Question about Nikon COOLPIX L18 Digital Camera
Battery exhausted always showing on camera
I have L12 Nikon coolpix, after a month or so of use battery problems started sometimes the camera will work with a new set of batteries but very short time span and most of the time it comes up on screen as batteries exhausted.
  • Anonymous Mar 26, 2014
    battery will not charge
    President:
  • 1,223 Answers
Pls call canon it may be linked to this problem ur model is different i know but i think problem is same and they are responsible for that repairs
http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-L16-L18-Service-Advisory.page
pls remember to rate me FIXYA fo rhelp
Posted on Apr 13, 2009
    Problem Solver:
  • 6 Answers
Go into the camera's setup menu and find the battery type option.
Menu > Setup > Battery type
Change it to the type of battery you are using. The camera adjusts it's power usage depending on what batteries it is told are in it.
Posted on Aug 13, 2009
    New Friend:
    Problem Solver:
  • 3 Answers
It's the way that the camera reads the "energy left" that is the problem. Not all AA batteries are the same. Basically the default setting is (at least in the UK and US versions) set to ALKALINE AA batteries. If you are getting the "battery exhausted" message after putting new AAs in, chances are your batteries are not ALKALINE. You can either buy some new AA Alkaline specific batteries (eg: Duracell make them and they say specifically alkaline on the side). Or you can try to keep power on long enough to press MENU, then go to the "spanner" tab, then select "Battery Type", and select either Lithium AA if that is what you are using, or NI-MH versions. Stupide Canon don't tell you this anywhere, and I have already chucked one of their products because of it, when actually it was fine. (Jake, Newcastle, United Kingdom, December 2012).
Posted on Dec 26, 2012
  • jaketurnbull
    jaketurnbull Dec 26, 2012
    Sorry dissing canon and I meant NIKON of course.
Eat poop and cry then run into a wall and laugh
Posted on Nov 01, 2012
Exchausted battery in polariod camera
Are you sure that NEW batteries are good? sometimes bad, exhausted batteries go for sale as scam
Jan 26, 2014 | Nikon COOLPIX L12 Digital Camera
Its only 1 month that I have purchased my Nikon Coolpix s400, I usually used to charge it with the usb charger. but now its not charging when I insert theusb charger to it green light blinks only for 30...
Hi,the battery may have a dead one.,since you have a valid warranty pls ask for a replacement..
It is normal for the batteries since they have been fully tested under load..
sometimes it happens even with a famous camera maker as NIKON but remember batteries manufactured by another source,they just put a brand name whoever asks.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 03, 2011 | Nikon COOLPIX L12 Digital Camera
Nikon coolpix 4000 not charging its shows battery exhousted
Do you have store your Nikon CoolPix 4000 battery for a long time as the battery power exhausted? If so, it maybe have cause great damage to the Li-ion Nikon camera battery, you'd better store a Li-ion camera battery about 40% power and at a place about 25 degrees Celsius
May 26, 2011 | Nikon COOLPIX L12 Digital Camera
Blurry Photos & Batteries Exhausted
I may be able to help with the battery problem. Two suggestions: 1) With a WHITE eraser (preferably at the end of a pencil) rub the metal tabs in the camera that makes contact with the batteries. They may be slightly corroded. DON'T use a pink eraser. A fine sandpaper will also work, but is more difficult to work with inside a small space. 2) The metal tabs may be pushed in too far. You may need to pry them out with a small flat-head screw driver or needle nose pliers. Do so gently.
GregM23
Sep 07, 2009 | Nikon COOLPIX L12 Digital Camera
Problem with the Flash Light of Nikon COOLPIX L12 Digital Camera
I know some of the common things for the digital camera. I want you to try these.
-------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
-------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
* When shooting MPEG movies
* When set to the Twilight mode
* If an external flash is connected
The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
i hope this helps to fix your problem.
Thanx for using fixya.
Cheers.
Sep 27, 2008 | Nikon COOLPIX L12 Digital Camera
Battery Problem
ITS NOT THE BATTERIES -- check out the internet (google "nikon coolpix battery exhausted" and you'll see hundreds of people are experiencing this glitch. best fix i've found so far: remove batteries and memory card, then replace batteries and try again. Maybe firmware update works too, but this fix is not confirmed.
Jun 24, 2008 | Nikon Coolpix L11 Digital Camera
Battery Problem
These cameras have a internal battery that holds data for the camera to keep its settings. These batteries can be replaced but the camera has to be disassimboled to change it they should be able to be changed at a local camera shop pretty cheap.
Mar 21, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
1,967 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
