Question about Samsung YP-U2X Digital Media Player
YP-U2J MP3 PLAYER
MY COMPUTER DOES NOT READ MY MP3 PLAYER. i CAN TURN IT ON AND PLAY MUSIC ON IT NORMALLY, BUT WHEN I CONNECT IT TO THE USB SOCKET, THE COMPUTER TRIES TO RECOGNIZE THE PLAYER AND IT CANT. CAN YOU PLEASE HELP ME?
  • 25 more comments
  • Anonymous Nov 30, 2007
    My samsung ;
  • Anonymous Dec 05, 2007
    when ever i insert mu mp3 player in the usb it say device driver was not unsuccessfully installed
  • Anonymous Dec 06, 2007
    omputer will not reconize the MP3 player
  • stephon Dec 06, 2007
    Computer will not recongnize the mp3 player.
  • norcosolja Dec 11, 2007
    EXACT SAME PROBLEM PLEASE SOMEONE HELP
  • cppc Dec 14, 2007
    I connect and my system doesn't recognize my player
  • Anonymous Dec 15, 2007
    it says usb disconnected
  • Anonymous Dec 17, 2007
    My mp3 won't turn on, my computer won't read/recognize my mp3 and I've reset the mp3 countless times. Nothing seems to work...
    This is my second version of the mp3 and I have no idea what to do with it no. Please help me!!!!!
  • Anonymous Dec 30, 2007
    I can not get my computer to reconize it how can i delete and add new songs to this player
  • angelgirl777 Jan 01, 2008
    i used my samsung player yp-u2j with napaster. the songs expired and now i cannot get them off the player. the player is not recognized in napster or windows media player to remove the songs. my player shuts itself down when i turn it on and when i plug it into my computer the device manager pop up goes on and off but does not recognize the player from that point forward. the player will only charge the battery and thats it. my player is now useless and i am very upset after spending money on it.
    I cannot use my player. I used it with napster and the files expired. now my player is full and I am not capable of removing the files from the player. the player will not register on windows media player or napaster to remove the files. The device manager flickers at the bottom of my computer and will not recognize the player from that point forward. When I connect to my computer is only charges the player and that is it. Please help and I cannot use the player now.
  • Anonymous Jan 03, 2008
    I received this as a gift and it already had music on it. I want to edit on Windows media player, to add titles, move to different places, etc. When I try to find my mp3 player, it will only locate in SYNC. It will only let me delete songs or add songs. I can not listen to music from the mp3 player on the computer, nor can I move or edit. Please help. There were no disks or info from the person I received it from.
  • Anonymous Jan 05, 2008
    como le pongo la musica porque el no me asecta el programa del disco
  • hh4prez Jan 08, 2008
    i have the same problem. At first I thought it was because I got a new computer, but now the two other computers i used to use it on will not recognize it.
  • Anonymous Jan 25, 2008
    my computer dont reckgonize my mp3 either...HELP!
  • MinLT Jan 27, 2008
    I can charge my MP3 and play it. However, I can't download anything new or delete anything old because my computer doesn't recognize the device.
  • qbncgr Feb 03, 2008
    I had the same problem, then I used the best solution posted and it fixed it.
  • GOOFY_1 Feb 11, 2008
    I CAN PLUG IT IN AND IT CHARGES BUT I CANT FIND THE PORTBALE DEVICE IN THE COMPUTER AND I CANT SYNC MUSIC ON THE DEVICE
  • jenn1519 Feb 14, 2008
    ill plug mine in and when i usually plug it in the computer makes a bing noise like it recognizes that its in the usb plug but 2 seconds later it will make the bong noise that i unplugged it which i didnt so i cant put any new music on. it will charge but it wont let me get any music on. and windows doesnt read that its in there.
    help?
  • Black Hawk Feb 22, 2008
    i have the MN3837, and it charges, and play music reguarly, but i cant sync my music anymore!!!!!!!!!!!
  • belola Jun 04, 2008
    I need to find a update for the MPE3 YP-U2J since my laptop does not recognize it.
    Thanks,
    Be
  • Anonymous Jul 15, 2008
    my mp3 is saidingmtp connected and i can`t do anything on it
  • ruez Aug 05, 2008
    i lost my installation cd and now my pc wont recognize the player but it works fine i am using wmp 11
  • eltigre185 Aug 16, 2008
    mi computadorsa no reconoce ami mp3 yp_u2j quiero solucionarlo
  • no_bugga_boo Oct 05, 2008
    i can turn my mp3 on and listen to music but when i plug it into the usb port my computer doesnt recognize it
  • cullenalice9 Dec 14, 2008
    i have a problem my mp3 YP-U2J got washed and i want to know if there is anyway i could fix it.
