Question about Dell Latitude D600 Notebook
Error Code in Diagnostic 1000-0146 BUT MY COMPUTER WORKS?????
So, the story goes, I have been having problems with my PCI expansion card slot not working, so I've looked every where for an answer, but have found nothing. But anyways, I decided to do a diagnostic of the device. So I started up the Diagnostic and it always does a Pre-boot System assessment. The assessment found that the "Start DST" failed and gave me the error code 1000-0146. I looked this code up in multiple locations, every post was someone who got this code because their computer was not starting up, not booting, auto restarting, or somthing of that sort. And every answer I found said that this error message means the Drive has failed. But... here's the wierd part. I am typing on the computer that i did the test on, it works perfectly fine (other than the Card Slot). It makes no sense to me at all.... And if anyone knows what the problem could be with my PCI expansion slot, it would be really nice to know that too.
  • ajemma2000 May 11, 2009
    my d600 latitude fails 2 boot unless when forced. it fails d dst test displaying error code 1000-0146. d network card(lan) occasionally fails. could d hard drive failure be d cause of this?
  • 3,940 Answers
The 1000-0146 is a diagnostic result indicating a failing hard drive. Just because the drive fails diagnostics, doesn't mean it will not function and is may run for an extended period before if becomes unusable. But take this as a warning and backup any important data you have on that drive NOW.
As far as your PCMCIA Card slot not working.
  1. Ensure it is enabled in the BIOS and you have no driver errors in Device Manager.
  2. If those all check out, replace the card cage: http://cgi.ebay.com/DELL-LATITUDE-D600-PCMCIA-SLOT-CAGE-CMD3BE7632_W0QQitemZ280331231481QQcmdZViewItemQQptZLaptops_Nov05?hash=item280331231481&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Posted on Apr 13, 2009
Install audio card for asus essention cg5270bp003 pc desktop
http://www.evertek.com/viewpart.asp?auto=58002&cpc=NEWARR
Three views shown.
http://www.revolutionpc.net/store/Asus-Essentio-Ultimate-Desktop-Computer.html
Scroll down to the photos towards the bottom.
Looking at the Front of the computer, the LEFT Side panel removes.
Remove the Philips head screw located towards the Top, on the Side Panel's edge, and the Bottom screw on the Side Panel's edge.
Pull back on the raised fingergrip, formed out of the back of the Side Panel.
The panel pulls back so far, then is tilted out, and removed.
-> FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
You may also wish to remove all cables from the computer, and lay it on it's side for easier access to the motherboard.
http://www.ebay.com/itm/OEM-ASUS-ESSENTIO-CG5270-P5QL-VM-MOTHERBOARD-61-MIB8Q3-01-US-TESTED-/170893854322?pt=Motherboards&hash=item27ca114672
Look at the right side of the motherboard, and the two long White PCI slots.
Above them is a long Blue PCI-Express x16 slot. This is used for a graphics card.
Above it is a small White slot. This is a PCI-Express x1 slot.
If a PCI slot is open you can use it for a Sound Card.
If not, and the white PCI-Express x1 slot is open, you can use it.
Examples of Sound Cards used in a PCI slot, and a PCI-Express x1 slot;
1) PCI;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4459743&CatId=2771
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2941927&CatId=2771
On the back of the computer case framework is a small 'door', that holds the expansion cards in place.
The Thumbscrew is loosened, and this allows the door to swing open.
Find the appropriate expansion slot cover, that matches up to the slot your wish to use, and remove it.
Note that the expansion slot covers, do Not line up inline with an expansion slot on the motherboard.
(Expansion Slot; i.e., PCI, or PCI-Express x16, or PCI-Express x1 )
The expansion slot on the motherboard, is usually one space over from the expansion slot cover on the back.
[Don't believe that is worded correctly, but you will see what I mean with the Side Panel off, and looking at the motherboard ]
Yes. It's a lot of fun(?) trying to keep the expansion slot covers in place, expansion cards in place, and trying to close that 'door' properly.
