Question about Philips Magnavox 51MP392H Rear Projection Television
Convergence amp if i am having trouble with the green amp, where can i buy a convergence amp?
  • csa0219 Sep 11, 2007
    WHAT IS THE CORRECT PART NUMBER? THANKS
  • csa0219 Sep 17, 2007
    i received the part in, the new part is on the tv, now the tv doesn't come on at all? any suggestions.
The amp is a chip of convergence amplifier chip. what is number painted on chip
Posted on Sep 13, 2007
    Genius:
  • 1,153 Answers
Www.bluestar-online.com
Posted on Sep 11, 2007
  • Lashawn Robinson Sep 13, 2007
    It should be STK-3** something like this
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have a JVC rear projection TV. from the frot it looks like the green color is sagging. we took off the back panel & the green lens... it looks like there is liquid under the lens & that it is...
The tv pictures cloudy or hallow?Yes,than the R,G,B CRTS Tubes guns require changing it coolant liquid.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to used.But just R,B,G colors lines mis alignment,colors shadows or 3D pictures,this problems is a convergence problems,it dead.The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 11, 2010 | JVC AV-65WP84 65" Rear Projection...
The picture just changed & the convergence is off with the picture bowing inward on top & bottom of screen & you see the image in red,blue & green. The auto convergence feature in the setup...
U have a soldering iron,solder wick or a desoldering pump,and solders?U know how to do soldering?U can fix this problems like about 20 mins.The convergence fuse part (FL231) is dead.Very common on this model of RCA tvs.U can buy this convergence fuse (FL231) at Ebay.com pretty cheap like $3+ shipping.There 3 small brown or pinkisk sqaure look like caps.The one in the middle is dead.But they're fuses located right side of the Flyback transformer,call a FBT(a big black block of transformer).Resolders the FBT too.
Jun 18, 2010 | RCA HD52W59 HDTV Projection Television
Picture appears blurry & subjects appear to have a green hue around them
Convergence is dead.U know how to solders?Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 25, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Red vert lines will not convergenge(sides) blue and green o.k.
your convergence output amps are done...
you have to do repair on the convergence output circuit, and inspect
the power supply for any damages.
Jan 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Image is showing with yellow & red shades
Ur convergence is dead.Must know how to solders?Replaced convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit.Shop will cost u $300 for parts and labors.
Jan 16, 2010 | Hitachi 61UWX10B 61" Rear Projection...
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
46 inch rear projection tv
The convergence modules are bad. They are made by SDK. ShopJImmy has them. Buy the kit because it has resistors and fuses that you may need to replace too. TV Parts Universal TV Stands DLP Chips ShopJimmy
May 23, 2017 | Hitachi 55FX48B 55" Rear Projection...
Samsung 42" projection green and only green out of focus? Bulb? Tube? IC?
Just had new Ic?? Meaning single?? The symptoms you're describing are a convergence failure. That unit takes Stk392-040 Sanyo Ics and be aware there are a ton of Chineese knock-offs out there that can cause you real trouble, so purchase them from only a reputable part distributor... You need to change both amps, test all 3.9 ohm-2w resistors in that circuit, like Rz123 and Rz124 and check Fd102 3.5a pico fuse for open. That's actually a really easy set to work on for convergence problems because the entire convergence amp board is easily removed.
Bill
Dec 10, 2007 | Samsung HCM4216W 42" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
