Question about Dryers
My tumble drier dont heat up. It works but its
My tumble dryer dont heat up. It works but its just cold temperature so it makes the drying longer. I have empty water resevior and cleaned filter but still if i put it on just cold air.
  • 3 Answers
There will be a red overheat switch on the rear on most models, simply pull the machine out and press reset, the most cpmmon cause is running when empty or a build up of lint. if the doesnt work then it will be an open circuit element.
Posted on Apr 13, 2009
My bush tumble drier is smoking when drying clothes can u please give me advice on how to solve this please?
if its electrical smoke turn off dont use till fixed possible motor --element or switch can cause smoke/fire from short --if its steam your seals may need to be replaced
Aug 20, 2016 | Dryers
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
My dryer heats up but is not drying my laundry.. What's wrong?
here is a fuw things to check first,,,, is the vents clear the dryer need to breath freely,,,is the drum turning around freely and not sticking due to belt slip,,, how dry are the cloths going ino the dryer,,,,(as the winer is here the air going in is cooler so takes more heat to warm it up) uk temp -2 degrees??? cold! how much are you putting in it? can it tumble freely,,,(no big knots in it?) try turning the heat up to full heat? and drying for longer,,,if all that fails,,,dont do any more washing??
Nov 28, 2010 | Kenmore Dryers
My dryer only blowing cold airwhats wrong
the heating elements that dry the clothes is more than likely burnt out. If the drier turns on and the clothes tumble then the element is the only other possible reason for the drier not to heat up. This element is in the bottom of the drier and can be accessed through the removal of the back panel. It will more than likely be in a square metal box. It isn't hard to replace as you will see but you will need to take the model and serial #'s to an appliance parts house for the proper replacement part.
Good luck hope this helped
Dave
Mar 02, 2010 | AEG T57800 Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
Whirlpool model # lgr7646ez3
Here are a list of causes that may contribute to this lack of sufficient drying.
CAUSE
• Lint screen is clogged with lint.
• Restricted air movement.
Exhaust vent or outside
exhaust hood is clogged with
lint.
• Exhaust vent is crushed or
kinked.
• One fuse is blown or circuit
breaker is tripped. The dryer
will appear to operate, but you
will not get any heat.
• Cycle Control knob or temperature
selector is set on air dry.
• Load not contacting the sensor
strips and automatic cycle
ending early.
• Fabric softener sheets blocking
exhaust grill.
• Dryer located in room with
temperature below 45ºF (7ºC).
• Large amount of moisture in
the load.
• Cold rinse water used.
• Load too large and bulky to
dry quickly.
Here are the solutions to combat the issues.
SOLUTION
• Clean lint screen.
• Run dryer for 5-10 minutes. Hold hand under
outside exhaust hood to check air movement. If you
do not feel air moving, clean exhaust system of lint
or replace exhaust vent with heavy metal or flexible
metal vent.
• Replace with heavy metal or flexible metal vent
• Replace fuse or reset breaker.
• Select the right cycle and temperature for the types
of garments being dried.
• Level dryer.
• Use only one softener sheet per load and only use
it once.
• Move dryer to a location with temperatures above
45ºF (7ºC).
• Expect longer dry times with items that hold more
moisture (cottons).
• Expect longer dry times.
• Separate load to tumble freely.
This will help you fix this problem. i suspect an exhaust obstruction.
Mar 11, 2009 | Whirlpool LGR7646E Dryer
Twin thin dryer
I believe that it is the thermostat that is bad if it will not heat. It is the piece that supplys electrical heat to the heat coils. 696818 is the whirlpool part number for the thermostat on my stackable unit and it can be purchased online for 10-15 bucks.
Sep 21, 2008 | Whirlpool LTE6234D Top Load Stacked...
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
Dryers Logo
286 people viewed this question
Top Dryers Experts
