15-MOJO12D2 air specs
I am wanting to know the air specs for a, 15-MOJO12D2 subwoofer
2 Suggested Answers
chrisreitano
  • 85 Answers
SOURCE: i want to know how much cubic air a 15 inch cerwin
There are too many variables to answer your question; driver model, port frequency desired, box type required-just to name a few.
I can't anwser your question right now with this info but I can tell you that in the past I have contacted several leading manufacturers tech support to get answers I never would have received from books or software that worked better that I could believe. Call and speak directly with someone in the mobile audio tech support, you will get better answers over the phone.
480-838-9422
-Chris
Posted on Jun 25, 2010
I have 2 15 type r subwoofer and 2000w alpine amplifier i like know if this dual 15 bandpass can handle?
Check the specs on your speakers and the amount of cubic space it needs to breathe and amount of porting required and then check the box to see if it meets that requirement otherwise if it doesn't it will sound like **** and be highly distorted.
Dec 10, 2010 | Dual 15" Bandpass Sub Box Enclosure Plexi...
I want to make a box for this woofer and i want to know the dimensions.
http://www.sonicelectronix.com/item_13203_Kole+Audio+KMX-15.html look at the specs, you should use 3/4 plywood or particle board, roughly 19' tall 19'' wide and 10'' deep
Jun 04, 2010 | Kole audio KMX-15 Car Subwoofer
What is the recommened air space for kicker comp vr sealed do you know the specs for building a sealed box
Really it all depends on how you want them to sound, and to be set up. There really is not specific air space, but there are general air spaces that work, and some times the manufacture will list some specs for different set ups. It also depends on the size of the sub, which you did not specify.
Kicker recommends as follows.
0.4 cubs per sub for a compact box, and 1.8 for an SQ box. SQ stand for sound quality.
So if you want a small box, do .4 per sub. If you want a better sounding box do 1.8.
Rule of thumb and something to think about.
The more air space in the sub, the less power you can run, the less air space, the more power you can run.
For example you can run 200 watts RMS per sub at .4 cubes, but only 140 watts RMS with 1.8.
As well, the smaller box will be louder, But not sound as good.
Dec 24, 2009 | Kicker CompVR 05CVR84 Car Subwoofer
What is the best enclosure volume for 15" Juggernaut 2000watts rms car subwoofer. i want to know the dimension of the box along with ports size.
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require.
On a 15 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
Dec 01, 2009 | Mmats Juggernaut 15'' Car Subwoofer
I need the corrects specs for my 15
Heres all the specs you could ever need: http://www.shopping.com/xPO-Mmats-Juggernaut-15
Nov 18, 2009 | Mmats Juggernaut 15'' Car Subwoofer
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
SUBWOOFER ENCLSURE FOR TWO PIONEER TSW307F 12" FREE AIR
Hi, i know its a long time since 2008.
but do you or enyone else know where to get specs to a pioneer ts-w307f???
im building a box for this sub but i cant find specs so i cant run it on winisd!
i konw this dont answer a qestion but since you did a graph on it in winisd i thought you might have the right specs?
Dec 24, 2008 | Alpine MRV-F307 Car Audio Amplifier
Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Mar 24, 2008 | Audio Players & Recorders
185 people viewed this question
 Grubhead
Grubhead
