Question about Riso RZ220 Duplicator
RISO RZ200 I HAVE A PROBLEM WITH MY RISO RZ200.ON MY DISPLAY APPEAR AN ERROR CODE D22-542.WHEN I REMOVE THE CARTRIGE APPEAR D04-534.WHAT SHOUD I DO?
  • 22 Answers
D22-542 is saying that there's a problem with the printed circuit board on the print drum. It's not communicating with the machine. D04 -534 says that the incorrect ink cartridge is installed. First, is this a new drum you are introducing into the machine? if it is, not all drums are interchangeable. You need to get the right pcb (printed circuit board) for the ink drum you are using to match your machine. Second.. Something is mismatched here with the ink cartridges. The only way you'd get the ink cartridge error is if the drum is in the machine. I had this problem with a Rn 2130 ui.. I bought a used drum off e-bay and it wouldn't work. When I stole the pcb from another color drum it worked fine. If you have been using this drum in this machine before... be sure that the connection between the drum and the machine is good. Make sure you have the right ink cartridge too. Some of these aftermarked re-sellers sell stuff that doesn't line up with the tabs on the inside.. I've got some ink here that if you hold your toungue just right and turn the tube about 2 degrees it'l work.
Posted on Aug 14, 2009
    Problem Solver:
  • 4 Answers
If show ERROR CODE D22-542 means the board in the drum have some problemif show D04-534 means you are using not original ink, but just press restart key is ok.
Posted on Aug 11, 2009
  • 3 Answers
I had the CODE D04-534 occur on some of the brand new original cartridges and have been puzzled why they did not work. I tryed the following on my Risograph RZ-390UI and it worked:
go into test mode..
turn off machine and turn it back on while holding down the left and right print position arrows.
if the error code shows up.. press the yellow reset button to clear it.. you will then see a number (firmware ver.) press the "C" button on the number pad..
you should then see the display all zeros "0000"
enter 890 and press start.
then when it beep press the "C" again enter 112
when it beeps again press and hold the yellow clear button and the machine will reboot...
HOPE THIS WORKS ON YOURS...
Posted on Jul 08, 2012
  • Hillary Kumangin Oct 17, 2013
    I still have P98-25 poping up plus i cant go into test mode to reset the machine
  • Paul Collins
    Paul Collins Jan 13, 2018
    This worked on my RZ 390ui, thanks!
2 Suggested Answers
  • 81 Answers
SOURCE: I HAVE A PROBLEM WITH MY RISO RZ200.ON MY DISPLAY
go into test mode..
i am sorry to say that if this did solve the problem you will need replacement parts or a new drum
Posted on Jul 07, 2009
Riso rz200ep error code d-13---9
http://printcopy.info/?l=en&mod=erc&brand=Riso&model=RZ200&code=D13-9
The link above states:
Code
D13-9
Description
The rear cover is opened (serviceman safety switch is OFF).
Riso RZ200 Error Codes
Mar 26, 2018 | Office Equipment & Supplies
How much would I pay for 2 x drums for a RZ200? Thanks
you can probably find them on ebay for about 3-4 hundred each.. new from riso they are very expensive..
Jun 22, 2009 | Riso RZ220 Duplicator
I cant repair my riso
Need proper error code.. A letter should come before..
Apr 29, 2009 | Riso RZ220 Duplicator
I HAVE A PROBLEM WITH MY RISO RZ200.ON MY DISPLAY APPEAR AN ERROR CODE D22-542.IF I REMOVE THE CARTRIGE APPEAR D04-534.WHAT SHOUD I DO?
go into test mode..
Apr 13, 2009 | Riso RZ220 Duplicator
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
2,521 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
