Question about Brother MFC-410CN All-In-One InkJet Printer
Paper jam mfc-410cn keeps saying paper jam, have checked inside took any paper i found out, but still saying jam,have switched off left for at least half hour, but still no joy.need help
A7f317899
Posted on Feb 11, 2008
  • 832 Answers
Push menu then start mono (b/W) then 4x arrow-up button. maintenance should be displayed. What error code does the machine give to you?
Posted on Sep 16, 2007
SOURCE:
Mfc 7840w keeps jamming
use a 20lb paper in lieu of regular copy paper, works for me
Jan 21, 2013 | Brother MFC 7840W Printer
Keeps saying there is a paper jam
Unplug the printer and open all the access panels. Using a small flashlight may help. Carefully check all areas inside the printer for a stray piece of paper logged somewhere inside. You may need a small pair of pliers or tweezers to remove the piece of paper.
When clearing jams ensure you find the entire piece of paper that was jammed in the printer.
When your done, be sure to securely replace all parts removed from the printer and properly close all the access panels.
Jan 01, 2013 | Brother MFC-465CN InkJet Printer
I had the Bro 8840D repaired following a paper jam. I am unable to get it to pull paper through. Says paper jam, but no jam exists. The tech repair shop said a switch had been flipped when the first jam...
okay, try this...clear the paper jam message and try to make a copy using the manual bypass (MP tray) located on front of machine. if copy comes through okay, then chances are you have a problem in main cassette area. pull cassette out, and make sure the rear stop inside cassette is not pushed too tightly against rear of paper stack. should leave about 1/8" gap. if thats okay, then sounds like you may need your paper pickup roller replaced. sounds like your repair shop just fixed the error, not the cause of the error.
hth,
razors
May 24, 2010 | Brother MFC-8840D All-In-One Laser Printer
Keep saying paper jam
Hi Mesha
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Jan 24, 2010 | Brother MFC-3240C All-In-One InkJet...
Paperjam
Check whether the inside is perfectly clean - it might be that while you were trying to fix the jam, some paper was left stuck inside. Otherwise try disconnecting the printer from the power supply to allow it to reset.
Sep 16, 2009 | Brother MFC 420CN All-In-One InkJet...
Printer says it's jammed, but i took out the paper tray, took out the jammed paper, put it back in, now it won't work. it continues to say it's jammed.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it
Apr 30, 2009 | Brother MFC 420CN All-In-One InkJet...
My fax machine keeps saying there is a paper jam.
look on the bottom of your drum unit. there is a sensor opening that might have a tiny piece of paper in it, not allowing the sensor flag to reset. if thats not it, closely inspect behind rear door.
hth,
razors
Apr 05, 2009 | Brother MFC 8500 All-In-One Laser Printer
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Dec 28, 2007 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-410CN All-In-One InkJet Printer Logo
347 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
