Question about Poulan Garden
35 cc poulan 16 inch bogs down under load only
35 cc poulan 16 inch bogs down under load only used 3 times but is 3 years old
cmcduncand
  • 714 Answers
SOURCE: I have a 16 inch gas poulan chainsaw. I can't
Hi Speed circuit clogged in Carb.
Remove clean and soak blow out jet, Replace spark plug.
Also verfi Oil mix, add a fuel stabiliser if using fuel with ethanol.
Hope this tip helps.
R/
David
Posted on Jan 29, 2010
dontbother10
  • 2220 Answers
SOURCE: Bogs down?
Try turning the "H" needle CCW a little. Cleaning the muffler and spark arrestor is a good idea too (if it cannot exhale it cannot inhale).
I do not think you need this but something to save for later.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 08, 2010
  • 4088 Answers
SOURCE: new 18" Poulan Pro 42 cc saw, mixed up new gas
Don't use stabil. Use a modern synthetic saw oil (50:1 fuel to oil ratio) available at home centers, hardware stores, and saw dealers. Mix the oil and fuel in it's own container and be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. If it becomes apparent that the carburetor adjustments are wrong, you will need to see your dealer for adjustment. Good luck!
Posted on Dec 18, 2010
  • 2239 Answers
SOURCE: Poulan 16" saw, start fine, runs fine until it
A couple of ideas, it could be a fuel tank breather issue, when it starts to die just try loosening the fuel cap, if the saw picks up again you will need to change the breather, the only other thing i can think of is a bad ignition that is breaking down when hot, the only aswer to this is to replace the ignition unit
Posted on Apr 08, 2011
  • 155 Answers
Usually when a small engine starts fine.. runs fine.. gets hot it's ignition related.
First you want to make sure the cooling fins are clean.. remove any covers and clean the area around the head. If those fins are clogged.. not good.
Second I would check the spark.. and the spark plug condtion.
Also for power tools that don't get used that often.. fuel sytems get gummed up.. fuel gets old.. and folks tend to use the fuel in the can they mixed two seasons ago. Make sure the fuel mix is correct.
I assume it is running fine with the choke off.. however check the choke for proper operation.
Clean or replace the air filter as well.. once all the ignition and fuel components are in good order.. only then should you begin to adjust the carb. Probably not needed.. but don't do it until you are satisfied that you have good air fuel mix and proper spark.
Best of luck
Apr 08, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Best of luck
Won't start after sitting for a few minutes after use, starts good after sitting for a very short time or a long time.
I have 18 inch poulan,if I stop for a few min.then try to start it I do not choke it and it will start right up
Sep 12, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Bogs down?
Lou
Apr 08, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Chainsaw will start but when I squeeze the
Clean the air filter and the spark arrestor and muffler; if the saw cannot exhale it cannot inhale. How old is the fuel mix? If older than 1.5 months it too may be the problem. If no better post back below. Please include the make, model and serial numbers.
Lou
Mar 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Choke/start knobs wont pull out to ingage thus not start.saw is only 6monthsold used twice
Should still be warranted. Why void the warranty? Take it back or find an authorized service center.
Poulan.com
http://www.poulanpro.com/node4042.aspx
The site says 1 year warranty. HTH
Lou
Oct 04, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
548 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
