Question about NEC VT460 Multimedia Projector
My nec vt46 does not want to turn on
When i turn the power switch fro the back the power ligth on the top stays orenge and if i press any button the status ligth remains on as long as your holding any other button and when u let the buttond go the status ligth blinks red afetr like 3 secondsbut the power alwyse remains on no matter what u do
Did you find the solution to the problem cheechaaron? My projector has the exact same problem, I need to know how to fix it.
Posted on Jul 27, 2010
You need to check the manual. It will tell you at the rear what the different lights mean.
Posted on Apr 21, 2009
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I have a nec vt560 and the power light stays orange and the status light is off until buttons are pressed. bottom line is...i cant get the projector to come on...the power light never turns green.
The projector is in standby mode, which is a good sign.
When you press the ON button for "at least 2 seconds or more", what happens.
Do any lights come on at all?
Mar 20, 2011 | NEC VT560 Multimedia Projector
I need the codes for universal control
Hello
Three digit Universal Remote codes fro Sylvania are:-
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 133/ 161/ 163
Four digit universal remote codes for sylvania are:-
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
NB: Switch OFF and switch ON your TV with its front panel power control switch each time before trying an other code.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
OK.
Jan 09, 2011 | Sylvania SRT2420P TV
Bissell 5770 vacuum power won't stay on. The power will only stay on if you hold down the button the whole time.
I just had this happen to me. I took the top part of the vacuum off, unscrewed all of the screws from the top piece and opened it just enough to pop off the plastic red power button. Then I pressed the switch mechanism up and down a few times to reset it and put it back together. Turns out it didn't actually go bad.
Feb 28, 2010 | Bissell 5770 Healthy Home Bagless Upright...
My nec plasma tv seems to turn on for a few secconds then returns to standby,I took the back of it and tested fuses. 2 hi temp ceramic fuses were blown 4Amp any ideas?
Have you tried pressing the "Input select/Exit" button? Right after pressing the power button and the light turns green, press this button until you get to the right input that you are connected to, and hopefully you should see your picture. I had this same issue when I first got this T.V., Hopefully this helps!
Jan 25, 2010 | NEC PlasmaSync 42MP2 42 in. Television
My XBox 360 won't turn on.
try pressing the power button dnt just plug it in u ****
Jan 01, 2010 | Microsoft Xbox 360 Console
Ho to reset oil ligth for bmw x5 2003
switch off ignition
press & hold button between speedo and fuel gage
turn ignition to pos I
after 5 seconds the word "oil service"or "inspection"are shown together with the message "reset"or "re"
release button on dash
press and hold button - after 5 sec the message "reset" starts to flash
release button - press and release button again
the new service interval is now displayed
the message "end sia"is now displayed
switch off ignition
Mar 26, 2009 | 2003 BMW 5 Series
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Nec 42'' plasma
Try holding down the 'INPUT SELECT' button, then press the power button on, on the tv at the same time.
Oct 29, 2007 | NEC PlasmaSync 42MP3 42 in. Television
DiamondPoint V71LCD Not displaying image
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
Jun 27, 2007 | NEC-Mitsubishi Nec Display Solutions...
NEC VT460 Multimedia Projector Logo
534 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
