Question about LG L1530S 15" LCD Monitor
HP 1530 LCD Monitor bottom one third of screen not displaying
  • razorb May 07, 2009
    I plug every thing up right but the green light dose not come on the screen dose not come on y??????
  • 68 Answers
Change video board
Posted on Aug 21, 2009
LG L194WT picture problem
Sounds like your main board is going out. It's cheaper to buy another monitor then fixing it unless you have a warranty.
Feb 18, 2013 | LG L194WT 19" LCD Monitor
When I turn on my HP Pavilion 1x1000 It stays on ,but there is no image on the screen, and stays on please help.
A) Post THE Product Number on the bottom of the laptop. It's in the white Service Tag. P/N = Product Number.
B) On the left/bottom side of the LCD screen frame (Display Bezel), there is a switch. Looks like a small button.
This is the Internal Display Switch. (May not be in this exact position for your model. Look around on the Display Bezel, that surrounds the LCD screen)
When the laptop is closed, the switch turns off the display, (Image on screen), with the computer still on.
Tap it a couple of times lightly, with the eraser on the end of a number 2 pencil.
See if anything happens. That switch may be bad.
C) Laptop off, monitor off, connect a VGA monitor to the VGA port on the laptop.
Example of a VGA cable, and VGA connector, (Port),
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
C) Turn the monitor on. If a CRT type of monitor allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options,
1) Internal monitor of laptop ONLY
2) Internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key. At the same time tap once on the Display Toggle-Over key.
Don't know what exact HP laptop you have. For most HP's it is the F2 key, or the F4 key, that is the Display Toggle-Over key.
(Key has an empty rectangle on it, with a vertical line on each side)
Still no display on the external VGA monitor?
Hold the Fn key down again. (Bottom left of Keyboard)
Tap once more on the Display Toggle-Over key
NO display on the external VGA monitor, means you have a bad graphics chipset.
(By using an external VGA monitor, you are bypassing the Internal Display Switch, and the Display Assembly. (Internal monitor of laptop)
If you have a display on the external VGA monitor, you have a problem with;
1) Video Cable, (Display Panel Cable for HP)
or
2) Display Assembly
Post back with your results, and if you have a display on the external VGA monitor, we will go on.
If you do not have a display on the external VGA monitor, you are looking at motherboard replacement.
Post back in a Comment.
Regards,
joecoolvette
May 13, 2012 | HP Computers & Internet
I have a hp 1530 flatscreen monitor when I push the menu button on the screen it blacks out...and says osd lockout...what does tht mean...I have to unplug it in order for it to come bck up
OSD means On Screen Display. To unlock the OSD hold the power button of the monitor until you get a message similar to "OSD unlocked".
If you still have problems, click on this link for further instructions :-
http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
Dec 29, 2010 | HP Televison & Video
White horizontal bar at the bottom of the screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty usually its for 3 years
Apr 10, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
Is it the lamps?
You may have LCD controller board (T--CON, part of the LCD panel) going bad or loose connection, or the Logic board. You will need to open it up and inspect the inside. First check the power supply to make you do not have bad caps with bulging op/seal. You may also have to do some voltage checking. Post back what you see first so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
I jsut have a bad feeling that it is bad screen.
Apr 05, 2010 | HP w1907 LCD Monitor
I want to adjust my screen , its is streching vertically Please help
Look for "buttons" on the bottom-front or bottom-edge of the monitor.
One button will activate the OSD ("On Screen Display). Through the OSD, you can change the "vertical size" and "vertical position" of the display.
Feb 03, 2010 | HP L1955 19" LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
My hp 1530 has the ability to rotate, but it has rotated and now the screen is sidewards
You have to go to the display settings, right click on desktop then go to properties and then settings and tell the video card the monitor is rotated. You may have to install the drivers for the monitor
Apr 28, 2009 | HP Computers & Internet
Black horizontal line
The LC display is bad. The monitor will have to be replaced.
Jun 24, 2007 | HP vs15 15"LCD Flat Panel Monitor
LG L1530S 15" LCD Monitor Logo
389 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
