Question about Yamaha RX-V461 AV Receiver
Sound distortion on Yamaha Receiver RX-V461
Since purchase there has always been a sound distortion when running through the HD set top box whilst in dolby digital. However this is not the case when run in PCM.
I have had a couple of different brands of set top boxes and it is always the same case, either optical or coaxial.
When watching DVD's it is intermittent when coming through in dolby digital.
Is this a common problem with the RX-V461?
5 Suggested Answers
  • 151 Answers
SOURCE: no dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
CABLE GUY.
Posted on Jul 12, 2008
quang123
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
Gurudristi
  • 98 Answers
SOURCE: HK AVR35 Receiver - Dolby Digital not displaying or working
If the display is showing as optical/PCM, then the input signal is in 2 Ch Stereo.
Try to change the signal from the source i.e. the DVD player, On the remote, go to audio and press repatedly , the audio would change from audio1, audio 2 .... and so on, depending upon how may have been recorded on the DVD. If the DVD is recorded in Dolby Digital, it may show the audio as Dolby Digital 5.1 on you monitor. Once this setting has been done, your Receiver should automatically detect it and show as Optical/Dolby digital.
Please let me know if you you solve your problem.
Posted on Mar 13, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a PS3 hooked up via HDMI to my Yamaha
Your PS3 probably has a setting for what digital bitstream it produces. Check it out. Dolby Digital is probably what you want.
Posted on Dec 27, 2009
What are the surround sound settings for a yamaha rx-v461?
It has many, depending on the your speaker configuration, the source hardware and the source material...
Read the manuals...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-V461-Receivers-manual/id/2526ci760/t/2/
May 07, 2011 | Yamaha RX-V461 AV Receiver
RX-V461 Yahama Receiver is hooked up to TV with optical THX cable but can't get sound. Tuner on receiver plays and all speakers work perfectly for radio listening.
double check input used on amp and make sure u use the auto format decoder fuction on your amp ok if it has none than turn it on optical digital ok that should work for you :)
Feb 10, 2011 | Yamaha RX-V461 AV Receiver
Different sound levels dvd and cable hdtv yamaha htr-6130
Well, first of all, the method you are using is the lowest quality. You should upgrade to a toslink(digital optical cable) or a digital RCA cable. The toslink is the best all around. But it is normal for some devices to have higher sound output than others.
Jan 08, 2009 | Yamaha RX-V461 AV Receiver
Problem hooking up my Yamaha RX-V461 to my PS3
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
I have a RX-V461 AV Receiver for my Samsung HDTV.
I don't have manual here, but try to go to Setup menu / Speaker setup / Manual Setup / Config and check if rear speakers are NOT set to None.
Nov 19, 2008 | Yamaha RX-V461 AV Receiver
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
Help setting up Yamaha RX-V461
Typically, only stereo inputs exist on any comsumer-grade receiver, and the actual decoding to 3, 4, 5, 6, and even 7.1 is done internal in the receiver. When a "placement" signal is detected by the receiver, the sound is routed to the correct speaker.Please refer to a user manual
..accordianman
May 01, 2008 | Denon AVR-4802 Receiver
Rx-v461
but does it sound normal in all other sources?
Feb 18, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V461 AV Receiver Logo
283 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
