Question about GPS
Electrostatic precipitator Required Specification and price only this part Choke Transformer Part no 22588260 More details for assembling this PCB. FLS Miljo Electrostatic precipitator (PC Board micro processor for inter face LYNGSO CARD NO CS28.1) Soren T.Lyngso Type 22588360 V07 9538 Denmark Part no 22588260, Type 022588360 V07, S N: 4695600175, GPV ELBAU ELECTRONICS, Card No. 221118-8907,Es 28.1
map9966
  • 2351 Answers
SOURCE: Best Graphics card for my Pc
Hi Dr,
Best video card for you're Intel D845GVSR would be XFX GeForce 6200 Video Card - 512MB DDR2, PCI, DVI, VGA, TV Out. XFX carries a Lifetime Warranty.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3735736&CatId=319
Enjoy!
Mike
Posted on May 09, 2008
jonb3838
  • 237 Answers
SOURCE: ASUS P5S800-VM mother board V Asus EN9500GT graphic card
you would need a new mother board or change the graphics card
Posted on Feb 11, 2009
  • 39 Answers
SOURCE: KP500 mobile and when add a micro SD card it does not detect it
When you look at the phone, and the screen is facing you, the microSD card's contacts should be facing back of the phone. And notice that LG KP500 does not support larger micro SDs than 8 GB.
Posted on Mar 14, 2009
SOURCE: Micro sdhc card reader will not recognize 8gig card
You problem is most likely to be the fact that your micro chip is a HC chip. HC chips have a new program that is not backwards compatible to regular sd host ports. This is a simple fix, however. If you don't trust downloading programs for it on the internet, just go to target or walmart and get a USB SD card reader, and a SD adapter if you don't already have one. The usb adapter should only be like $10 at most.
Posted on Jun 15, 2009
  • 41 Answers
SOURCE: Music from Micro SD card will not show up on "My Music"
check its the right type of music file for the blitz, mp3, wav and so on then send those type of files
Posted on Sep 08, 2009
Must I register a transformer with an unknown PCB concentration?
If you do not know the PCB concentration of a transformer that is in use, apply the concentration assumptions for use in §761.2. If you are required to assume that the transformer contains $500 ppm PCBs, you must register it. http://www.qjpcb.com/ whatsapp:+8618688621379 http://www.qjpcb.com/ Skype : wang.michelle35
Sep 08, 2016 | XPLOSIV Pop Cap Games - Con/Term...
When I take a transformer out of service, must I notify EPA?
You are not required to notify EPA that the PCB Transformer is no longer in service. However, you may do so and ask that the transformer be removed from the database.
Jun 12, 2016 | ASUS Transformer Book T100
Jun 02, 2016 | Smeg Repair Pcb / Module Dw1612 Dwi612c
The USB of my Samsumg LED HDReady 32" Tv is broken. Can it be replaced? If yes, how?
The Main PCB will need to be replaced, part# depends on your model#.. ( http://www.samsungparts.com/partslist.aspx?Catalog=Parts_and_Accessories&Category=LA40B530P7R ) See Below
BN94-03079U
MAIN PCB
$116.79
Nationwide BO, Usually ships within 4-6 weeks
BN94-02930L
MAIN PCB
$116.11
More on the way, Usually ships within 3-5 business days Specification
LA40B530P7RXZN
ASSY PCB MAIN Specification
LA32B530P7RX
ASSY PCB MAIN
Nov 25, 2013 | Samsung LA40B530 40 in. HD-Ready TV
Error e0610096 in canon 1140
The Service manual say:
E061 is an error code associated with the mechanism controlling the surface
potential of the drum, and points to the following:
(The notation "xx" of detail code indicates the color of the developing
assembly; e.g., xx=01: M, xx=02: Y, xx=03: Y, xx=04: Bk.)
Detail code: 0096
Description: Vd2 is 550 V or less.
Possible cause: The Vd2 lower limit is reached
Step 1
Checks: Is the setting of
COPIER>ADJUST>V-CONT-M/C/
Y/K in service mode identical to the
settings recorded on the service label?
Yes/No: NO
Action: Enter the settings from
the service label newly.
Step 2
Check the detail code in service
mode (COPIER>DISPLAY>ERR).
Is it 0000 or 0001? YES Go to step 3.
