Question about Motorola Mobility HS820 Consumer Headset
My Phone Does Not Locate My HS820 Headset
My phone does not locate my headset even though I set it to the pairing mode which is when it has the blue light on constantly. I've also checked with my computer and it won't locate the headset either.
  • 1 more comment
  • brisko Apr 13, 2008
    i dont know how to use it.
  • Danhdo Jun 08, 2008
    how to setup motorola HS820 headset with Samsung SGH-a737 Cell phone
  • john horse Apr 18, 2009
    Everything goes fine until the password for the new device founded is requesting....what can I do? I have a BB pearl. Thanks
Try the following:
1) Make sure the HS820 is fully charged up.
2) Remove the battery and SIM card from your phone for about 1 minute and put them back in.
3) As soon as your phone is booted up, access the "find devices" function for adding your HS820.
4) Hold the HS820 button down until the blue light is solid.
5) Then do whatever your phone requres to "search for devices."
6) Here's the key: as the phone is searching for devices, PHYSICALLY TOUCH touch the HS820 to the phone.
I couldn't get my HS820 to synch with my new Blackberry Curve the normal way and ultimately got it to synch by going through this process.
Posted on Jul 26, 2008
    New Friend:
Many thank Csdemos. I'm finally able to use my headst thanks to you.
Cheers :-)
Posted on Apr 12, 2010
This worked for me too!! I've been using my bluetooth device for over a year, and last night it decided to no longer connect to my phone for some odd reason. I tried connecting it for over 2 hours and had no luck until I found this page. And now it works!!! All I had to do was hold the on button on my bluetooth until it turned a solid blue color. Thanks, Csdemos! You're a genius! :)
Posted on Oct 28, 2008
GREATTTTTTTTTTTTTT Thanks it works for me with a Nextel phone and it works great
Posted on Oct 14, 2008
You are a Genius!
Posted on Oct 31, 2008
6ya staff
SOURCE:
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
Apr 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Reprogramming bluetooth
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Mar 15, 2009 | Plantronics Explorer 220 Bluetooth Headset...
GE Bluetooth connectivity
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 26, 2008 | GE Bluetooth In-ear Headset Wireless...
NOT PAIRING ANYMORE
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS820 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Mar 15, 2008 | Motorola Mobility HS820 Consumer Headset
Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Jan 14, 2008 | Motorola Mobility Bluetooth Hands Free...
Motorola hs820
you have to press and hold the button for a few seconds, it will then flash 3 times and then stay solid blue, this is now in pairing mode, get your phone to find the headset and then pair usually with the numbers 0000, then thelight will flash then it is paired.
Sep 30, 2007 | Motorola Mobility HS820 Consumer Headset
Samsung e900 pairing
if you press the power button and hold until the blue light stays on the set is then in find mode, at this point use your phone to search for new devices and when it finds it it will see the HS820 and probably ask for a pin number this is 0000, when they are paired the blue light will flash and then flash intermitently from then on.
May 26, 2007 | Motorola Mobility HS820 Consumer Headset
Headset will not pair up eith razr phone.
Have you pressed and held the button on headset until light is always on, as this is in pairing mode, then search devices with your phone.
Jan 15, 2007 | Motorola Mobility HS820 Consumer Headset
Bluetooth headset
Put your phone in "Discovery Mode" Most phones can get there by going to Menu/Settings/Tools/Bluetooth. If you don't have Bluetooth option here, your phone probably doesn't have bluetooth capability. Then, on your bluetooth hold down the big button until the blue light stays. If you have a bluetooth that you flip, make sure it is closed first, press down the button until the light appears and then flip the bluetooth open. that should leave the light on. as the light stays on and your phone on discovery mode they should be able to locate each other.
Dec 25, 2006 | Motorola Mobility E815
Motorola Mobility HS820 Consumer Headset Logo
566 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