[Look close. The bracket for the expansion card, (In this case a Sound Card), fits in little depressions in the metal framework of the computer case; or the brackets half-moon hole, will fit over a small peg, in the computer case framework ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | ASUS Essentio CG5270BP003 PC Desktop
M3N78-VM LAN PORT& PCI PROBLEM
1) How do you know that PCI slot is not working? Tried another PCI expansion card in it? Perhaps another LAN adapter card?
(Ethernet Card)
A LAN adapter card will go bad before a PCI slot will.
2) PCI expansion slot is bad? No other PCI slot to use?
Then here is a suggestion,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3504463&csid=_61
Plug it into any available USB port on the computer.
It is a GigaByte Ethernet solution, also. (10/100/1000)
Regards,
joecoolvette
Aug 08, 2012 | ASUS Computers & Internet
Where can i buy a onchip usb2?
FIC FR33E motherboard?
http://www.ebay.com/itm/FIC-FR33E-L-MOTHERBOARD-CPU-LOT-10-/170633274365
Reference: Photo
To the far left side of the motherboard, is actually the Bottom of the motherboard, when installed in your computer case.
The two White long expansion slots you see, are PCI expansion slots.
If one is available, (Open), you can use a PCI USB adapter card.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Seem cheap? Nope. Good quality also. (You can also check the reviews)
Need guidance in installing?
1) Follow Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside the computer.
Computer on a table, computer unplugged from power, computer case open.
[Note* Always unplug the power to a computer AT the surge protector. NOT at the back of the computer. (Power Supply)
You can cause a power surge ]
2) TOUCH an unpainted surface, of the metal frame of the open computer case.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
3) Finding an open PCI slot look at the back of the computer. In the metal frame you will see slots going horizontally.
These are Expansion Slots.
You may have an add-on adapter card already installed, in one of the PCI slots.
The expansion slot cover for it is removed.
You should see expansion slot covers however, in the remaining expansion slots on the back of the computer metal framework.
Remove the one that corresponds with the PCI slot you wish to use.
Be aware that the PCI slot will not be directly in line, with the expansion slot.
When installing an add-on adapter card, you will see when the card is inserted in the PCI slot, the metal bracket on the add-on card, lines up with an adjacent expansion slot.
This will make more sense to you once you go to install the card.
[PCI USB adapter card is an add-on adapter card ]
Line the card up in the PCI slot. Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Also, at the same time line up the metal bracket of the PCI USB adapter card, with the metal framework of the computer case at the back.
Gently push the PCI USB adapter card down into the PCI slot.
Fasten the card's metal bracket to the computer's metal framework.
Post the computer manufacturer name, and model number, if you need guidance in opening the computer case. Post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | FIC Computers & Internet
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
Hi, Is Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card capable for my Compaq HP Presario SR2020NX? -thanks a lot.
You mean will the Asus ATI Radeon HD6450 with 1GB of graphics memory, work in a Compaq Presario SR2020NX Desktop PC?
Yes.
The Compaq Presario SR2020NX Desktop PC has a PCI-Express x16 expansion slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757470&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3245048
{Motherboard illustration and photo are towards the bottom of the page}
Look at the specifications.
Scroll down to the heading - Expansion slots.
Three PCI. (PCI expansion slots)
One PCI Express x16 graphics.
NOTE*
Looking at the motherboard illustration, it is Wrong.
Shows - PCIEX1 (PCI E X1)
According to the specifications it is a PCIEX16 expansion slot. (PCI-E x16)
A PCI-Express x1 slot has 36 contact pins. 18 on each side.
In comparison a PCI slot {White} has 124 contact pins. 62 on each side.
Looking at the photo of the supposed PCI-E x1 slot they show, the black PCI-Ex1 slot is longer than the white PCI slots.
