugh.
May 09, 2008 | Apple iPod MA446LL/A MP3 Player
APPLE IPOD VIDEO 30 GB WHITE
You can try to reset :
http://support.apple.com/kb/TS1382?viewlocale=en_US
http://support.apple.com/kb/HT1320?viewlocale=en_US
If you still have the problem you can try restore :
For Windows:
For Mac:
Or
Try to reinstall
Good Luck.
Live, Love, Laugh.
May 05, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
43 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
