Question about Honeywell ER150B Air Conditioner
SAMSUNG AIR CONDITIONER.
The outside unit does not respond when the inside unit starts up.
  • Anonymous Feb 25, 2008
    My air conditioner does not work when turn it on after 6 month use.
  • lilspit91 Jul 22, 2008
    my outdoor unit is not starting. i get power to the contactor but it does not pull in. when i depress contactor manually it runs.
  • 306 Answers
Your coil is bad on the contactor. Make sure there is 24 volts to the coil if there isn't the transformer is bad. Any 2 wire touching each other that will kill a transformer is a heart beat.
Posted on Nov 23, 2008
  • 625 Answers
Check for a control fuse in the condenser section.
Posted on Sep 11, 2007
SOURCE:
How do I locate the contactor in the outside unit of Samsung air conditioner ?
DO THIS WITH THE POWER OFF!
Follow the main power wires until they stop at a connection and there is the contactor.
Aug 17, 2014 | Samsung Heating & Cooling
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
My air conditioner is not running on the outside but in the inside. temperature states 85 inside
If you turn down the thermostat to the air conditioner and the unit outside does not come on, you could have a few different issues. The usual suspect is a start capcitor. When you adjust your thermostat you should hear a click from the outside unit. If you hear a click but nothing happens, check the power disconnect out there by the unit. I recently had to replace mine because it finally just wore out. It can also be the contactor, the fan itself or the actual compressor.
Jul 02, 2009 | Honeywell Heating & Cooling
Air conditioner not geting cool
Hello, It sounds to me like your low on freon/refrigerant. You'll need to have someone test the pressures for you.
Jan 24, 2009 | Fujitsu 24C1 Air Conditioner
Air conditioner freezing
Check your filter in the furnace, Then check the coil to make sure it is clean. If neither of these two solutions fix your problem you may be low on refrigerant.
Jul 22, 2008 | Samsung AS18A6RB Air Conditioner
Outside unit not working
If the heating and cooling is working O.K. and maintaining the proper temperatures it is possible that your outside unit is in its off cycle. If the inside unit is running and the outside unit is not with an elevated temperature inside check the power supply to the outside unit. Most units have a disconnect located near them. Check the disconnect and make sure it is set to the on position. Listen for a hum noise at the outside unit which could indicate that the control power is being supplied to the contactor.
Jun 15, 2008 | Samsung AS18A6RB Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Honeywell ER150B Air Conditioner Logo
79 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
