Question about Dell Computers & Internet
I need to know the pins layout on the CPU fan connector. It is a DELL desktop serial number 7BP5H1J model DHS computor. ( Intel P4 processor ) Thanks for helping, Marc.
  • Dell Master
  • 1,183 Answers
Hi
The GX 280, that you have come in various chassis design. You can select from the follwing link wich chassis you have
http://support.dell.com/support/edocs/systems/opgx280/en/ug/index.htm
The corresponding link for the pinout can be found at
http://support.dell.com/support/edocs/systems/opgx280/en/ug/replbrd0.htm
Thanks
Proton
Kindly rate the solution, if it helped you to solve the problem
Posted on Apr 13, 2009
I READ SOMEWHERE ON THE NET THAT YOU CAN INCRESE THE MHz OF A CPU BY CUTTING A PIN OFF THE CPU. IF THIS IS TRUE, DOES ANYONE KNOW WHICH PIN TO CUT OFF FOR A DELL DIMENSION 4300 DESKTOP WITH A 2.0...
Uh, no.
At least not for the Intel Pentium 4, sSpec - SL6GQ, SL6S7, SL5YR, SL5ZT, SL66R, and SL68R models.
(Northwood Core, and based on the 130NanoMeter architecture)
http://www.cpu-world.com/info/Pinouts/Pentium_4.html
478 pins. Which one would you remove?
The method is to change the Front Side Bus frequency rate. ('Speed')
This is done in the BIOS Setup utility, IF the utility has this option.
Or,
1) Change the Voltage.
2) Change the FSB
3) Change the Multiplier
ABIT motherboards had an option to bypass protection of the Pentium 4's.
Some motherboards have a Soft CPU option for this.
Removing a pin? No, bad juju.
Regards,
joecoolvette
Jan 21, 2012 | Dell Dimension 4300 PC Desktop
"CPU fan stopped working" message,
You can order a replacement fan from HP. Search for replace parts under your model computer when you go to HP's web site.
Aug 09, 2011 | HP Pavilion p6370t PC with Intel R Core TM...
I have a D102GGC2 motherboard with intel pentium 4 processor 524 , LGA775 Pkg 3.06GHz,.So please tell me about related drivers and chipset and how to download from intel site ?
Link for download of drivers etc. is at the bottom. Choose Operating system, etc and what you need (drivers, software, etc.).
I don't know if it will come to you as a hyperlink or not. If not you will have to copy and paste or type in address bar as one long string.
Manufacturer:
Intel
Part Number:
BOXD102GGC2
General
Product Type
Motherboard
Form Factor
Micro ATX
Width
9.8 in
Depth
8.6 in
Compatible Processors
Celeron D ,
Pentium 4 ,
Pentium D
Processor Socket
LGA775 Socket
Multi-Core Support
Dual-Core
Chipset Type
ATI Radeon Xpress 200 / AMD IXP 450
Max Bus Speed
800 MHz
Storage Controller
ATA-133,
Serial ATA-150
Power Connectors
4-pin ATX12V connector,
24-pin main power connector
Processor
Installed Qty (Max Supported)
0 ( 1 )
Memory
Supported RAM Technology
DDR2 SDRAM
RAM Installed ( Max )
0 MB / 2 GB (max)
Supported RAM Speed
PC2-3200,
PC2-4300
RAM Features
Dual channel memory architecture
Video
Graphics Controller
ATI Radeon X300 Shared video memory (UMA)
Audio
Audio Output
Sound card
Audio Codec
Realtek ALC861
Compliant Standards
High Definition Audio
Telecom / Networking
Networking
Network adapter - Realtek RTL8101L - Ethernet,
- Fast Ethernet
Features
BIOS Features
ACPI support,
SMBIOS support,
Rapid BIOS boot
Hardware Monitoring
System voltage,
CPU fan tachometer,
Chassis fan tachometer
Sleep / Wake Up
Mouse wake up,
Keyboard wake up,
Wake on USB port,
Wake on LAN (WOL),
Wake on PCI device,
Suspend to RAM (STR)
Expansion / Connectivity
Expansion Slots Total (Free)
1 Processor - LGA775 Socket,
2 Memory ( 1.8 V ) - DIMM 240-pin,
1 PCI Express x16,
1 PCI Express x1,
2 PCI
Storage Interfaces
Serial ATA-150 - connector(s): 4 x 7pin Serial ATA - 4 device(s),
ATA-133 - connector(s): 2 x 40pin IDC - 4 device(s)
Interfaces
4 x Hi-Speed USB - 4 pin USB Type A,
1 x Parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
1 x Serial - RS-232 - 9 pin D-Sub (DB-9),
1 x Mouse - Generic - 6 pin mini-DIN (PS/2 style),
1 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style),
1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45,
1 x Display / video - VGA - 15 pin HD D-Sub (HD-15),
1 x Storage - Floppy interface - 34 pin IDC,
1 x Audio - Line-in - Mini-phone stereo 3.5 mm,
1 x Audio - Line-out - Mini-phone stereo 3.5 mm,
1 x Microphone - Input - Mini-phone 3.5 mm
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D102GGC2
Hope this helps.
