Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Need to replace the power supply
Power supply went out.
  • 1 more comment
  • lostpower Sep 11, 2007
    for KOGi 17" L7EH-TA
  • KingJP1 May 19, 2008
    Need a power supply, as well. Can't find replacement at the local stores.
  • Anonymous Apr 05, 2009
    Power cord does not work, need a replacement.
Ebay has power supplies, I bought mine from there.
Posted on Feb 04, 2009
SOURCE:
TV went bang now no power
The capacitors on the power supply need to be replaced. When you take apart the TV, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video on howto replace capacitors.
Oct 20, 2014 | Samsung Televison & Video
Samsung ft-p5084 plaza tv went blank. No power at all.
If that fuse is blown chances are its because the Power supply has developed a short. The power supply will need replacement. You can easially install a power supply yourself just a few screws and couple of wire sockets and the old board pops right out. You can get the power boards from www.tvcircuitboards.com
Feb 09, 2013 | Samsung FPT5084 50 in. Plasma HDTV
I have a Syntax Olevia 20HVK, we had a brown out and the tv went out. I opened the tv and found a blown fuse in the power supply, I replaced the fuse and the fuse blew again. should i just replace the...
you have shorted power transistor or mosfet on power supply that need to be replace however this need a soldering skills and electronic background if you don't have skills its better if you replace the whole power supply board.
Nov 03, 2012 | Televison & Video
Just fitted new power supply after repair but power supply working but it wont power up .....please help
Check the fuse. Blowing a power supply does not happen. Blowing a fuse often does. If the power supply truly went out, it is too small in amperage. More information on the power supply may help.
Feb 01, 2018 | Ranger RCI-2995DX Base Scanner
My computer was knocked forward it went bang and then smelt of burning - I have been told that it might be the internal powe pack can you help?
If your desktop computer went bang from the back of the computer and the burnt smell comes from the fan grill of the power supply then the switch mode power supply definitely failed. The bang and burning smell was probably one or more of the capacitors that has exploded inside the power supply.
You can replace the switch mode power supply, make sure you purchase one that has the same total wattage or higher wattage.
There is a chance that when the power supply failed it may have caused a voltage spike that could have damaged some other components. You won't know until you replace the faulty power supply.
May 19, 2011 | Computers & Internet
Computer went of
if your computer is went off first you check its power cable .its battery if working in good then you check its power button its properly working push properly
if you have desktop computer check its power supply open its atx power connecter 24/pin in pin you green or black short it if supply fan on its mean your supply is oky
have a problem of mainboard supply regulater
its check with meter
first you replace power supply then check motherboard
Dec 27, 2010 | Computers & Internet
TV went out.
U have a dead power supply board,burn componnents parts on the power supply board.Replaced the power supply board,u will get ur power back as normal function as before.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 02, 2010 | Philips Magnavox 42MF521D/37 Television
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Power went out the other night while my Gateway GT4022 was on. It won't turn back on now, no lights, no fans...replaced power supply, still same problem...thanks
If the power went out while it was on it may have been given a surge. If that is the case the motherboard is going to need to be replaced. Check the power supply connection on the motherboard if it is discolored then that is the problem.
Jun 25, 2009 | Gateway GT4022 PC Desktop
Power supply for gateway
This power supply has an odd form factor so just "any" power supply won't work.
Nov 11, 2007 | Computers & Internet
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
165 people viewed this question
Top Kogi Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
