Question about Car Audio & Video
I have a 4 channel amp which i would like to install myself in my 1998 mitsubishi verada ei. how do i do it?, because I cant find a hole to run my power cable from battery to amp. Where would the best place to be to ground my amp on the body? where is the best place to run my wires along? what type of fuse should i get an 40 or 60 amp?
  • 67 Answers
Really depends a lot on you if you have clearance you can put it under a seat eaven a 500w amp wont get that hot down there. As far as your powering wire you can some times find a rubber plug in a hole on the fire wall or you can drill a 3/8-1/2 inch hole depending on your gadge wire and use a rubber gromet to protect the wire. the ground can be any steel part of the car generally I use a metal self tapping screw to the floor steel.
Posted on Apr 13, 2009
Hi i have a mitsubishi verada 1998 it wont idle down can anyone suggest wat it might be
wow an oldie but a goodie !!! 1998 !!! first id look to make sure the throttle isn't stuck , old aluminum gets corroded and likes to stick a bit then id look 4 any cracked and broken hoses on the manifold , if any of these leak air it will high idle
Aug 03, 2016 | Mitsubishi Cars & Trucks
Do I need to get a new head unit to put an amp and subwoofer in my mitsubishi verada?
Amps have a high and low input. You can run some speaker wire from your rear speakers to the high input on your amp. It comes with a small white plug with four wires. Use the green for one side, and the grey for the other! So no, you do not!
Jan 24, 2013 | Cars & Trucks
Can someone please give me the code for my radio Mitsubishi verada 1998 model radio model no AW345090 serial no 284004908.5.
Go to a Mitsubishi Dealer with your car, prove the car is yours and the dealer will give you the code, they will not give it over the phone.
Feb 18, 2012 | Mitsubishi Car Audio & Video
Hi there how can i tell if i cracked my engine block on a mitsubishi magna/verada 1998 can see coolant between the heads but dont know where its coming from
Blocks rarely crack, heads do crack more often. Most likely you have blown a gasket. Unless you can see coolant coming from a crack , you will have to disassemble it to find out
Aug 31, 2011 | Mitsubishi 3000GT Cars & Trucks
CLICKING NOISE BEHIND GLOVEBOX 2000 MITSUBISHI VERADA
It's a little motor that i believe opens and shuts a damper to do with the climate control, a quick fix is just adjusting the cabin temp up a few notches.
May 31, 2010 | Mitsubishi Lancer Cars & Trucks
Starter Motor Verada V6 ei
i do not have one handy but the starter will be located at the point where the motor and the transmission join. on either side of the motor. follow the main line from the battery to make it easier to find. if you are replacing it post another question and i'll do my best to answer it if i see it come up.
robert
please take a moment to rate this solution.. thanks
Nov 30, 2009 | 1991 Mitsubishi Galant
How to run an amp wiring kit in a mitsubishi verada ei 1998?
for the power wire try running it thru where your factory wiring harness go thru for the rest of the power or you may need to make your own hole... for the others,, pry up the side molding by your doors that are plastic, lay them under those very flatly so it'll still clip back in and you may need to run them on both sides if your power wire is thicker then 6ga.
then just try to run them underneath plastic moldings all the way back.. you can pull up your carpet if you really want to but its a lot of unneeded work if you go thru that way
Nov 18, 2009 | Car Audio & Video
Faulty Fuel sender - Mitsubishi Verada
my radio is "locked out" how can i fix it?
Aug 29, 2007 | Car Audio & Video
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