  • Anonymous Apr 03, 2009
    bo funciona ni prende
Hmm i got the same problem as jenn1519 ill plug mine in and when i usually plug it in the computer makes a bing noise like it recognizes that its in the usb plug but 2 seconds later it will make the bong noise that i unplugged it which i didnt so i cant put any new music on. it will charge but it wont let me get any music on. and windows doesnt read that its in there.
and also my mp3 player is very important for me its a gift from a friend so plzz plzz help ? :(
tanko!!!
its ma emil add hot_chilligirl@yahoo.com.au
Posted on May 20, 2008
Symptoms:
  • The first time the device is connected to the PC after installing WMP11, the device is recognized and music syncs correctly
  • When attempting to use the device again, Found New Hardware bubble appears and then flashes between several messages including MTP Connected, Don't Disconnect, MTP Device found, MTP Device may not work properly, or There was a problem during installation.
  • Device may constantly appear and disappear in Device Manager or appear with an exclamation point indicating an error.
  • Device may not appear in My Computer
  • Uninstalling WMP11 and using WMP10 corrects the issue
  • Using the device on another PC or laptop works flawlessly
There is a known issue with WMP11 and many MTP devices by various manufacturers. This is not specific to Samsung but Microsoft recommends a driver or firmware upgrade from the manufacturer to correct the problem.  If neither is available, the user is instructed to roll back to WMP10.
Please verify the firmware version currently on your MP3 player (Menu > Settings > System > About). US Firmware Version 1.136 is the current version (as of 2/28/07) posted on Samsung.com.  If you are using an earlier version, you should download the current one.  Even If you're running the current version 1.136 or there is a newer version available in the Download Center, you are strongly advised to continue with the instructions below for Updating the firmware AND Formatting the Data area.
IMPORTANT:  Failure to format the data area as indicated in Step 7 below will result in unresolved issues.  You must Format the Data area which will cause you to lose all data on the device.
To Update Firmware:
  1. Download the YP-U2J Updater Utility from the Download Center (Firmware Tab)
  2. Unzip the file and run Setup.exe to install
  3. After the installation is complete, press and hold down the play button on the device while connecting the device to the PC. (If done correctly you will see a window appear on your computer for PLAYER RECOVERY DEVICE CLASS). If this does not appear, try resetting the unit while connecting to the PC
  4. A Windows pop-up screen will appear indicating [Install player recovery device class]. (Select automatically for the installation option) After installation this window will disappear.
  5. Click the updater program icon on your desktop or click Start > Programs > Samsung YP-U2J Updater
  6. Continue holding the play button until the "Found New Hardware" bubble appears.
  7. Check the box near Format Data Area and click Start.
  8. Once complete, click Close
  9. Disconnect the YP-U2J and reconnect it as usual.
  10. The device should now appear in both My Computer and in Windows Media Player.
Posted on Oct 31, 2007
I have samsung yp-u2j 512mb, i kind of not used it for an year and now when i press swtich on button it says SYSTEM LOADING ======20% and goes off...i dont know if its the battery problem or not... can anyone help me out...
Posted on Feb 08, 2010
Occuring the problem when turning on with the title"bulding eror"
Click here for Firmware Update from samsung.com
Here is the instruction for updating the firmware:
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port(Hold down the play button while you connect the device, you should seea message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message"Initializing" on YP-U2J Updater, you can now remove your hand fromplay button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUSTdisconnect the Mp3 player and turn it on. You will see a 20% messagefor about 50 seconds and it will be restarted automatically.
Dec 13, 2008 | Samsung YP-U2X Digital Media Player
Samsung YP-U2 & Windows Media 11 on Vista Home Premium
CLICK Here to Download : Firmware Update
This error is common with Windows Media Player
Here is the instruction:
Update: Pleasekeep in mind that if you sync your Mp3 player with a computer that hasa Windows Media Player 9 or 10, you should do these steps again
Aug 22, 2008 | Samsung YP-U2X Digital Media Player
YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 27, 2008 | Samsung YP-U2X Digital Media Player
Mp3
Follow these steps:
Jan 04, 2008 | Samsung YP-U2X Digital Media Player
Cannot use my player-device manager problem/deleting files
This error is common after with Windows Media Player 11
Jan 01, 2008 | Samsung YP-U2X Digital Media Player
Deleting
I have the same problem! Please post if you figure out how to delete such files!
Dec 11, 2007 | Samsung YP-U2X Digital Media Player
Yp-u2j
My samsung yp-u2j is not connecting, its realy pissing me off, because my cumputed wont download the new hardware i need...
Dec 08, 2007 | Samsung YP-U2X Digital Media Player
YP-U2JXB & YP-U2JZW Won't sync...Help!
Error C00D1236 virtually always indicates one of two things:
1) The device is trying to sync hidden files--are there any?
2) There is licensed media that is being synced, and the license is either corrupt or has expired. If you have any licensed media, then try going back to where you purchased it (in an iTunes-like music management program? In WMP?) and refresh/renew the license.
The bad news is that until C00D1236 is resolved, you can't sync your device. frown.gif
You can bypass syncing, and directly transfer files, In my computer, the mp3 plaer will be shown as a drive.
Now if one of the two solutions above is not feasible for u, try this:
Nov 22, 2007 | Samsung YP-U2X Digital Media Player
Remove music
by connecting to the coomputer
Nov 15, 2007 | Samsung YP-U2JQB MP3 Player
Samsung YP-U2X Digital Media Player Logo
2,194 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