Nov 27, 2010 | Intel D102GGC2 Motherboard
Trying to upgrade cpu.
Here's a direct link to the service manual of the NetVista 8303-21A:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_pdf/24p2969.pdf
On page 13 of this manual:
Microprocessor (varies by model type): Intel® Pentium® 4 processor with 256 KB or 512 KB of internal L2 cache memory and Intel NetBurst™ micro-architecture.
It seems that the computer's motherboard does not support Intel P4 processors with more than 512 KB of internal L2 cache. That's why your P4 2.8GHz/1M/533 Prescott processor did not work.
You will have to either buy another processor with 512 KB L2 cache, or replace your motherboard with one which supports the new processor.
Dec 19, 2009 | IBM NetVista PC Desktop
Dell optiplex p4 1.8ghz: RAM
Best and easiest thing to do is go to www.crucial.com and run a scan of your computer. It will tell you what you have, how much it will hold, and what kind of modules.
Yes, it's safe.
Thanks for using Fixya!
If you have any trouble, comment back.
Jan 28, 2009 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
Asrock P4i65G motherboard/CPU
Hi Rlforeard, yes the BX80546PG3000E is compatible with the motherboard P4I65G.
http://www.alvio.com/product_view.aspx?product_ID=61048&source_ID=froogle
Here is the list from Asrock. CPU's supported for the Asrock P4I65G board. You will find you can go higher.
http://www.asrock.com/mb/cpu.asp?Model=P4I65G&s=478
Good Luck!
Mike
Jun 02, 2008 | Asrock Computers & Internet
I want to upgrade my Compaq Presario 1200 AMD laptop Hard Drive - any limitations?
Several companies such as AMD and Cyrix are also developing processors which are completely compatible with Intel processors. This means that they are capable of emulating every processor instruction in the the Intel chips.
INTEL SOCKET INFORMATION
Intel designed a set of sockets. Each of these sockets supported a certain range of processors. Below we have listed the complete specifications and layouts of each of these sockets.
socket1.gif SOCKET 1 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
SUPPORTED PROCESSORS
169 Pins 17 x 17 PGA 5v SX / SX2, DX/DX2, DX4 OverDrive
socket2.gif SOCKET 2 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
238 19 x 19 PGA 5v SX/SX2, DX/DX2, DX4 OverDrive, 486 Pentium OverDrive socket3.gif SOCKET 3 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
237 19 x 19 PGA 5v/3.3v SX/SX2, DX/DX2, DX4 OverDrive, 486 Pentium OverDrive socket4.gif SOCKET 4 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
273 21 x 21 PGA 5v Pentium 60/66MHz, Pentium 60/66 OverDrive socket5.gif SOCKET 5 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
320 37 x 37 PGA 3.3v Pentium 75-133, Pentium 75+ OverDrive socket6.gif SOCKET 6 SPECIFICATIONS Slot 6 was thought and planed of, however was never actually ever implemented in any system.
