Need step-by-step instructions for serpentine belt installation on 6 cyl. 1997 Chevy Malibu
The solution sent to me only pointed out the obvious. It made no mention of the need to remove 2 motor mount bolts & jack up the engine 1 1/2 inches to thread the belt on.
Some master mechanic!
Posted on Apr 14, 2009
Serpentine belt 1999 chevy malibu is slipping off cranshaft pulley
Make sure that the belt is fully seated in ALL pulleys, if it still slips off, then you have a pully that is bent, or out of alignment.
Dec 04, 2013 | 1999 Chevrolet Malibu
My chevy maLIBU ALTERNATOR BELT SPINS THEN STOP CAR WON'T GO ANYWHERE
Vehicles: Chevy (GM) Malibu 2001-2005 3.1L SFI OHV 6-cylinder
Your battery has died since the alternator is not charging it. Jumping the car works to start the engine since the Malibu is using the energy of the second car to start and turn the engine.
Its possible that your belt may not be correctly routed or tensioned.
Check your 3.1L engine accessory drive belt routing. The arrow points in the direction in which the drive belt moves.
Fig. 1
Serpentine drive belt routing-GM 3.1L engine L/N bodies
Accessory Drive Belt Installation/Removal
GM 3.1L Engine
NOTE
Routine inspection of the belt may reveal cracks in the belt ribs. These cracks will not impair the belt performance. The belt should be replaced if the belt slip occurs if a section of the belt ribs are missing. A single serpentine drive belt is used to drive all engine accessories. All belt driven accessories are rigidly mounted with the belt tension maintained by a spring loaded tensioner. The indicator on the movable portion of the tensioner must be within the limits of the marks of the stationary portion of the tensioner. Any reading outside of these limits indicates either a defective belt or tensioner.
(1) Remove engine mount.
(2) Rotate the drive belt tensioner in a clockwise motion using a breaker bar or serpentine belt tool.
(3) Remove the drive belt.
Fig. 2.
Removal and installation of the drive belt - tool is shown installed on the tensioner. Arrow points to the power steering pump pulley.
To install:
(1) Rotate the drive belt tensioner in a clockwise motion using a breaker bar or serpentine belt tool.
(2) Install the drive belt. Connect the serpentine drive belt last to the power steering pulley.
(3) Install engine mount.
Dec 04, 2011 | 2001 Chevrolet Malibu
How do you change the serpentine belt chevy malibu 200
Well you don't have to remove the tensioner. If you look at it, you'll see a 3/8 square hole in the arm of the tensioner. Put a ratchet wrench, or breaker bar in the hole, and you can move the tensioner, it is only spring loaded. The diagram for how the belt laces in should be on the radiator core support. Lace it for the majority around, move the tensioner, and once you have the belt in line, release the tension on the tensioner arm.
Mar 26, 2010 | 2000 Chevrolet Malibu
How to replace timing belt
1999 chevy malibu 6 cyl dosen't have a timing belt just the serpentine drive belt the routing diagram should be under the hood
Aug 02, 2009 | 1999 Chevrolet Malibu
Serpentine belt broke
Get a 3/8s drive rachet put in
May 27, 2009 | 2005 Chevrolet Equinox
Need step-by-step instructions for installing a serpentine belt on a 6 cyl. 1997 Chevy Malibu.
The path should be listed under the hood on a decal, you will need a breakerbar and apropriate sized socket to compress the idler to put the belt over that pulley... just remember to put the breaker bar through the belt before compressing the idler assembly .
Apr 13, 2009 | 1997 Chevrolet Malibu
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
