Question about Intel D845GVSR Motherboard
My cmd command never run, there is volume problem, I think mother board board problem is there what i do?
  • 88 Answers
Dear,
As I know it is not a problem of motherboard. Please be sure
1.Your System is loaded with latest Antivirus. Most of the time such problem are due to virus activity.
2. If not, before installing the antivirus backup your data.
It will solve your problem.
Regards,
Rakesh Kumar
Posted on Apr 13, 2009
    Guru:
  • 846 Answers
You may encounter to other similar error messages, but with differentfile names config.nt and Autoexec.nt. This issue may occur if one ormore of the following files are missing or damaged:
Config.nt
Autoexec.nt
Command.com
try this.....
http://windowsxp.mvps.org/utils/Dosfiles.zip
if it works than ok other wise install XP SP2
http://www.microsoft.com/downloads/details.aspx?familyid=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en
Hope It Solved Your Problem
Good Day
  • 700 Answers
If it is in windows environment
Consider this ; you might been infected with a virus. Update your definition files then scan.
Or search for that file cmd.exe if it is deleted or the being hide/block by the virus.
  • 43 Answers
Try to ran it from
c:\windows\system32\ cmd.exe
rightclick on it and select run as.
if its not working from there then in that case your system profile may be corrupted.In that case you need to reinstall windows.
Remove write protect from pen drive
1. Start > Run -> type "CMD" and press enter
2. type< diskpart
3. type< list volume
4. type< select volume # (# is the number of the USB HDD you've pluged in)
5. type< attributes disk clear readonly
(If you need help while typing commands then type "HELP FORMAT" on command prompt)
Aug 27, 2013 | Kingston DataTraveler 101 G2...
Checkdisk /r will not run due to insugfficient priviliges
You should run the command from an Elevated Command Prompt. Running the Elevated Command Prompt is running the Command Prompt with administrative privileges. To run elevated Cmd, right click on Command Prompt or cmd and select run as administrator.
Hope this helps, Mrityunjay.
Jun 27, 2012 | Samsung N150 Netbook
Hanging after memory count
Sounds like your boot files are corrupt or some system files are corrupt. You can try clicking Start/All Programs/Accessories and look for the CMD (command) Prompt. If you don't see it you can click the RUN and in the box type cmd and press enter. A black window should appear allowing you to type in commands. Type the following command: sfc /scannow (which is the system file checker and let it run). When it finishes, try rebooting. If you still have the problem type the following command: chkdsk /r
The Check Disk command might tell you that volumes are locked or that it will run the next time you restart your computer. In either event it's safe to click yes or ok to let it run. It will run for an hour or more and you will notice the percentage of completion going from high to low but that is ok. Just be patient and let it run until it finishes then reboot.
Mar 09, 2012 | HP Compaq dc7600 PC Desktop
Can not get hard drive to convert from fat32 to ntfs
Convert FAT32 to NTFS In Windows XP:
  • Click Start -> Run
  • Enter "cmd" into the text field labeled "Open".
  • Click OK button
  • If you want to convert drive D (D:), enter the command "vol d:" in the command window, to find the volume label for the D: partition
  • Then enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS
  • When prompted, enter the volume label for the partition
Convert FAT32 to NTFS In Windows Vista and 7:
  • Click Start sphere.
  • In the Start Menu search box, simply enter "cmd" and hit enter.
  • If you want to convert drive D (D:), enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS that way can be confusing so an easier way is to download a free software heres the link http://www.partition-tool.com/personal.htm
Oct 20, 2010 | Maxtor Hard Drive
After i use partitionmagic to merge drive (D & E ) and rename to D the Drive D disappear and wheni check error it shown Error #1520 Externak attribute header mismatch How to solve this problem
This error occurs when the PC hard disk has error(s) and your using particular software as you have mentioned like partition magic. To solve this problem shut down all your applications and running software.
If you are using Windows XP
Go to Start>Run>In the run box type cmd
A black Window will open its called CLI or Command line interface. In this Window run the following command on the C partition CHKDSK /F if the message appears"Check the system next time the system restarts (Y/N) type "y". then type "d:"to enter D partition. When the D prompt (D:) appears type the same check disk /Fix command which is "CHKDSK /F" and hit enter.
Similarly repeat this command for all the partitions.
If the this option statement appears "would you like to force dismount on this volume? (Y/N). Select "Y".
If you are using Windows Vista or Windows 7 then when you perform the first step which is Start>Run>In the run box type cmd before hitting enter in the start menu look for a small black icon named cmd on the top of the start menu. Right click it and select "Run as Administrator" When the black cmd window opens all the steps after that are the same as described above.
Good Luck!
Jul 29, 2010 | Computers & Internet
Can read the drive, directory corrupted
just run chkdsk command to recover your directory structure,
Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Apr 22, 2010 | Hitachi hts548080m9at00 80 GB Hard Drive
Booting problem.....
if you still having booting problems, you can do this suggested steps:
Insert the Operating System CD before pc reboot
Try to boot to safe mode with command prompt by pressing F8 repeatedly , select "safe mode with command prompt " option then hit ENTER, then run this command ...
Then follow these guidelines:
Hope this help...
Apr 18, 2010 | Lenovo IdeaPad Y510 Notebook
My external hard drive does not show up when
in run windows type cmd and press enter
you will be in dos mode in that go to e:\ and press enter
in e:\ drive type the command chkdsk /r/f and enter
it will says to do later on press y and exit
and restart the system .it will fix the problem
Nov 21, 2009 | Computers & Internet
Vesta mother board installation
this will happen coz driver non compatibility with Vista os, locate drvers for vista online, will get it
Mar 23, 2009 | Computers & Internet
Turbo C is not running.
sir
First Give full details about *********** Board for exam: 845 gvsr , Asus, Gigabyte, Mercury,
ok any way i think command is running Proparly or not working telme ? id : uday_uday2004@rediffmail.com
see this command : go 2 run type cmd next give path your soft ware whare is thair for : ex: c:\turboc2\tc c:\turboc\tc
your folder name give mustend shoud folder Name (turboc2 or turboc) ok
byy good luck ----vote for me --------
Apr 03, 2008 | ASUS M2N-MX Motherboard
Intel D845GVSR Motherboard Logo
76 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
