Question about Denon DCM-260 5-Disc CD Changer
Denon 5 disc CD player pauses intermittently
I have a Denon (DCM-260) CD autochanger style player that will stop playing a track at random, and then starts up again where it left off. I am fixing this unit for a friend who was aware of my previous experience as a hi-fi repair man in the analogue days, so you can be as technical as you like with your answer. Thank you very much for your help.
  • Peter Blunden Apr 19, 2009
    Hi petraman7. Thank you very much for your help. I have been away for a few days, and have yet to service this player. I will let you know how I go. Cheers!
    Genius:
  • 1,175 Answers
Hi...
1st off , what I do with CD players is clean the rails that the laser assby runs on and treat the rail surface w/ liquid silicone.
Next pull all the cables to the CD assby and reseat them.
Clean the laser lens w/ pure alcohol and swab off till dry.
If there are any adjust pots , note where theyre set, rotate them a couple times and set them back to original set point.
You might be able to get the service manual at
www.free-service-manuals.com (14.00 for 3 months)
or www.stereomanuals.com
Posted on Apr 13, 2009
I need a replacement play/open button where can I source this please?
search for p/n: 9ka2g297a there are many online parts stores that carry it
May 13, 2014 | Denon DCM-260 5-Disc CD Changer
Where is the mp3 plug in for a denon DCM-280
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Denon-DCM-280-CD-Players-review-manual/id/363ci871/t/1-2/
It's capable of playing MP3's right out of the box. See page 18.
Feb 21, 2011 | Denon DCM-280 5-Disc CD Changer
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
Need new on/off button
yes you need new on/off button
Oct 05, 2009 | Denon DCM-260 5-Disc CD Changer
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
May 17, 2009 | Denon DCM-390 5-Disc CD Player
Increasing static and complete sound loss
hello you mean buzzing,humming cause is a high missing broken ground and it needs service by electronic shop............make shure is not missing any wire that must be connected or undervlotage working............saludos
Jan 08, 2009 | Denon DCM-280 5-Disc CD Changer
Denon DCM 370 5 disc changer does not show all discs!
Probably drive belt that rotates the carosel inside is not lining up properly,or the belt that moves the laser mech into position,sounds like its just not lining up properly
Jan 04, 2009 | Denon DCM-370 5-Disc CD Changer
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
339 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