PINS
PIN LAYOUT
VOLTAGE
235 19 x 19 PGA 3.3v DX4, 486 Pentium OverDrive socket7.gif SOCKET 7 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
321 37 x 37 PGA Voltage Regulator Module Pentium 75-300, Pentium 75+ OverDrive slot1.gif SLOT 1 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
242 Slot Voltage Regulator Module Pentium II / Pentium III Processors
PROCESSOR HISTORY AND INFORMATION
Below is a listing of all known processor manufacturers made to date. In the below list is information about major processors listed by the date manufactured as well as a brief description of the technology and advances of each of the processors.
INTEL 4004 - Microprocessor introduced in 1970 with the speed of 108KHz was the worlds first microprocessor.
INTEL 8080 - Microprocessor introduced in 1974 running at the speed of 2 MHz was used in the world's first PC, the Altair.
INTEL 8086 (Code Name: P1)- Microprocessor first introduced in 1976. The 80086 had a 16-bit architecture that allowed it to work with 16-bit binary numbers and pass them through a 16-bit data bus. The 8086 was available in clock speeds of 5MHz, 8MHz, and 10MHz.
MOTOROLA 68000 - Microprocessor released in 1979 was later chosen by Apple for the Macintosh computer.
INTEL 8087 - Floating-point math compressor compliant with the 8086 / 8080 microprocessor family.
INTEL 8088 - Microprocessor released in 1979. The 8088 was the first Processor used in the original IBM PC and XT personal computers because it was less expensive than the 8086 microprocessor because of the availability of less expensive eight-bit data bus supporting chips made it the microprocessor for the IBM PC. The 8088 was available in speeds from 4.77 MHz and 8MHz.and used the 16-bit architecture allowing it to work internally with 16-digit numbers. The 8088 had the ability of addressing up to 1MB of RAM.
INTEL 80286 (Code Name: P2) - Microprocessor introduced by Intel in 1982 which commonly is referred to as the 286 processor. The 286 processor supported 16-bit architecture, supported virtual memory, and was available in clock speeds of 8MHz, 10MHz, and 12MHz. The 286 was around 20 times faster than the predecessor 8088.
INTEL 80287 - A compliant processor to the 286, a floating-point math coprocessor. Specially designed 286 chips have the capability of placing the optional 80287 processor on top of it, giving the computer a math coprocessor.
INTEL 80386DX (Code Name: P3) - Microprocessor manufactured in 1985 was the next generation of Intel processors. The 80386DX included the math compressor, unlike the 80386SX, and still featured the 32-bit architecture and built-in multitasking. The chip was available in clock speeds of 16MHz, 20MHz, 25MHz, and 33MHz.
SPARC - Released in 1987 is short for Scaleable Processor ARChiture by Sun - used RISC (Reduced Instruction Set) to speed up processing.
INTEL 80486DX (Code Name: P4) - Microprocessor released April 10th 1989. The 486DX featured a built-in memory cache and 32-bit architecture. It had more than three times the computing power of the 386DX and was available in clock speeds of 25MHz, 33MHz, and 50MHz.
INTEL 80386SX - Microprocessor introduced in 1989 was the next generation of Intel processors. The 80386SX lacked a math coprocessor but still featured the 32-bit architecture and built-in multitasking. The chip was available in clock speeds of 16MHz, 20MHz, 25MHz, and 33MHz.
Good Luck, Please dont forget to Rate/Thank You.
Jan 17, 2008 | Compaq Presario 1200 Notebook
Heatsink Removal
This is an easy one. :)
I am assuming that you're asking about removing your typical P4 HSF.
Direct from Intel's very own website! :)
http://support.intel.com/support/processors/pentium4/sb/CS-007989.htm#Removal
Good luck and please be careful. *nods*
Cyryl
Nov 04, 2007 | Intel Pentium 4 Socket 478-Pin Cooling Fan...
Computers & Internet Logo
126 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
