CPU Overheating My ASUS X51RL is 1 and a half year old. It's working in almost 24/365 mode all this time. So, it's have overheating now. I'm looking for service guide for its disassembling and cleaning. Thank you! P.S. Sorry for my English.
  • serge1961 Apr 13, 2009
    Thank you for this helpful solution, but I still need a service guide.
  • 21 Answers
While I am not familiar with this exact model, (is it a laptop or desktop?), Overheating quite often is a symptom of not just needing a cleaning but of a fan failing, I wish I could tell you what exactly to do to open your unit up to clean it... When you do AVOID using any canned or compressed air on the cooling fans, as this will spin them up to speeds far faster than they are designed for, and if they are failing this can take them over the edge.
Posted on Apr 13, 2009
Http://www.facebook.com/video/video.php?v=2742991141068&saved
Look my video of my laptop ASUS X51RL. And read the info.
The basic idea is to add one more fan for the GPU, new thermal paste and clear the CPU cooler. And finaly 4 objects in 4 corners of laptop for better flow of air.
Posted on Nov 30, 2011
How do Ifix an overheating problem on a eee 1015pe
The most easy way is to buy a notebook cooler stand. If it's overheating again you must open the case and clean cpu cooler and put some thermoconductor paste on cpu and graphic card.
Nov 17, 2012 | ASUS Eee PC 1015PE
My computer is restart when open some software together, like Mozilla and media player....and make call in Skype etc.... config.. asus p4v8x-x mother board g5500 nvidia graphics card 1 gb...
The problem can be overheating of CPU. Which can be easily diagnosed by download a free software SpeedFan, which will tell your CPU's temperature.
I would recommend you to download the software and post your temperature readings by commenting on my reply.
If the CPU is really overheating, I will provide you with further information on how to solve that.
Click Here to download speed fan: http://www.almico.com/sfdownload.php
Nov 22, 2010 | ASUS P4V8X-X Motherboard
My acer extensa 5220 is overheating even if only winamp is running.before that wasn't a problem. laptop is 1 year old, and cooler is working properly
Either CPU is faulty, or the heatsink has lost aderence with the CPU surface or coolin power.
Atandard procedure is refitting or replacing cooling fan, in some rare occasion is the CPU, but that is uncommon and can't be tested.
Another possible cause is the temp sensor on the motherboard that is faulty.
first ensure that is overheating and check temp sensor using SpeedFan - Access temperature sensor in your computer.
Good luck.
G.
Aug 03, 2009 | Acer Extensa 503T Notebook
Automatic shutdown without notice
its because CPU get hot. check the cpu fan or
clean that, heatsink of cpu fan must be clean and closed to cpu.
Aug 01, 2009 | Acer Aspire 5315 Notebook
Monitor freezing and screen crackling.
Sounds to me like your graphics processor is overheating, or possibly the cpu. Are any of these components new? you may want to make sure that they have proper cooling. On the other hand if its a few years old, may jus need to replace the overheating component.
Mar 15, 2009 | Acer Aspire M1640 Refurbished Intel...
I HAVE P5RD1-VM ASUS BOARD NOW COMPUTER STARTED PROBLEM
several reasons for this.
1:) CPU Overheating.
2:) RAM Overheating.
3:) Motherboard Component Overheating.
4:) FAN not operating correctly.
These are a few things that can shutdown a computer after a few minutes, also viruses/trojans et,c.
can shut off hard-drives. and even instruct the bios to change settings.
Check that the CPU And case fans work correctly.
Mike @ compurepair.
Nov 17, 2008 | ASUS P5RD1-VM Motherboard
I formated my computer....a asus p4b 1.5 mhg....turn it on and off while re-installing all of my software. once done i turned the puter off to clean the cpu fan... since the puter would not turn itself...
hi hope this helps.
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Oct 18, 2008 | ASUS Computers & Internet
Overheating
If you?re not sure if your computer is overheating and you don?t want to check manually, you can use one of the monitoring softwares that check that for you. (for example- ASUS PROBE 2 which came with my motherboard).
Feb 22, 2006 | Epson >>> IM800 DARK GRAY 733 MHZ CPU...
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
362 people viewed this question
David Payne
David Payne