Is it 0010? YES Go to step 4.
Is it 0020? YES Go to step 5.
Is it 0030, 0031, or 0032? YES Go to step 9.
Is it 0040? YES Go to step 12.
Is it 0050, 0051, 0052, or 0053? YES Go to step 16.
Is it 0070, 0071, xx80, or xx81? YES Go to step 19.
Is it 0060 or 009x? YES Go to step 20.
Step 3: Potential sensor unit
Checks:
Turn on and off the power switch.
Does LED1 on the potential
measurement PCB remain on
during potential control?
NO - Replace the potential sensor unit.
YES - Check the wiring from the
DC driver PC to the potential
sensor. Turn off and then on
the power switch; if the error
is indicated once again, go to
step 2.
Step 4: Pre-exposure lamp
Checks:
Does the pre-exposure lamp turn
on during copying operation?
NO - Check the wiring from
the DC driver PCB to
the pre-exposure lamp;
if normal, replace the
pre-exposure lamp.
YES - Check the potential
sensor unit. Turn off and
then on the power switch;
if the error is indicated
once again, go to step 2.
Step 5: Primary charging assembly
Is the primary charging assembly
connected properly?
NO - Connect the assembly
properly.
Step 6: Primary charging assembly
Is the primary charging wire
broken or soiled?
YES - Clean or route the charging
wire once again. Turn off and
then on the power switch; if
the error is indicated once
Step 7: Primary charging assembly
Are there traces of leakage on the
primary charging assembly?
YES - Replace the primary
charging assembly.
Step 8: High-voltage cable
Is there electrical conductivity
from the primary charging wire to
the high-voltage transformer
(HVT-DC)?
NO - Check the primary highvoltage
cable.
YES - Replace the HVT-DC
PCB. Turn off and then
Step 9: HVT-DC PCB
fitted properly?
NO - Fit the assembly
properly.
Step 10: Primary charging grid plate
Is the grid plate of the primary
charging assembly mounted
properly?
NO - Mount the grid plate
properly.
Step 11: High-voltage cable HVT-DC PCB
Is there electrical continuity from
charging assembly to the highvoltage
transformer (HVT-DC)?
NO - Check the grid highvoltage
cable.
Step 12: Post-cleaning charging assembly
Is the post-cleaning charging
assembly fitted properly?
properly.
Step 13: Post-cleaning charging assembly
Is the post-cleaning charging wire
broken or soiled?
YES - Clean or fit the charging
wire properly.
Step 14: Post-cleaning charging assembly
Are there traces of leakage in the
post-cleaning charging assembly?
YES - Replace the postcleaning
charging
assembly.
Step 15: High-voltage cable
assembly to the high-voltage
NO - Check the post-cleaning
high-voltage cable.
Step 16: Laser exposure system
Is the movement of the laser shutter
normal?
NO - Check the shutter
assembly
Step 17: Laser exposure system
Is the dust-proofing glass or the
bending mirror soiled?
YES - Clean it.
Step 18: Laser exposure system
Is the laser power normal? (See the
descriptions given for how to adjust
the laser power.)
NO - Adjust the laser power.
If output is absent,
replace the laser unit or
the laser driver.
YES - Check the
photosensitive drum for
grounding; if normal,
replace the
photosensitive drum.
(After replacement,
execute the work under
II. C. 2.)
Turn off and then on the
Jan 13, 2011 | Canon CLC 1140 Copier
Burnt resistor on primary side of transformer on pw po:2437473 i would like help identifying resistorf
1. discontinue use momentarily, by disconnecting on periperal energy devices.
2. perform a physical observation to determine extent to damage, before contacting technical support specialist. required information includes device kinds, model specifications and description of the fault.
advice technical support is the most convenient alternative device malfunctions considering, expertise requirements, possible manufacturers specification details recognisabel by technical installment entities.
Dec 01, 2010 | Philips Audio Players & Recorders
Sharp aquos lc-32
Exactly the same problem with mine, Sharp quoted £160 fixed price !!!! -
fixed in the same manner as detailed, many thanks.
Pics attached ... Before
Then screws removed ...
355f6f8.jpg used light emery papaer to clean the contact points between the pcb and the Chassis.
Back togetther all working fine.
Oct 18, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
GPS Logo
174 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
