Monitor shows nothing on screen, power button on solid, none of other buttons respond.
Hooked up monitor to computer, then turned everything on, computer, monitor etc. monitor's power light came on, flashed for a few seconds and then became solid, but nothing showed on screen.
  • ERIC BAKER May 11, 2010
    Have you tried looking for loose connection's inside your pc behind the access cover?
    Genius:
  • 2,785 Answers
Plz try by removing the connector of the monitor from the back of cpu while keeping your monitor power on. if you get any message in the monitor then your monitor is ok. then open your side cover and try by resiting the ram, you have to swithch off your pc before opening your side cover. If you dont get any thing in the monitor then *********** board is having problem
Posted on Apr 13, 2009
Lg w2343t monitor
try monitor on a different working desktop to see if it works, both on the external and internal video card ports. If screen menu buttons fails to respond, fault is either on menu buttons or you may have a burned out lcd screen, try a different monitor on your desktop pc to check its functionality. Monitor probably needs replacement.( It might not be burned out for you mentioned "no signal" error message appeared on screen, have the screen menu buttons checked)
Dec 28, 2013 | Computers & Internet
I have a SyncMaster 2232BW monitor hooked to my pc, the blue power button comes on when power on, my computer POST appears for about a second then vanishes leaving only bright lights on display, none of...
Seems that you may have the wrong type of video selection theres a button for auto sensing the type of connection. if your video cable is blue then you have an analog connection, white video cable is a digital connection you just need to ensure that the monitor is set to the proper selection.
Sep 05, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I am unable to turn the screen off and the Menu button, actually, none of the buttons on the screen works. It constantly shows the Volume in the centre of the screen and I cannot remove it. Please help! ...
If none of the button are working then it could mean that one of the buttons is stuck or there is an issue with the board on the monitor itself.
Unplug the monitor from power and the computer. Make sure none of the buttons are stuck down, plug only power back in to the monitor and see what it shows. Plug it back into the computer and check to see if the problem returns
Mar 07, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
My monitor is not responding. I have a blank screen and my power led is flashing green, none of the front monitor buttons are responding, not even to turn of power. Cannot access menu as I have blank,...
Hi Cat, You can try removing the data cable of your monitor, the one connecting to the back of the tower/computer. If there are no issues on the monitor, normally you will be getting the power self test which is indicated by three vertical colors on the screen (Red, BLue, Green). If you dont see the power self test, it may be a problem with the monitor. YOu may want to try using a different monitor to isolate issue if available
Oct 27, 2010 | Acer AL1912 19" LCD Monitor
I have Dell 2000sp monitor that was working fine. The none of my internet pages would load. I thought it was my connection and restarted the computer, but now the monitor is on, but the screen is black....
The only problem if it is the monitor that it could have is the connection. Check see if you cable is kinked coming out of the computer, and is conected properly. Usually everything else would be a problem with the computer.
You can also try hitting the buttons on the monitor to see if stuck.
Nov 05, 2009 | Dell 2000FP 20.1" LCD Monitor
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
No display on screen and solid amber light on pcs' power button
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
To el_cid_132: Did you mean to say a solid amber light on the MONITOR's power button? If, after all you've tried with the computer, you still have no display, it's a pretty good bet your monitor is bad. Try another monitor to verify the computer function. Take a close look at the pins in the monitor's input cable plug. They are pretty easy to bend, and you may have one not making contact.
To Jaffe: It's a simple job to remove the hard drive from your laptop and hook up to another computer to copy anythig off that you want to keep. I don't know what a shop in your area would charge, but it should be reasonable. As for replacing the system board, a quick Google search for "MX6448 motherboard" turned up several sources, price range $250-$300. Usually it's not worth putting a new system board into a laptop unless it's a very high-end model. You can buy basic laptops now for around $400, and you'd be getting brand-new with a warranty.
Jun 05, 2008 | Gateway (4000779) Motherboard
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
