Question about D-Link DP 301U (DP-301U) Print Server
Hp 1020 dp-300u
Attempting to set-up a HP 1020 Laserjet onto a D-Link DP-300U print server using USB port. I've checked and double checked the settings for the print server and the TCP/IP port I've created and all is well.
Just can't send print jobs through print server. The jobs repeatedly fail. Are there settings I've overlooked?
  • Anonymous Apr 29, 2009
    the print goes to print server but prints does not go to hp laserjet 1020
    Problem Solver:
  • 9 Answers
Dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Posted on Sep 21, 2009
  • 30 Answers
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1020 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Posted on May 22, 2009
    THE SOLUTION NUMBER 2 WORK!! YEAHH
    THANKS MAN
    Posted on Mar 19, 2010
    You need a run PSMointor for printing
    Posted on Sep 10, 2009
    Can't find my usb Printer on my D-Link DP 300U (DP-300U) Print Server What to do anyone
    ok have you tried changing the settings in the print server usually a printer must be configured on the print server before it can be used if it is on the network try telneting in to it through a web browser like you may a modem
    Oct 13, 2011 | D-Link DP 300U (DP-300U) Print Server
    How do I set up and configure a DP-300U Dlink printserver for the first time on a desktop computer running on Windows XP professional operating system. The printer model is Hp laserjet 1018.
    here is the user manual for the DLINK
    http://www.givemefile.net/manuals/printing_server/d-link/file/33217.html
    also this is the link for the printer
    http://h10025.www1.hp.com/ewfrf/wc/product?product=1814094&lc=en&cc=us&dlc=en&lang=en&cc=us
    Mar 18, 2010 | D-Link DP-300U (DHDP300U) Print Server
    DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
    First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
    If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
    If device Config issue check to see it is setup up as an IP Port not a normal local port
    Jul 15, 2009 | D-Link DP 300U (DP-300U) Print Server
    HP LJ P1008 can be used as network printer ?
    I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
    LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    DP 300U
    DP 300U's can get be pretty uncooperative when attached to a different router. One solution is to reset the DP 300U to its factory settings. Use the PS Admin software to do this. (If you lost the PS Admin software, you should be able to download it from the internet.) If the software prompts you for a password and you do not know it, try "SYSXXXX", where XXXX is the last four digits of the MAC address located on the underside of the print server.
    After you reset the DP 300U you will need to set it up from scratch, a process which is not particularly intuitive. Refer to your "Quick Install Guide" (download it from D-link's web site if you don't have it anymore).
    Oct 17, 2008 | D-Link DP 300U (DP-300U) Print Server
    Configuring a Mac Book Pro laptop with a DP 300U Print Server
    I connected my HP5MP to the DP-300U LPT1 port.
    I configured my port on the DLink Configuration tab, giving it a name "hp5"
    ...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
    On my Mac, I go to System Preferences > Print & Fax
    Click the + to add a new printer
    Select the IP option
    Choose the Protocol: Line Printer Daemon - LPD
    Type in the Address: 192.168.0.10
    Type in the Queue: hp5
    Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
    and find the driver for your HP LaserJet 5MP.
    Save it. Works like magic. ;-)
    If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
    Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
    DP-300U revB and KONICA MINOLTA bizhub 163
    I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
    Jul 17, 2008 | D-Link DP 300U (DP-300U) Print Server
    D-Link Print Server Compatibility issues
    DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
    Jan 27, 2008 | Sharp AR-5320 Black and White Copier
    Can Not Print to HP LJ 1020
    hook the print server directly to the computer and program it with a static IP address.
    than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
    Dec 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
    Not printing to network attached printer
    I have a DLink DPR-1260, and found the configuration to be challenging too. First of all, has it ever worked? If not, you may need to check your router config to ensure that they are both on the same subnet. Typically they come set to 192.168.x.x... if the router is set to 192.168.1.1, the print server is set to 192.168.0.10, and your subnet mask is set to 255.255.255.0... it'll never connect. Make sure that the router and print server are configured to the same subnet... 192.168.1.x for example... and then try it. Let us know if that doesn't resolve your issue, and we'll keep working with you.
    Oct 26, 2007 | D-Link DP-300U (DHDP300U) Print Server
    D-Link DP 301U (DP-301U) Print Server Logo
    3,031 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