It is a PCI-Express x16 slot with 164 pins. 82 on each side.
The Asus ATI Radeon HD6450 uses a PCI-Express x16 expansion slot.
So you know the graphics card will fit. Low-profile to boot.
Power requirement:
The Compaq Presario SR2020NX desktop computer comes with a 300 Watt power supply.
(Although in actuality it's more like 70 percent of the maximum rated wattage. 210 Watts)
Enough power for the computer, and the graphics card.
ATI graphics cards do not use as much power as a comparable Nvidia graphics card.
Concerned that the Asus graphics card uses DDR3 graphics ram memory, and the Presario SR2020NX uses DDR2 Sdram ram memory?
Don't be. The graphics cards graphics memory runs independent of the computer's ram memory.
Information on PCI-Express,
http://en.wikipedia.org/wiki/PCI-Express
(Top right of your page, blue Comment)
Regards,
joecoolvette
Sep 15, 2011 | HP Compaq Presario SR2020NX PC Desktop
Hp a705w pavilion how to properly installed the video display adaptor
Since the HP a705w desktop computer comes with Integrated Graphics, I'm going to assume you are installing a graphics card.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00255589&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=435558
The above is HP Support > HP 705w desktop computer > Specifications.
(Graphics Card, Video Card, Graphics Adapter Card, and Video Adapter Card, all refer to the same thing)
The expansion slot used for a graphics card is a PCI slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00063244&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=435558
The above is HP Support > HP 705w desktop computer > Motherboard Specifications.
Scroll down the page to the motherboard illustration shown in Figure 1, and the motherboard photo shown in Figure 2.
In the illustration the PCI slots are at the bottom of the motherboard, and are named, PCI Slot 1, PCI Slot 2, and PCI Slot 3.
In the photo the PCI Slots are shown, and are White in color.
You can use any available (Open) PCI slot.
You can use a PCI graphics card. (PCI Video Adapter Card. Same thing)
Suggest you install the software (Drivers) from the CD disk that comes with the graphics card, First.
Turn your computer on, when Windows has fully loaded, install the disk into your optical drive. (CD/DVD drive)
Follow the simple instructions, install the software.
When the software is fully loaded restart your computer. Don't be alarmed as your computer won't use this software yet.
After Windows has fully loaded again, shut your computer down normally.
(Start > Turn Off Computer > Turn Off)
Unplug your computer from power.
Open the computer case.
Follow Anti-Static Precautions.
Static will fry out (Short Circuit) the hardware components inside a computer.
(Processor, Ram Memory, Graphics Card, motherboard chipset, Harddrive, and so on)
With the computer unplugged from power, working on a table, computer case open, TOUCH the metal frame of the oprn computer case.
Should you leave your computer in the middle of working on it, upon your return be SURE to Touch the metal frame again.
There will be a metal slot cover, installed on the outside frame of your computer case. (Expansion Slot Cover)
This flat piece of metal will cover where you want the PCI graphics card to be.
It has to be removed.
There are several methods that this metal cover will be attached, to the metal frame of the computer case.
[ NOTE*
The metal expansion slot cover you have to remove, will Not be inline with the PCI slot.
It will be over one slot
Once you attempt to physically install the PCI graphics card, you'll see what I am referring to ]
1) To remove this metal cover look for an + in it. A flat tipped screwdriver is installed in the +, and the screwdriver is tipped down.
(The handle of the screwdriver is tipped down)
Looking at the back of the computer the expansion slot metal cover is horizontal.
The cover is twisted in an up, and down fashion to remove.
(Twisting from the bottom of the computer, towards the top, and then back down again)
There are small metal tabs that hold the metal cover in place. You are twisting the cover to break these metal tabs.
2) The metal cover is held in place by a single Philips head screw.
Remove the screw, remove the metal expansion slot cover.
3) I don't believe the a705w had a cover plate. A cover plate is hinged on one side. Usually a single screw is removed, and this allows the cover plate to swing to one side.
