Can't login to 192.168.1.1
I got ADSL wireless Ethernet router (caremo) After log in using 192.168.1.1 to gateway. im still can't open modem setup.
username ; admin
password: admin
Error message: bad username/password.
Sorry my english language very lack.
    Scholar:
  • 30 Answers
Hi the username and password for the router has been changed while the previous configuration.If you can call your service providor they should be able to provide the same.There are other some common usernames and passwords which you can try.
username:admin
password:epicrouter
*OR*
username:admin
password:password
*OR*
username:password
password:password
*OR*
username:snowflake
password:password
*******Alternatively you can also try to reset the router to its default settings by pressing the reset button at the back of the router(however this should be the last step of action).
Posted on Apr 13, 2009
  • Silki Garg Nov 23, 2010
    I think the username and password combination is correct. The same is also mentioned here.http://defaultpasswords.in/caremo-router...
Login optus
The ID/password that you should use are printed on the bottom of the router -- using your E-mail ID/password will not work.
Aug 14, 2014 | 2wire Wireless-G 802.11g ADSL Gateway
I dont know how to get wireless internet
Check the ADSL or cable modem status light. If it is solid green, it indicates that your ADSL/cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring.
When done, log in to the web interface of your router device and check if it can obtain the IP address from your ISP or not.
If you see 0.0.0.0, the router is not obtaining the IP address. It can happen due to various reasons. Contact your ISP and ask for the details including username, password for PPPoE etc. and try to connect to the Internet again afterwards.
You may also need to configure the default gateway settings also. To configure your router device as the default gateway, reboot your PC. When done, open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway
If you are still unable to browse the Internet, ping your router's connection to the PC.
The Request timed out error can occur due to two things: (1). incorrect physical connection between your router device and the PC or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
When done, check back if you can browse the Internet or not.
***If you need any kind of technical assistance you can contact support cell
Jan 21, 2013 | Computers & Internet
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
I need connect a wirelees router a this modem,u help me plzzz
most wireless routers are setup for cable modems out of the box all you need to do is run an Ethernet cable from your modem to your wireless router. you can then access your wireless router by the ip address and a pc hooked you directly to the router.
Feb 28, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Apr 02, 2010 | Computers & Internet
I no longer have the install software, how can I set up wep for my unsecured router?
You dont need the Software to do this - you can setup routers manually - by logging into them - to start lets find the correct online manual - this is the start of getting an online manual http://www.zoom.com/techsupport/adsl/adsl_5590cf.shtml Page 28 - shows how to setup the wireless security also shows details on page 13 how to login to the router - using 10.0.0.2 in an internet explorer address bar - now these are quite OLD settings - so they may still be valid or a firmware update may have changed - to check - on the PC do the following start>run {vista/7 search box}>CMD>ipconfig --- you should see a number next to default gateway if its 10.0.0.2 then thats the same as the manual - but it may start 192.168.x.x ---- so that maybe the number you need to enter into the webpage NEXT - the default username and password --- from page 14 of manual then goto the wireless section and set the WEP security you require
Mar 20, 2010 | Zoom X6 Adsl Modem/router Rohs...
How to instal D-link
Read the "Quick Install Guide" that came with the router.
Or, connect an Ethernet cable between your ADSL/Cable modem to the 'WAN' port on the router.
Connect another Ethernet cable between LAN port #1 on the router and your computer.
Turn the router on.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Look for a line like:
Default Gateway . . . . . . . . . : 124.168.136.111
Start Internet Explorer.
Type http://124.168.136.111 and press ENTER.
Login to the router's web-interface.
Run the "Wired Setup Wizard".
Run the "Wireless Setup Wizard".
Nov 16, 2009 | D-Link DIR-655 Wireless Router
Computers & Internet Logo
3,391 people viewed this question
David Payne
David Payne
