Question about Epson LX-300+ II Matrix Printer
Setting of new paper size from epson lx-300 +II
How to set custom paper size on epson lx-300 +II
  • 1 more comment
  • ronaldo_2002 Apr 23, 2009
  • Don  Farrell
    Don Farrell May 11, 2010
    I need some help from you guys. Are you trying to re size the paper length via the front panel or with printer control codes? Don
  • Don  Farrell
    I give up. Are you trying to build a custom form using the front panel or via printer control codes?
Your solution works fine with me, but the problem is i can't able to save the settings on the printer. so everytime i need to print on that given custom sized paper type, i need to manualy select it from advance tab on printer properties before i have a good print-out..
Anyways,Thank you very much.
Posted on Jan 17, 2013
2 Suggested Answers
SOURCE: setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Posted on Jul 29, 2009
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
Custom size doesn''t present on your driver on Form to Tray Assigment in
Hi, I can't understand what "Custom size doesn''t present on your driver " means. the drver is just the piece of sofware used by windows to make your printer work. Custome size setting should have nothing to do with the driver.
Feb 23, 2008 | Epson LX-300 Matrix Printer
Epson LX-300+ II
just change the page length setting in printer .just press pause button and switch on the printer and change the setting accordig to the page size it is bettreif you take online help from epson service call center they will guide you how to set the page length.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | Epson LX-300 Matrix Printer
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
Setting custom size (tear off) paper
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Problem on printing size
Hai
First you go start to settigs,printers &faxes .Then you go file ,server properties.
Create a form size,insert paper size and save the form.
Aftter that you can find the form name in device setting.
Oct 14, 2008 | Epson LX-300+ II Matrix Printer
Small Height Paper Size Problem
here's an option for you to consider.... hope it helps!!!!
set it to 3.6 and make your adjustment on the page margins.
Feb 28, 2008 | Epson LX-300+ II Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Draft Printing with EPSON LX-300 with custom page 10x6 inch in windows xp sp2
You have to install the printer through it installer, it that way the advanced features of the printer will be activated and can be manually configured to what you want.
Click the link to get your driver. download here
Don't forget to rate me, "Fixya"... thanks.
Jan 27, 2008 | Epson LX-300 Matrix Printer
PRINTING ON CUSTOM SIZE PAPER
you need to change the page lenght on the printer. to do so...
  1. turn off printer
  2. press and hold the tear off button while turning on the printer
  3. a menu of the setting will be printed
  4. just follow the instruction
  5. you need to set the page lenght for tractor feeding to 8inchs
turn off the printer it willsave the setting
Jan 01, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300+ II Matrix Printer Logo
3,622 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
