Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Sep 11, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an od code on my washer ??
I have an od code on my washer. It won't run this was. If I pull the power cord and then plug it back in -- the code goes away and the washer runs fine. I think the code means open door. But it is not open. Is there any way that this can be repaired. Thanks
Anonymous
Level 3:
  • Master 625 Answers
  • Posted on Sep 12, 2007
Anonymous
Master
Level 3:
Answers
625
Questions
7
Helped
679466
Points
1177
Check to see if the switch button is depressed.
2answers
Lenovo idea pad won't charge or run plugged in
Is the cord and Battery the EXACT same power spec? If so, it may be the AC jack in the Laptop has been damaged due to pulling on the cord while plugged in, broken connection.
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
2helpful
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
2answers
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
1helpful
Where is the reset button. Our washer won't go on. It has no power at all.Tried the circuit breaker..Machine was here when we bought the house
Thanks for choosing FixYa Karen and welcome. You can unplug the washer for 30 minutes and plug it back up to reset the washer. Make sure the outlet works. Next, check your power cord. Wigglle it while plugged in to see if the power comes on. Inspect the cord first for damage before you do that. If the outlet, breaker, and cord is good, you need to check the fuse to the washer. If it still has no power, you may have a bad control board. Due to the fact there is no power, it is probably electrical. Inspect all wires in the washer for damage. You may need a voltage meter to test for power in the cicuits.
1helpful
I can not pull the string to start the engine of power washer
Try removing the spark plug then pulling the cord! If the cord pulls then you cycle the engine a couple of time to see if fuel is coming out of the spark plug hole! If no fuel present replace spark plug and try starting the engine. always have water running through your washer before you attemp to start!
2helpful
LIGHTS COME ON BUT WILL NOT RUN
Are there any error codes to the LED display when you press the Start button of your FAV6800AW is that your model? Error codes types such as OD, OP, FL,LR etc.
Have you tried to power cycle the machine by pulling the 120VAC power cord then re-power back up. If there are no error codes the next step would be to enter service mode and read the machines diagnostic error code list to get a start point for troubleshooting.
I’ll assume the machine type is a FAV6800AW or FAV9800AW and post some handy links. If you want to DIY I will try to help. If you decide to call in a service repair company I would call Maytag for an authorized Maytag repair service in your area some parts Like the Control Board may still be under warranty (5yr). Warranty info is in the SM link I attached. The number to call is 800-688-9900. Maytag will need your model number and serial number, that info is located on the back right top side of the console.
The Service Manual for reference. Sears Parts Direct for reference.
16helpful
7answers
Od error code
Maytag's service center emailed me back saying that I needed to purchase a magnet for the right side of the lid, even after I sent them photos of the lid. There is no magnet on the right side, so don't be fooled! The lid comes apart fairly easily. First, with a screwdriver, apply a little downward pressure and pry out the center liquid/powder holder. It is hinged on the bottom and will come right out. Next, pull out on the bottom corners and the lid liner will come straight down. Now you can verify that the magnet (on the left side!) is there and seated correctly. If that is the case, go ahead and reassemble. Unplug the washer. Lift up the top portion of the washer (at the crease). You may need a screwdriver to pry up on it. I didn't. I just pulled up on it. It comes up fairly easily. Now you can see the locks, mounted with one bolt on either side. Inspect the wiring for any wear or damage. Next, remove the locks one at a time, unhook the wire connector and plug them back in. Reassemble. Leave the lid up (not sure if it matters, but I did) and plug the washer back in. That's all I did and it worked! The "od" alarm didn't come back.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
