Question about E-Machines C1641 PC Desktop
No display ok my pc stop working all together it wouldnt even come on so i got a new power supply now it on but i got no display nothing on siganl what do i do
  • alanble7487 Sep 15, 2007
    im trying all the things you said to do thank you for your help you beem very helpful thank aagain for your time Delphi51
    Scholar:
  • 33 Answers
So turning on the computer doesn't bring the monitor out of standby? Just to be sure, try turning the monitor off, then on again and the Pc on at the same time. If you see any writing on the screen, that will be good news. Make sure it isn't just the cable to the monitor. It is possible to mess up the connector on the cable where it goes into the computer. If one of the pins is bent, use tweezers, to very carefully try to bend it back. If it breaks you have a big problem - have to find another one and splice it onto the cable or replace the whole cord. Still nothing on the screen. Could be the monitor. Could be the video card, the motherboard, the microprocessor or the power supply. The worst case is that the old power supply failed drastically and destroyed all of the above. Try your monitor on another computer. Any sounds coming from the computer when it starts? Startup music would be a very good sign - most everything working. Any beeps? Three beeps mean the video card has failed but the motherboard and processor are probably okay. I can't think of an easy way for you to test the motherboard and processor. If you have access to a similar computer, you could try swapping in a known to be good video card. It sure looks like the worst case scenario.
Posted on Sep 11, 2007
  • Delphi51
    Delphi51 Sep 12, 2007
    It could be just mixed up CMOS settings.
    I can't find how to clear the CMOS settings on that computer, but taking the battery out for a few days will do it. Then it might start okay!
Hitachi 1350 projector dead, no power. cleaned everywhere, changed the bulb, nothing I do gets power into it.
I assume the projectors are of similar age and have similar useage history? Not certain why they would fail together, but the most probable cause is faulty switch mode power supplies. The electrolytic capacitors in these supplies a relatively short working life, especially when installed in high temperature environments - like a video projector. new caps in the supplies may be all that's required to solve the issue. If you have other similar projectors, they may well be approaching the same problem.
Any reasonably competent TV repair tech should be able to check the supplies for you, and repair them if found faulty :o)
Apr 05, 2014 | Hitachi PJTX100 Multimedia Projector
Consumersupport lenovo com
sounds like your power supply is having trouble. Is the inside filled with dust bunnies? Get some canned air and blow out the inside of the machine. Make sure all the fans spin freely. Once in a while the video card will need to be pulled out and reseated to reestabilish electrical connection. At the least, clean and replug... at the most, a new power supply.
Dec 30, 2013 | Computers & Internet
No power to system but green light on motherboard is on
If you have replaced the power supply with a known working power supply and have connected it properly to the motherboard and all devices, then you probably have a bad motherboard.
Dec 21, 2011 | Dell Dimension 3000 PC Desktop
Compaq Presario SR1750NX wouldnt come on, installed dynex 400 watt atx power supply now it comes on & fan runs but monitor is still blank. Installed ATI RADEON 7000 GRAPHICS CARD, still nothing, the...
After adding new graphics card monitor display will not work with motherboard display connector.
So, connect your monitor VGA cable with your graphics card display port.
Thanks for using FixYa.
May 22, 2011 | Computers & Internet
Sir i am using asus motherboard(ASUS M2N68-AM SE2) in my pc, when i switch on my pc the processor fan and smps fan is rotating for few seconds(4 to 6 Seconds) and it stopped rotating. 1. the monitor shows...
remove all the ram from motherboard and switch on the system and see it is working or not like just on and fan are rotating and the smps fan is also working and your system is giving beep sound for ram.try with other smps also some time problem with power supply also. Remove the connector of power switch and restart switch and directly try to on from shorting the connector with the help of pen or screw driver point. Some time faulty switch also give problem. Just try all these possibilities.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Jan 03, 2011 | ASUS M2N68-AM SE2 Motherboard
Smart Cycle. Worked Fine yesterday. Changed the batteries, Connections are tight. Turn it on, Nothing No lights on the cycle , nothing on the tv screen.. Other toys work well on the same TV. Help
do you know where you put the cartridge in below where you placed the 4 screws you can take those apart and you will see some cables inside you will see a red and back one together thats the power from the batteries below. i cut mine and drilled a hole on the side where my son wouldnt hit the cable and now my smart cycle doesn't use batteries it uses the power in my house to power it. i used a 4.5 volt 350 mA power supply for some other deal. i had laying around.
you can use 6volt power supply and that will work i wouldnt go higher than 6 volts since 4 D batteries add up to 6 volts 1.5 x 4 = 6 volts. the watts doest really matter since the device will use what it needs.
black cable on power supply goes to red on bike black and white cable on power supply goes to black cable on bike
at least thats how it worked on mine it didnt hurt my bike i had to switch the cables around i didnt have the polarity right the first try.
Aug 27, 2010 | Nintendo Game Boy Advance Console
No power up A135-S2266
Maybe your graphics card and/or display went bad. If I were both of you, I would check that out and see. if so, then you would have to buy a new computer screen for your computers.
May 19, 2008 | Toshiba Satellite A135 Notebook
Latitude C640 is dead!!
The only solution that I can think of would be a power jack problem. I would not advise replacing the power jack yourself since you have to take out the laptop mother board, de-solder the power jack then solder the new one on and put it back together. My advice would be to take it to a professional computer repair shop and have them take a look at it and replace the power jack. It is worth getting repaired since power jacks usually range $40-$70.
Feb 20, 2008 | Compaq Presario 1200XL104 Notebook
Acer aspire e500 won't turn on
Check that all the power supply units are switched on( Wall Plug, UPS, CPU), If all is ok and the problem exists, replace the CMOS battery.( if the sys works replace your CMOS Battery, configure the cmos settings also)
Jan 03, 2008 | E-Machines T1360 PC Desktop
E-Machines C1641 PC Desktop Logo
50 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
