Water spill, mouse on the fritz
I spilled a little water on my laptop keyboard about a week ago. It seemed alright so I didn't turn it off (which I realize I should have done after looking at some of the other solutions posted on this site). Since then, my mouse has been right clicking like mad. It often clicks repeatedly for minutes at a time, then sometimes I can get it to stop for a few minutes. I presume this is a fried hardware problem, but are there any possible software fixes or anything else I can do once the thing has obviously dried? Thanks!
    Sniper:
  • 66 Answers
honestly, the only thing you can do, or have done, is to disassemble the laptop, get inside and look at the connectors and components. Sometimes the liquid causes corrosion, and some cleaning with alcohol can clean things up.
This is surely hardware, not an easy software fix.
Other times, cables or connectors can be replaced. I have had the keyboard go bad, the touchpad, the cables to the power strip by the power button, and even leak down into the ram, and corrode the ram contacts.
All were fixable, so it is possible. The key is to get deep inside and check out where the liquid flowed, and examine the parts. A good shop that knows laptops can help.
Posted on Apr 13, 2009
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Spilled coffee on keyboard now screen flickers
I wash once a laptop keyboard after someone spilled beer on it. Try to unmount keyboard and wash it with water and soap. It works for me. Let keyboard to naturally dry one day.
Jul 21, 2012 | Computers & Internet
I spilled water on my keyboard of my eee pc 1000ha. I dried it off and everything seems fine but I'm not sure. Is there anything I should do?
If everything seems fine then it probely is alright. Because it was only water there is no risk of a sticky residue being left behind. You can see my detailed tip here for further info and suggestions on how to proceed.
Jun 30, 2011 | ASUS Eee PC 1000HA Notebook
Spill water on my macbook air, and does not turn on
gone with the wind....or shall i say....water....
dump it in the trash bin....
all liquids are enemy of any IC equipments.....
(many have this dirty habbit of drinking Tea/Coffee/Beer etc while working with their notebooks/laptops.....)
on PC..... the liquids normaly spill on to the keyboard/mouse which is seperate from the CPU...
can replace the keyboard of a PC with just few $$$
but with notebooks the main circuit/motherboard is just below the keyboard.....
once a liquid falls...it just goes thru the holes on the keyboard....and short circuits the ICs...chips...etc
Apr 20, 2011 | Apple MacBook Air
About a week ago I spilled some water on my ASUS U81A laptop keyboard. Put it upside down, turned it off, and took the battery out immediately. Opened up the keyboard to help it dry. Two days later I...
You should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of water on the circuit boards & on other components. On circuit boards, water damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no water seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the water fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Sep 28, 2010 | ASUS Eee PC 900 Notebook
Will not power on, spilled a tablespoon of water on keyboard
liquid spilled on laptop is bad news, even thou it might be just a tablespoon, on the right spot might render your laptop useless, its recommended that you Do Not turn on the laptop, remove batt, allow it to dry for a week, if the laptop does not turn on then its possible that internal components might be affected/damaged. if the system is still in warranty and covers accidental water damage, call your manufacturer, if not, bring it to your local computer shop for repair...
Hope it helps!
Mar 05, 2010 | Computers & Internet
My wife spilled tea on her Dell Inspiron 5100. Now when attempt to start up goes to a black screen with blinking cursor and beeps incessantly. What does this mean, and can I fix it?
add milk!
well spilling tea on the keyboard has most likely fritzed the circuit The beeping and blinking, depending on the number of beeps relates to no monitor and no keyboard.wich seems to fit your description of the fault without having to count
As for fixing it yourself? I wouldn't attempt it.. too many levels to wade through and an expensive fix. anyway. cheaper to buy a new one
Try making a claim for a replacement on your home insurance as a fusion claim. ge3t a new laptop. Perhaps the brands that was used at the Olympics that can sustain dropping and water spills. Vario I think it was.
Please rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Dell Inspiron 5100 Notebook
Spilled water on my toshiba satellite notebook
try : start-control panel -mouse and keyboard, if nothing weird appear,try to reinstall the driver for the keyboard,you'll find it here:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1311513&rpn=PSMA0U&modelFilter=M105-S3002&selCategory=3&selFamily=1073768663&selModel=1311513%7CPSMA0U
If it doesn't work you will have to change the keyboard and hopfully, there is nothing wrong with the motherboard
Jan 01, 2009 | Joy Toshiba M105 S3002 Notebook
Very short freezes constantly
There was more damage than just the keyboard, your fault appears intermitten and possibly some connectors and sockets are not making good electrical contact. You need to dismantle the laptop completely to inspect and clean what ever you can with distilled water and let it dry throughly. It still may not work because there may be some electrical damage to some chips and components, especially if the laptop was running at the time of the wine spill.
There is not much help I can offer you except to advise you to buy another laptop, and if the hard drive in the old laptop is OK then buy a USB hard drive case and insert the laptop hard drive in this case and use it as an external USB hard drive. You need to delete all the old system files etc. to maxmise the hard disk space.
Dec 04, 2008 | HP Pavilion dv9000z Notebook
Mouse pad wont work after water spill
not difficult..with right tools and patience..the touchpad is part of the upper assembly, and requires that the bottom be removed. When I do this, it takes around an hour.
got backup?
Feb 20, 2008 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