This action allows removal of all expansion cards installed.
Once the metal expansion slot cover is removed, line up the contact pins of the Video Adapter Card with the PCI slot.
Insert the video adapter card straight down in the PCI slot.
Install the screw that holds the video adapter card in place, to the metal frame of the computer case.
Close the computer case.
Plug your monitor into the video adapter card.
Plug the computer back into power.
WAIT 1 minute, turn the computer on.
For questions please post in a Comment.
Sep 28, 2010 | HP Pavilion a705w PC Desktop
We have an emachine w3400 and need and new video card but don't know if it is PCI standard or PCI express how do i find out?
The eMachines W3400 desktop computer has an MSI MS-7145 motherboard.
(MSI = Micro Star International, Inc)
This is the MSI MS-7145 motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket754/msi7145.shtml
The MSI MS-7145 motherboard, has one PCI Express x16 expansion slot, which is used for a graphics card.
Viewing the bottom left of the photo, you will see three white PCI slots.
Right above them is a longer white slot.
This is a PCI Express x16, expansion slot.
Scrolling down to the subheading - Expansion Slots,
You will see - One PCI Express 16x slot, listed.
Should you require information in installing a PCI Express graphics card, or information on which PCI Express graphics card may fit your needs, state so in a Comment.
(Believe upper right of your page)
Jun 16, 2010 | E-Machines eMachines Desktop PC
What is the advantage of PCIe expansion bus and how willl it contribute to providing a solution at the internet cafe?
A PCI expansion bus is a slot in your computer, a place where yo can plug in a electonic device. There are several different kinds of slots in most desktop or tower style computers, PCI is one of them. PCI slots will accomodate a variety of expansion devices, a modem or Network interface card for example.
How a PCI clot will interface with the rest of your question is a mystery to me. What is the problem at the internet cafe??? I would expect most folks would use a laptop computer at a internet cafe ... laptops do not have PCI slots. The Cafe may have a tower with PCI slots and they may have an issue that could be addressed by an expansion card installed using the PCI card.
If you can ask your question or present your situation, I and other volunteer workers here would be glad to have a look at it.
Thanks for your interest in FixYa.com
Feb 24, 2010 | Computers & Internet
Monitor screen stays blank
HP desktop computer? Change the monitor cable. The cable from the monitor to the computer, may be bad.
Happens.
If this doesn't solve it then I suggest the GPU is bad. Graphics Processing Unit. If you have Integrated Graphics, (Also referred to as 'On-Board'), then I suggest buying an average, inexpensive graphics card, and installing it.
You'll have to see what expansion slot, your computer uses for graphics. It may be a PCI slot, or an AGP slot, or a PCI Express x16 slot.
Clear as mud on that last one? Let me give you some links, that might help clear up what an Expansion slot is, and the three types of expansion slots used for a graphics card.
1.Expansion slot:http://en.wikipedia.org/wiki/Expansion_slot
2.PCI (local bus):http://en.wikipedia.org/wiki/PCI_(bus)
3.AGP:http://en.wikipedia.org/wiki/AGP
4.http://en.wikipedia.org/wiki/PCI_Express
5.http://en.wikipedia.org/wiki/File:Asus_a8n_VMCSM02.jpg
The link above (No.5) shows a photo of an average motherboard. At the top right you will see two White slots. Those are PCI expansion slots.
Below the PCI slots is a PCI Express x16 slot. It is Black in color.
Apr 10, 2009 | Computers & Internet
Card needing 2.2 compliant PCI slot work in 2.1 compliant slot?
Hi ginger_man07,
Yes. 2.2 devices are backwards compatible & will function with your 2.1 slot.
Enjoy ginger_man07!
Thank you for using fixya.
Mike
Jan 13, 2009 | Computers & Internet
Dell Latitude D600 Notebook Logo
1,096 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
