Question about Samsung SyncMaster 753S 17" CRT Monitor
Retress line with vertical foldover - Samsung SyncMaster 753S 17" CRT Monitor
  • 700 Answers
Vertical suddenly fold over? Vertical IC loosing connection with board. Best solution is to reflux or resolder it. If not damage vertical IC, replace it. That should fix the problem.
Posted on Apr 13, 2009
How to repair Vertical Foldover on Toshiba 20AF43 old crt TV
Check and replace all the electrolytic capacitors [about 5 or 6 of it] at its vertical scan output section circuit..
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | Toshiba Televison & Video
Vertical foldover on bottom of 32 inch samsung lcd tv about 3 inches across bottom of screen
usually on all image related problem on all LCD comes from faulty t-con board..but for sure try to play dvd movie to test if the problem is on tv/t-con...
Jul 18, 2012 | Televison & Video
White lines at the top of my jvc, av-32230
Problem is in the vertical circuit of the set= lines at top and or some foldover----either the output chip and or a filter cap connected to the chip.
May or may not be a do it yourself repair depending on what skills you have at fixing TV sets===not an adjustment etc.
Apr 14, 2012 | Televison & Video
Lines at top of screen, about 4"
Hi:
This is due to vertical deflecton problem, there is some capacitors that has gone bad and need replacing. It might just be one cap rated at 100uf 35 volts. This is called vertical foldover eventually the top will fold over or you will get a 4" black border on the top of the scrn.
Aug 23, 2010 | Toshiba 27A33 27" TV
I have a 20ms3442/17 the screen only shows the bottom half of the picture and the upper half is lines and a reverse image on the first half of the top of the lower half
You have a vertical foldover. Check the caps near the two vertical ICs. HMMM it does not surprise me...There could be a couple of suface mout caps. to check...I do not remember the locations at this time. But try the electrolytics...they are easy to check.
Nov 29, 2009 | Philips Magnavox 20MS3442 20" TV
I have vertical shifted up from bottom and foldover from top down
This is caused by a defective capacitor in the vertical circuit. If you can solder, you should be able to fix this your self. Let me know if you wish to attempt the repair and I will supply additional details and instructions.
Dan
Apr 02, 2009 | Zenith B13A03D 13" TV
Vertical Fold over or rolling on Dell Inspiron 1000
Get a new hard drive put into the system, with the cd's that came with the system, restore the laptop back to factory defaults and then after that the F12 function should work and windows will go back to working as well.
Feb 13, 2009 | Dell Inspiron 1000 Notebook
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
DS25390 Verticle foldover
If you have a picture but the top is folded over, your vertical IC is probably good and you need to replace the pump-up capacitor next to the IC. When the pump-up cap (typically a 47 or 100uF 35V cap) is open then the picture will have white lines and foldover at the top. The typical vertical output IC is the LA7838, but I am not familiar with exactly which output IC your set uses.
Jul 02, 2007 | Sanyo DS25390 TV
Samsung SyncMaster 753S 17" CRT Monitor Logo
237 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
