Question about D-Link DE 1824i (DE-1824I) Networking Hub
Reset speed from 10Mbps on 100Mbps (D-Link DE-1824i)
Guys how is possible reset speed from 10Mbps to 100Mbps at D-Link DE-1824i. It was advertised as 100Mbps hub.
Regards Tony
  • 83 Answers
Tony,  I was looking at the specs and found these lines :- Choices of 12 and 24 10BASE-T ports per hub
1 100BASE-TX port (for connection to 100BASE-TX hubs) Which is saying that the user/pc ports are fixed 10Mps and there is one 100Mbps uplink port to connect two hubs together.
http://www.dlink-intl.com/Products/Hubs/DE1824.htm
Posted on Apr 24, 2009
My lan card automatically disables and enables and is connects at 10 Mbps rather 100 Mbps
Please check specifications of the network hub you are using. If this is only 10mbps, then your D600 will also connect at the same speed. If your hub is already 100mbps, and considering that if automatically disables and enables, then the network adapter of you laptop is probably defective. Try updating the firmware of the unit and also the device drivers, this may also possibly correct the problem. You may also want to consider buying a USB network card or just replacing the laptop if the above does not work.
Jan 10, 2011 | Dell Latitude D600 Notebook
My connection through my 2wire pc port phoneline is extremely slow, the internet is very laggy, yet all the computers connected directly to the router through ethernet cables are very fast
This is because the adapter is ONLY 10Mbps you need a higher one 100Mbps or even 1000Mbps... That adapter is too old to be used on a high speed network, replace it with a faster one.
Mar 06, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
One light is out on my linksys usb200m
It depends on which light is OFF: Below are the LED indicators:
100/ACT Green. The LED lights up when there is a connection to a 100Mbps network. It flashes when the computer is transmitting or receiving data at 100Mbps.
F/H Green. The LED lights up when the Adapter is operating in fullduplex mode. The LED is off when the Adapter is operating in half-duplex mode.
10/ACT Green. The LED lights up when there is a connection to a 10Mbps network. It flashes when the computer is transmitting or receiving data at 10Mbps.
Dec 04, 2009 | Linksys USB200M USB 2.0 Network Adapter
Usb speed problem
I am not sure you can fix it there or different USB types.
  1. USB 1.0 Specified data rates of 1.5 Mbit/s (Low-Speed) and 12 Mbit/s (Full-Speed).
  2. USB 2.0 Added higher maximum speed of 480 Mbit/s (now called Hi-Speed).
Only certian motherboards have the USB 2.0..
That would seem to be the issue..
Sep 14, 2009 | Computers & Internet
Moderm speed
Your question is garbled but I'll try to explain some of it.
Your ethernet LAN jack on your computer is probably 100mbps and the ethernet LAN jack on the modem is also 100mbps, connect them together and it will tell you that it is connected at 100mbps because they are both working at the same speed.
As for the other connections, you are mixing usb and ethernet up so much that I can not tell from what you are connecting together.
My lan ports only output 10mps
1. Click Start => Settings => Network Connections
2. Right click on your LAN connection and click properties
3. Under General Tab, click the configure button to configure your Ethernet adapter
4. In the dialog box that appears, click the Advance Tab
5. Under Property, scroll down to SPEED and Duplex and set the property to 100Full
However, you can set it to its default value: Autonegotiation. It you have switch or hub that runs on 10mbps, it should run at 10 and not 100mbps
Jul 30, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Reset pswd
You can reset the unit to factory default... this will set the password to factory settings.. then you can create new password
Jun 16, 2009 | IBM Nways 8275 Model 217 Networking Switch
Slow speed of data transfer 10 MBPS instead of 100 MBPS
the switch which ur pc is connected might have been set to 10 mbps ...if the switch is managable cisco switch try changing the port setting to 100mbps full duplex
Apr 18, 2009 | D-Link DE 824TP (DE-824TP) Networking Hub
Slow connection w/ FiOS
You may not be interpreting the LED correctly. The Link LED goes on to indicate a physical connection (if the Link LED is out, the cable is damaged or disconnected), but the 10/100 LED only illuminates when there’s a 100Mbps connection. The LED will remain off when the connection is only 10Mbps. Here’s how to quickly determine the speed of your connection. If the 10/100LED is off, there’s a slow connection. If the LED is on, there’s a fast connection.
A fast (100Mbps) network connection requires that both ends of the connection support 100Mbps communication. So, if the 10/100 LED on your hub is dark, chances are that your PC’s network adapter (or NIC [network interface card]) is only operating in the 10Mbps mode. Check the NIC in your Device Manager Network Adapter entry and look for any 10/100 designation. An older 10Mbps NIC may need to be upgraded for 100Mbps operation. If it’s a 10/100 NIC, refer to the PC’s documentation and check the NIC settings to make sure it’s not locked in the 10Mbps mode. Set the NIC to a mixed or 10/100 mode so that it can adapt automatically to establish the best possible connection.
Mar 06, 2008 | Acer Aspire 3004WLCi Notebook
Slow internet
I suspect that the DE-528 (discontinued card by the way) is only a 10 mbps card. Unless you are doing some heavy duty video the card would be fine. Otherwise replace it with a 100 mbps card.
Feb 08, 2008 | D-Link DE-528 Network Adapter
D-Link DE 1824i (DE-1824I) Networking Hub Logo
819 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
