Question about Cyberhome CH-DVD 300 DVD Player
No Power... need a new fuse.
My fuse blew out and I've been trying to find out what size the fuse is. I have tried a couple different one but they aren't the same voltage. What is the voltage and size of the fuse, where can I find one, and what is the name of it on the package?
While wiping off the dvd vhs player it went out. Said it did not recognize the tv anymore. My son put it on his tv and got a half screenof the movie. just took out the fuse t2al 250v. what is my problem?
Posted on Jul 18, 2011
Don't know the name on the packager bt the fuse is a T2AL / 250V should be able to find it at any rat shack or electronic clearing house
Posted on Sep 12, 2007
40 amp. fuse keeps blowing out on 2008 harley
You have a short. Check the insulation on all wiring that carries + voltage - possible that some wire may have lost insulation and is abutting some metal part shorting it out.
Aug 24, 2015 | 2008 Harley Davidson FXCWC Softail Rocker...
Where can i get a replacement on board fan from?
fans are pretty standard things with only 2-3 different sizes so you wont have great difficulty getting one from your local friendly neighbourhood pc repair shop...or electronic retailer unless you live in the Australian Outback or Outer Mongolia or somewhere equally remote. Try a Tandy/ Radioshack/Maplins/PC World-you don't say what country you're in so can't 2nd guess what retailers are near you.
Don't forget, these things aren't motherboard specific; if it's your cpu chip fan then that's more specific to the cpu processor; try searching for that, and if it's just a motherboard cooling fan, then measure the length of one side in mm, and search for that size fan. The fan voltage is always 12volts.
Jun 11, 2012 | DFI LANParty UT RDX200 CF-DR Motherboard
Can a bad voltage regulator cause the main 30 amp fuse to blow?
Usually a bad regulator will only cause problems with charging...
Sounds like you've got a short somewhere in the wiring...I'd start by checking the ignition switch wiring and the connections going into the fuse box.
Mar 19, 2012 | kawasaki VN 1500 Vulcan Classic...
The other day the water company was digging in our yard to fix a water leak and they hit the power line and it blew a couple of breakers in our house. one of those was for the computer and ever since then...
They spiked high voltage and probably blew your motherboard. But possibly only the power supply. Higher quality one's have a fuse, check that. If you plug pc into a power strip check that fuse. Look at mobo and see if you see any burned capacitors. Depending on mobo it might have a fuse check that. If all else fails try a CMOS reset and see if it screwed up the BIOS.
Sep 04, 2010 | Computers & Internet
Microwave just died
The Microwave should be on a different circuit than the fridge. If the fridge kicks on at the same time you have the microwave on high you can damage them with low voltage causing high amperage and blowing the fuse, try replacing the microwave fuse and try to run it off a circuit that the fridge is not on, New hoses have a dedicated plug for just the microwave oven, I own a 1.4 cubic foot oven and it had to have it's own plug due to the breaker size and wire size, it pulled to much power to be on that circuit. So change the fuse if that does not work and post here and will see what else to check, and please rate if this helps.
Aug 08, 2009 | Hotpoint RVM1435 Microwave Oven
Blowing Fuses
If you disconnect the speaker wires from the amp and the fuse blows only after the remote voltage is applied (when the head unit is switched on), the output transistors are likely shorted.
Nov 14, 2006 | Profile 600MSX Car Audio Amplifier
Cyberhome CH-DVD 300 DVD Player Logo
445 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
